Question about Lite On LTR 16102B CD-RW Burner
Tray will not eject on LTR 16102B CD-RW
The tray will not eject when button is pushed or if eject is selected, the LED light does come on. If the tray is open it will close when button or eject is selected. Any suggestions as to why?
    Master:
  • 461 Answers
Most likely due to a worn belt. You can use a paper clip in the manual eject hole while pressing the button repeatedly to get it open. The belt or the drive will need to be replaced.
Posted on Dec 19, 2008
DRIVE DOOR WONT OPEN
push the hole of front side with a stick
Dec 23, 2013 | Lite On LTR 16102B CD-RW Burner
My MSI GT660 Dvd will not open or eject
There are two ways to open the CD/DVD drive door if the button just below the drive tray does not work.
Go to My Computer and right click on the drive and click on Eject.
If this does not work then you can manually open the CD/DVD drive tray by -
Straighten a paper clip and gently insert it into a tiny hole below the drive tray next to the Eject button. Push the paper clip gently until the drive tray pops out, then pull the tray until it is fully out, then you can remove the CD disc.
If you still having problem opening with the Eject button, then the CD/DVD drive is faulty and needs replacing.
Feb 18, 2013 | MSI GT660 Series CD 8X DVD RW DL Burner...
The CD rom does not open?
Take a paper clip now straighten it push it in the tiny hole on the front of the CD ROM drive
the drive should open
Apr 12, 2011 | LG (GCC4243N) CD-RW/DVD-ROM (Combo) Burner
My cd rom tray will not eject and the light is
have you manually tried to eject the disc tray? There's a little hole on there somewhere, stick an unbent paperclip or safety pin in it and push until the tray starts to come out, then pull the tray out with your fingers.
Once you've done that, push the button to allow the tray to automatically retract.
Jul 22, 2010 | Teac DW 28E CD-RW/DVD-ROM Burner
My LG multi dvd writer lightscribe tray wont open. the green light is steady. no matter how many times i try to eject the tray ang it wont open. there is dvd+r inside.
use a unfolded paperclip and insert it into a small hole below the disc tray. This is the manual eject port. Stick it straight in and push, a little bit of pressure will be needed.
Apr 20, 2009 | LG Super-Multi GSA-4163B 16x8x16x DVD+R/RW...
Cd rom tray open problem
normal problem for samsung cd drives . clean the rails of drives that which tray is commin out . it mainly caused due to the change ina laaingnment of drive tray
Dec 04, 2007 | Samsung (DSSMBK482448) CD-RW Burner
CD Drive not Ejecting properly
Hi, Since the warranty period has expired I will assume that the CD/RW has been in use for some time. Normally a small belt powered by a motor drives a gear that slides the tray out. Sometimes this belt is loose, warped or plain cut. Replacing the belt should solve the problem. You have to open the CD and it is near the front just below the tray. In other instances, the grease on the toothed railing at the sides and/or underneath the tray gets gummed up, cleaning and repacking with new light grease should take care of that. Rarely (but still does happen), the motor itself burns up and replacement (if you can get the part) is in order. An interim fix is to push a small straightened metal paperclip at a small hole below the tray cover/lip and slightly push till the tray partially opens. You can then manually pull it out. Hope this be of some help/idea to you. Good luck and kind regards.
Aug 27, 2007 | Samsung (SH-W08AENB) DVD±RW Burner
CW088D CD-RW drive
All you can do is the usuall checks:- try, go to my computer>properties>hardware tab>device manager and go down the list to cd/dvd drives, click on the '+' and right click on your listed drive and select uninstall. restart the pc and then the drive will be re installed with drivers automatically. if it still won't eject then there is a drive fault.
Apr 23, 2007 | CyberDrive CW088D CD-RW Burner
Drive wont open/eject
try, go to my computer>properties>hardware tab>device manager and go down the list to cd/dvd drives, click on the '+' and right click on your listed drive and select uninstall. restart the notebook and then the drive will be re installed with drivers automatically. it may be a firmware or driver error.
Apr 17, 2007 | LG GSA 4163B DVD±RW Dual Layer Burner
CD-RW Problem
There some few tips you can try. Power down the computer then open the cd tray by inserting a sharp object in the small hole near the tray. Look for this hole, then using the sharp object push it pretty hard. With the other hand try to pull the tray out. Once you've pulled it power on the computer (with the cd-rw's tray opened) and watch what the cd-rw is actually doing now. If after it retracts the tray it is doing the same, you will need to dissasemble it. If you are willing to try this, please post another message and also specify there what did the cd-rw drive do when you've applied the method i've told you before.
Mar 11, 2007 | Lite On (LTR-52327S/5238S)...
Lite On LTR 16102B CD-RW Burner Logo
435 people viewed this question
Top Lite On Computers & Internet Experts
John Anderson
John Anderson
Rommel Balcita
Gbenga
Are you a Lite On Computer and Internet Expert? Answer questions, earn points and help others
