Question about GE Dryers
I have a ge profile harmony dpgt750ec2pl it stops heating will work for days ok them stops heating. Try it again next day works fine. The vent outside flows very good. any help ?
  • 749 Answers
SOURCE: GE Profile Harmony DPGT750EC Electric Dryer just shuts off randomly! HELP!
what's the problem?
Posted on Nov 16, 2007
Master_Tech
  • 770 Answers
SOURCE: Dryer Not Heating
I can email you the manual for the unit please post your email address and i will send it in PDF format you can print it off or look at it if you have dial up connection it may take awhile it is like 12Mb
Posted on Jan 25, 2008
Master_Tech
  • 770 Answers
SOURCE: GE Profile Harmony Dryer - not drying clothes
Check your email
Posted on Apr 29, 2008
  • 54 Answers
SOURCE: GE Profile Harmony Gas Dryer DPGT750GC1PL not heating
If you hear the blower ramp up when you start the dryer and it slowly ramps down or quits all together then you need to replace the blower.
Posted on Jul 04, 2008
  • 33 Answers
SOURCE: GE Profile Harmony DPGT750EC Electric Dryer not heating up
Check the air flow from the vent-if there is no air or very weak air flow, it is the blower motor. It is not getting up to speed or not spinning at all. Try this:
Press "Home"
Press "Help"
Simultaneously press and hold down BOTH
"My Cycles" and "Back"
After a few seconds the dryer will enter service mode and report any problems.
Pertains to GE Profile HarmonyDPGT750EC/GC
Posted on Aug 07, 2009
I have a GE Profile Harmony model #DPGT750EC2PL. The appliance has stopped heating and blowing the air out of the house. The drum is turning but thats about all. I have cleaned the vent line, flipped the...
no the belt should be taught there very trickey to fit they loop back around the tie back wheel this would the the cause of slacking in the belt as for no heat it is either a blown heating element or a blown thermal fuse
Sep 12, 2011 | Dryers
Only gets warm not hot. Has been intermittent problem. works for six monhts and then fails for a few days then works again. Vent line is clear
Could be thermostats or heating element ..You will need to test them with multimeter stats should be closed circuit Element may be Twin circuit for low to high heat Should read around 38 OHMS....
Feb 22, 2011 | GE Profile Harmony DPGT750EC Electric...
I have a GE Dryer Profile Harmony. It is several years old. The dryer is not blowing air out the back ventilation so not drying. It is making a quiet odd sound as well. When I troubleshooted I shut the...
You vent is plugged very bad. Disconnect the vent tubing and thoroughly clean it out. It will heat and dry like new afterwards guaranteed. These dryers have sensors that shut the burner off if the exhaust is not venting properly. Once its cleared out it will run perfectly again
Apr 09, 2010 | GE Profile Harmony DPGT750EC Electric...
DescrI have a GE profile harmony electric dryer model #dpgt750ec1pl. About 5 minutes into a drying cycle the blower shuts down. There is still heat but no air coming out of the dryer duct. Any suggestions?...
you should not have heat when motor stops there is a switch in the motor to shut the element off....yours is not working(you could burn your house)replace the motor.
PLEASE DO NOT TRY IT AGAIN...can't be lucky all the time
Aug 07, 2009 | GE Profile Harmony DPGT750EC Electric...
GE Profile Gas Dryer - Heat goes on and off
The operating coils get hot and quit. They only cost 20 bucks. Read more about it here:
Gas dryer works then quits then works some more
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Mar 31, 2009 | KitchenAid KGYS850LT Gas Dryer
Long drying time
Check directly behind dryer to see if there is squished flex vent. Also keep vent as short and straight as possible. Avoid flex venting, or use as little of it as possible.
Jul 17, 2008 | GE Profile Harmony DPGT750EC Electric...
Ge profile harmony dryer
You most likely have a clogged venting system going to the oustside.. Try this pull the dryer away from the wall remove the flex venting pipe.
Run a load now yes i know the heat and moisture will come in the house but it is just one load(open a window) if it works ok then you will need to get someone out to clean your vent and your money back from the repairman who came out .....any technician worth anything should have told you this.....98% of long dry time calls are a plugged venting..just and FYI...Hope this fix ya if so plz rate
Jan 26, 2008 | GE Profile Harmony DPGT750EC Electric...
GE Profile Harmony Electric Dryer - Starts out heating but then screen says SENSING
nicknames, usually with long dry times I suspect a pinched or clogged vent. Make sure you check that first. You can do a test to check the moisture sensor. The 2 sensor bars will be on the inside of the drum just below the vent cage. Press the home and then help button. Next press and hold the help and start/stop button for 3 seconds. On a dry sensor, you should see a voltage of approx 4.75 displaying. Now get a wet rag and hold them across the 2 sensor bars. You should see the voltage drop to about 1.0 volts. If it does this your sensor is ok. Check the vent and this out first and we will take it from there. Catriver.
Dec 03, 2007 | GE Profile Harmony DPGT750EC Electric...
Dryers Logo
55 people viewed this question
Top GE Dryers Experts
Dave Harrison
John Tripp
John Tripp
vince
Are you a GE Dryer Expert? Answer questions, earn points and help others
