Question about Grundfos Comfort System Recirculator 595916
After installing the thermo bypass valve on the furthest sink faucet from the water heater, the sink faucet has no pressure, and there is hot water slowly comling out of the cold water valve.
It sounds like the installation loosened sediment inside pipe.
Remove sink aerator and see if you can flush open the faucet.
Also check if other faucets are receiving hot water from hot-and-cold taps that says if grundfos is pumping hot water from the water heater correctly.
http://waterheatertimer.org/Water-heater-recirculation-system.html
When recirculation pump is running, both hot and cold water lines have hot water.
If other faucets have hot water in both lines, then that tells you the blockage is localized in furthest faucet supply lines.
You may have to dissemble those supply lines and flush the sediment out.
Posted on Dec 30, 2010
How do I prepare my travel trailer water systems for winter so that they do not freeze
The first thing to do is to drain the fresh water tank. Drain the hot water heater. Install the RV antifreeze by allowing the water pump to be pumped into the water lines by opening the valve for this process. Open each water valve on all the sinks and the toilet valve as the RV antifreeze is being sucked into the water system and run until the color changes to the color of the antifreeze. Allow each trap to have antifreeze in it also, sinks, shower drain etc. Remove the inline water filter if one is installed and install the bypass plug in its place.
I actually am not able to get rid of the antifreeze taste from the water system so I blow air into the hot water tank drain at a low pressure until all the valve at each place water is controlled. Do not forget the outside sprayer and the shower hose and the shower head.
I allow the pressure to build up to 20 psi or so and then go into the unit and open each faucet until all the water is pushed out of the lines. Then I dump antifreeze into each P trap. Do not use the antifreeze used in the engine cooling system but the non toxic type made especially for RV water systems.
Sep 17, 2017 | RVs
One cold water valve under bar sink
Just cap the open hot connection. When the valve is set to any intermediate position between hot and cold water will flow from the hot side to the cold side if there is any pressure difference. In your case the difference is your water pressure. You did nothing wrong you just did not finish the install.
Mar 23, 2014 | Water Heaters
No hot water pressure in kitchen, low cold pressure
sounds like a bad faucet//only if you had good pressure before it was installed..to cheaply test..take the hot water off from the shutoff valve and spray it into a milk jug to see if theres good flow..then replace the faucet assmbly..dont forget to turn off the shutoff valve first..or you will get a watery surprise!
Jan 08, 2014 | Home
I have a leak coming from the "cold" line right at the valve joint. There is signifigant calcuim build up on the pipe from the valve to the connection of the water heater, (maybe 8 inch of pipe)...
Very simple - call a Plumber. He will fix your plumbing problem, and any foreseen potential problems related to your water leak. He may also suggest replacing your 6 year old water heater. Of course ..... for a professional cost.
However, depending on your time, skills, proper tools, patience and luck, it's easy enough to perform yourself:
1. Switch off the water heater Breakers (220v) in your service panel.
2. Turn off the water supply to the water heater.
3. Attach a water hose to the drain faucet. ( a good time to flush sediment -calcium deposits)
4. Open a hot water faucet to vent (above the level of the water heater drain - kitchen sink)
5. Remove the suspected leak components. (a union connection is a good place to start)
6. Install New pipes -3 wrap all male threaded ends with teflon Tap. Tighten securely - using 2 wrenches.
NOTE: Before refilling - you can turn on the water heater supply valve for a few minutes, to flush out any lingering calcium debris.
7. Shut off drain valve - remove hose. Shut off venting hot water faucet.
8. Turn on water supply valve to fill water heater.
9. Open a hot water faucet to relieve air pressure while filling - preferably the bath tub faucet, it doesn't have a screen that might clog.
10. When water flows without air - shut off tub faucet.
11. Look for leaks.
12. Switch the water heater Breakers on.
Note: 50 gallons should take an hour or more to heat up. Turn on a hot water valve momentarily within this heat up time to relieve thermal expansion. ( the PT valve on your water heater will perform this task if pressures/temperature exceed new water heater tolerances - it's just a precaution to introduce these fluctuating pressures on your fragile 6 year old unit)
These are just basic instructions - assuming you fill in the common sense and work safe steps.
