Question about Intel Motherboard
How do I fix OS does not see hard drives - MSIK8T NEO mother board raid 0
  • 67 Answers
1. Reset the Motherboard by either removing the CMOS battery or the CMOS jumper and putting them back.
2. Go to your BIOS settings and check if the settings are right or even restore to default.
3. Check the cables ( This is a common problem)
Hope this helps
Posted on Dec 30, 2010
I have two WD1600s, in RAID 0 configuration, on my Dell XPS, XP. One has failed. Can I just buy another one and reload the OS? Will any WD1600 do?
If you have a Raid 0, then both drives are tied into one. You could remove the bad drive, and just use the leftover one. But you would need to disable RAID in the BIOS.
Unless you know how you benefit from a Raid 0, I do not recommend keeping a Raid 0 if you have important files you need to keep.
you could also buy another drive, disable Raid, and install the operating system on the first drive, and keep leftover files like pictures etc on the second drive.
May 03, 2011 | Western Digital Caviar WD1600 (1600YD) 160...
Ugrade of DL380 G4 Server HDD Raid Array 36GB --->146GB Required
Do a ghost on the first hard drive install ghost on new hard drive and replace, I can provide more details on procedure just ask
Jul 25, 2008 | HP Compaq ProLiant DL380 G4 Server
I need a diagnostic tool for RAID falure code 0. Initial boot indicates degraded condition. DISK scan does not seem to remedy the issue. Did the drive actuually fail? Is there a fix? Primary disk still...
It looks like you have two arrays here. The first one being a mirrored RAID array and has only one disk. This means that the other disk has failed in some sort. This does not mean that the drive is bad, just the RAID failed for some reason. You will need to rebuild the RAID if you want to maintain the same level of redundancy.
You can just attempt a rebuild the RAID to the same drives but if this fails you will want to replace the bad drive. In order to do this you will need to make sure you can tell which drive is which. You do not want to mirror the bad drive to the good one.
If attempting a rebuild to the existing drive does not work or is not an option (because the failed drive could really be bad), you will need to determine which physical drive needs to be replaced. You may be able to hot-swap the drive but if you can power things down, that is always safest. Once the new drive is installed, you can rebuild to it and all should be well after that.
Jan 04, 2011 | Dell Dimension 9100 PC Desktop
Motherboard upgrade - Sony Vaio VGC-RB62G - RAID 0 issue
Why don't you try to get your main drive running before getting into Raid Configurations. Set your single drive to Master and run setup telling it you have one drive. Once you are satisfied that it is not some other fluky error, put in the other drive and I believe if SATA you don't even have to worry about Master Slave. Go about your boot and go into setup again. Hopefully all is good with the world and all that has to be done is fix up BIOS. No matter what, there is never an " out of the box " clean system. Make sure you plug your cables in correctly. I assume you're running EIDE. You'll get it.
Apr 18, 2010 | Sony VAIO VGC-RB62G PC Desktop
I tried to install SATA Hard Disc to MSI PT8 Neo-V Mother Board. But Even AMIBios Setup, it could not seen and when I try to install the windows, it tells no hard drive found.
cek our bios setup
1. is that addon card set to SATA or RAID?, SAT the set should be!
2. Broken? (maybe the cable not connect, power cable is bad or something else like, try to hear the sound working harddisk, teh sound because the HD's motor is working)
3. this time, the HD is very big enough, but the software not followed yet, so maybe your BIOS need to be upgrade, i dont know. try to flash it
at last, the HD only display detect when u boot the CPU. at BIOS is not display detect.
that my experience
sory if not helping
Sep 29, 2009 | MSI PT8 Neo-V Motherboard
Can't connect SATA Hard Drive to MSI PT8 Neo-V Mother Board
You tell where in the System or in the BIOS. In BIOS on the SATA Mode or RAID Mode while in the System you install RAID Software to recognize and detect any SATA or RAID Hardware.
About operating system
That depends on how you want to set up your system. If you want multiple hard-drives to work together as one, yes, you will need to load RAID drivers during startup. If you do not want multiple hard-drives to act as one large hard-drive then no, you will not need to load RAID drivers during startup.
I would not recommend loading RAID drivers if you only have one hard-drive. RAID is for two or more hard-drives in the same computer.
Feb 18, 2009 | VIA MSI K8M NEO-V K8M800 Chipset 800MHz...
Asus K8S-MS boot problem..
my understanding is that if you do not have other drives in a raid configuration you do not need the raid driver loaded ,have your hard drive plugged into the first sata slot, then format the hard drive ,instal o/s and all should be good.
hope this is of help
Terry
Mar 10, 2008 | ASUS K8S-MX Motherboard
RAID 0 Array disappeared after reboot
I would try the hard drive on another sata controller/port to verify that the bad drive is in fact bad. If it is really bad, then no there is nothing you can do but replace the drive and recreate the array (losing all data!).
You can not 'recover' a failed RAID-0 array because there is no parity or mirror data on an extra disk like there is with the other RAID modes. This is why people recommend against using RAID-0 for important data (unless you take frequent backups): RAID-0 actually increases your likelihood of losing your data. Statistically speaking, you are multiply the failure rates of each individual drive together.
Dec 22, 2007 | Promise FastTrak S150 TX2Plus Serial ATA...
Intel Motherboard Logo
21 people viewed this question
Top Intel Computers & Internet Experts
Tony
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
