Question about Insignia NS-PDVD8 Portable DVD Player
ITS PLUGED INTO AN AC WALL UNIT. TURN IT ON AND AN EMPTY BATTERY FLASHES WITH THE WORD CLOSE AND IT GOES OFF. WHY IS IT SHOWING AN EMPTY BATTERY WHEN IT'S USING AC?
  • Insignia Master
  • 6,694 Answers
if u are using an adapter( power supply) then it have some problem. just replace the power supply the problem will solve. now the the dvd is attempting to work on battery because it did't get power from its AC power supply.
ok
Posted on Dec 30, 2010
My garage door starts down then goes back and the motor light flashes 10 times. The owner's manual only refers up to 6 flashes.
Richard, what is the make of your GD Opener unit? However, make sure the antena wire on the unit is turned up. 2. sometimes direct sun on the sensors prevent operation from the remote. 3.adjust sensors on both sides making sure the green or red lights are on.4. check the remote battery ensuring red light works when you press the remote button. 5. finally, has on vacation switch on the unit has not been switched on. GL
Dec 01, 2014 | Building Materials
What does ac bat mean on my panel?
AC is your main power it goes to a transformer that gets pluged in
Bat is your battery power 2 wires going down to your battery
Jan 17, 2013 | Honeywell Ademco Lynxr-i Lynxren-6...
I pluged my DCR-SR47 vCam on my pc then it wont turn on i thought that it just have an empty battery but after i charge it i still cant turn it on only the red flash below the battery is blinking
  • try the following.
  • remove the battery and connect the AC adapter
  • Turn on the camcorder (without battery)
  • If the camera turn on, maybe you need replace the battery (lifetime one year)
  • Place the battery sliding it in the direction of the arrow
  • Connect the AC adapter in Jack (camcorder)
  • The Led Charger "CHG" lamp lights up. When the battery is charged, the light turn off.
  • I hope the information will be helpful.
    Is importan to people who share knowledge hear your comments or received rate points.
    Sep 17, 2011 | Cameras
    My hp 6735s laptop battery not charging says pluged in but not charging only 1 year 6month old
    r u getting the message when on AC power that the "smart AC adapter is not providing enough power" ?? If yes then remove the battery and c if the laptop works fine with just the adapter plugged in ...
    if yes then take power cord out of the adapter from the end that goes to the wall socket .. that side is removeable ..then plug it back in and flip the way its plugged into the wall socket .. c if this helps ..
    Oct 22, 2010 | HP Computers & Internet
    Acer aspire 5315 batt problem
    Please run this unit on A/C only and see if it powers up like that. If it does not, then the A/C adapter is faulty and thus cannot charge your battery.
    Service the battery by hitting it flat onto your hand palm or onto the back of your shoe and retry to see if it is charging.
    May 25, 2010 | Acer Aspire 5315 Notebook
    Kidde smoke detector without a door or tab for back up battery - where do I find the battery so I can change it. It has been beeping for close to 39 hours. Installer did not leave a users manual. (The...
    Some smoke detectors are AC-only, so there is no battery. Dual-power units typically have the battery compartment on the back of the unit, where it attaches to the wall or ceiling.
    Most units must be removed from their mounting bracket to change the battery, as the battery cover is on the back.
    You rotate the unit about 1/2 turn counter clockwise, and it should come off the wall/ceiling. If it has an AC power connection, you unplug that so you can change the battery more easily.
    Oct 16, 2009 | Home Security
    Wont charge while powered on or run on ac power
    Sounds like a lose or burnt charge terminal.  Fixing would require disassembling the laptop and resoldering the loose or broken connections.  You might want to try a different AC adapter first.
    Apr 21, 2009 | Toshiba Satellite A75-S211 Notebook
    No battery status Garmin 760
    Went to Best Buy and they didn't know how to get the bar up either but said that the unit should be charged in 3 to 4 hours. So, when i unplugged the unit from the wall...the battery status showed up. I guess it doesn't show when the unit is plugged into the AC charger. Now, all is well.
    Jan 17, 2009 | Garmin Nuvi 760 Handheld GPS Receiver
    Gigabeat Will Not Turn On - Battery Flashes Then Goes Dead
    have you only been charging it with the usb cable?
    try plugging it into a ac adaptor, (make sure the button is in the off position at the bottom)
    and it should hopefully restart, then turn it to the on when it's loaded, and leave it plugged in till it's completely charged
    that might work
    Feb 26, 2008 | Toshiba gigabeat S MP3 Player
    I called and they told me,i have the same problem, to just turn the battery switch ( bottom thing) off and charge it over night via wall outlet. hope it helps im trying it as i type so i wouldn't know...
    Jul 29, 2007 | Toshiba gigabeat S MP3 Player
    Insignia NS-PDVD8 Portable DVD Player Logo
    Top Insignia Televison & Video Experts
    Jaime Hernandez
    Are you an Insignia Televison and Video Expert? Answer questions, earn points and help others