Good Luck - The Skill will only come after trying.
Mar 05, 2011 | Rheem 50 GAL ELEC TALL Water Heater 6YR SC...
We have a Delta 172 single handle faucet. We had our hot water heater replaced. Now it takes longer for hot water to get to the faucet. Could debris (calcium build up, etc.) from the replacement get in...
Yes, debris from water heater replacements often breaks lose and gets stuck. The problem could potentially be anywhere between water heater and the faucet. The faucets shut off valves or the Delta faucet cartridge itself. Turn the hot and cold water valves off under the sink and disconnect the water supply lines from the faucet. aim the water supply lines into a bucket and turn the valves on one at a time. If there is a significant reduction in the water pressure and volume on the hot water side, you need to replace the shut off valve. If there is no reduction in water pressure, you need to clean and/or replace the Delta faucet cartridge. Contact Delta to receive free replacement parts.
Dec 11, 2010 | Delta Faucet Delta 172-SSWF Waterfall...
I have a brand new faucet not getting any water pressure? Water Pressure was fine before putting new faucet in. How do i troubleshoot this problem and get my bathroom sink running properly again?
It is very common when you first install any faucet, for the aerator on the very end of the faucet (where the water comes out into the sink) to plug up with rust or sediment. Because you had to turn off water supply, it churns up this sediment in pipes. It initially plugs up the filter/screen in aerator. Just unscrew the end & flush it out with water. Then reattach.
Jun 16, 2010 | Peerless Industries Peerless Chrome...
No water pressure in bath tub after turning off hot water heater
It could be back flowing into the hot water heater tank which is not full because of the leak. Even though the valve is closed on the cold water entry side, there is probably no valve on the exit side. That is how it is returning to the tank.
Sep 14, 2009 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
Bradford White Water Heater Model: M165R6DS13
Immediately turn off power to heater. One of two things has happened. Either: A. The electrical contacts in one of the thermostats has welded together, necessitating replacement of the thermostat(s). (in this case I would recommend replacing both upper and lower thermos) or B. The lower element has burnt through, and because there is 120 volts to the lower element at all times (it normally only heats when the thermos complete the circuit to give it a path to the other "hot", putting a full 240 volts on it) a section of the element will continue to heat up to the point where the break allows the current to complete it's path to neutral ground via the water in the tank. It can continue to heat until the high limit safety thermo trips out. (the red reset button on the upper thermostat)
If either condition exists, the high limit safety thermo should trip out power to the heater before boiling water, and thus steam, is produced. Even if the safety thermo should fail to cut power, the pressure / temperature relief valve should open, releasing excessive pressure. If that should also fail to open, due to corrosion or such, the water heater will create steam and can actually result in explosion, and possible injury or death!
Several years ago I came across one that was boiling and when I turned on a hot water faucet to relieve the pressure it filled the entire basement with steam. (I still shutter to think if I didn't catch that fast enough I or someone else could have been killed)
The most likely cause of your extra hot water is actually the lower element. After you turn off power to the heater, turn off the water supply to the heater, open a hot water faucet to allow air to enter the tank and drain the tank. Remove the lower element. A bad element is usually visually apparent. If it looks good, you would have to test it with an ohm meter. (should be about 20 ohms if it is good) Install new element, turn on water and fill until water flows steadily from the hot water faucet you left open. Now you can turn the faucet off and turn power back on to heater.
Feb 14, 2009 | LG (LRBC22522ST) Stainless Steel
Grundfos Comfort System Recirculator  595916 Logo
235 people viewed this question
Top Grundfos Hardware & Accessories Experts
Gene Haynes
Mike Magnay
Mike Magnay
Are you a Grundfos Hardware and Accessory Expert? Answer questions, earn points and help others
