Question about Canon imageRUNNER 8500 Copier
Why my ir6000 copier always hardern toner and make my cleaning screw brokem ????????????
  • 71 Answers
Hi
first are all the filters clean and the fans working? If so then the drum heater is getting to hot. Unplug it see if that helps .If that works then replace the drum core heater.
Posted on Jan 01, 2011
The problem is about error 000002 0000 for my ir6000
General condition
1) Is the developing assembly locking plate mounted correctly?
NO: Mount the plate correctly.
General condition
2) Is the shutter releasing member of the hopper mouth mounted correctly
to the developing assembly locking plate?
NO: It is likely that the inside of the hopper is clogged with toner. Remove
and then mount back the shutter releasing member to remove
the clog, or replace the hopper unit.
General condition, Developing assembly toner sensor (TS1)
3) Is the developing assembly adequately provided with toner?
YES: Check the developing assembly toner sensor.
General condition, Hopper toner sensor (TS2)
4) Is the hopper adequately provided with toner?
NO: Check the hopper toner sensor.
Hopper connector, Hopper supply motor (M10)
5) Is the connection of the hopper connector normal?
NO: Connect the connector securely.
YES: Check the hopper supply motor.
Feb 14, 2013 | Canon imageRUNNER 7200 Copier
I amusing cannon ir6000 . the error indcation is -check hopper conetivity
I take that it is saying that the toner hopper is not connected to the copier??? The connector for the hopper is covered by a small cover with one screw. With the front door open look on thebottom right of the hopper, there is a small cover > make sure the copier is "OFF" > remove the screw and you will see a white connector > make sure that the connector is installed & all the way in..... If that dose not do the trick, you may have a bigger problem....... Good Luck
Jan 26, 2011 | Canon imageRUNNER 5000 Copier
Ir6000 harder toner
check cooling fan at the bottom if it is clogged with dust, it wont allow air ventilation resulting in hardning toner.
Dec 30, 2010 | Canon imageRUNNER 8500 Copier
ImageRUNNER 7200 Copier: hi I'm Akar I have a canon ir6000 copier my...
The problem is with toner section. The copier cant get toner to toner unit or the toner motor is faulty.
In one case eaven the main pcb caused the problem.
I would try to replace toner hopper assy.
call service.
May 16, 2010 | Canon imageRUNNER 7200 Copier
Vinod canon ir6000 error e00061-00001 i cant
hai,one ir6000machine in oneand most problem eo61-01 please solution in this problem thnk you.
Dec 08, 2009 | Canon imageRUNNER 8500 Copier
Error code e000020 in ir6000
E020
General condition
General condition
Oct 25, 2009 | Canon imageRUNNER 7200 Copier
Blank copies on an ar208s sharp copier
Inside this machine has 3 sections. Toner cartridge, developing unit and drum unit. First pull out the toner cartridge then you will see a blue anodized screw, loosen this screw then pull this section ( developing unit ), if there's already toner inside the chamber, clean it and pour the all the developer into the chamber then put back the developing section, tighten the blue screw and install the toner cartridge.
May 12, 2009 | Sharp AR208s copier AR208s All-In-One...
Error code E000019-0000
Hi this is only indicating a dirty waste toner bottle neck.
It is easy to solve.
Take a star screwdriver,remove the one screw of the left lower panel.You will find the panel at the left-lower side of the machine,the side were you have to open to remove paper jams on the fixing side of the machine.
After removing that panel,remove the bottle remove the toner inside the bottle clean the NECK of the bottle inside and outside and put the bottle back in it's place.Put the panel back and switch machine on and off.
THIS WORKS ALWAYS
Jan 05, 2009 | Canon imageRUNNER 3300 All-In-One Laser...
Toshiba 2060
bota la botella que esta jenna de toner cuando avre la puerta y ponle una nueva
Sep 23, 2008 | Toshiba 2060 Copier
Canon imageRUNNER 8500 Copier Logo
142 people viewed this question
old marine
old marine
