Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
Tv looks like its in 3d in red blue green and wont go to converge option
    Genius:
  • 1,030 Answers
Http://www.fixya.com/support/r1062030-fl231_problem_convergence_not_in sounds like the fl231 fuse problem. read this to determine if you do.... let me know if this helps. very common and inexpensive to fix
Posted on Dec 30, 2010
Red green and blue colors do not overlap. Looks like a 3d movie without the glasses
Projection TV's sometimes need a "Convergence" adjustment. If you do not have the manual and/or cannot find the option in your TV menu, here is a link to help. Follow up and confirm this was your problem.
http://www.ehow.com/how_2034880_perform-convergence--tv.html
Jun 30, 2010 | Televison & Video
Blue will not focus causing "shadows". Magic focus will not solve the problem.
This tv have a problems call convergence,it dead.The tv convergence board the 2 STK convergence ICS and some or all it resistors are dead.These parts must be replaced to solved convergence problems.The shop will cost u $300-350 for parts and labors.
Jun 17, 2010 | Hitachi 53FDX20B 53" Rear Projection...
Red, green, and blue lines at bottom of screen, mirror looking effect, also looks like 3D. Got at a garage sale so no manual.
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the settings menu then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move RED and BLUE in all directions - up, down, left, and right. And you should be able to get the grid straight.
If you can't move them in all directions or cant move them far enough your convergence chips are bad and should be replaced. This is a common problem.
Note: If you TV has as flash focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a fix
69189a5.pngCONVERGENCE SOLUTION
You can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jan 03, 2010 | Hitachi 43F300 43" Rear Projection...
The picture looks 3D
  • Screen looks 3D
Oct 03, 2009 | RCA HD52W56 52" Rear Projection HDTV
My rca r52wm24 HD/TV monitior,is having ploblems with the picture, last night all of the suden the picture looks like a 3d movie with out the glasse, what is the problem
the problem is called convergence.this model was made with 2 options for convergence.first go into menu of tv,find convergence.if it has auto convergence activate it,IMPORTANT dont do any thing until its done(it will reach 100%,you can see it on the screen.the 2nd option is manual convergence,in that case you have to adjust the red onto the green then blue onto the green,DO NOT MOVE THE GREEN.both red/blue will move up and down,left and right.
Sep 24, 2009 | RCA R52WM24 52" HDTV Projection Television
Pictures look like they are in 3D
it sounds like your convergence is off.
you have Red, Greed & Blue projection guns
through your menu's you will find adjustments for them ...
set your green first then align then red and then blue to the green..
when making this adjustment the tv should put up a caliration signal called a crosshatch
a matrix of H and V lines to align
Apr 15, 2009 | RCA HD52W56 52" Rear Projection HDTV
Rca 52in rear projection hdtv red, blue, and green lines n double
tHIS is a convergence problem.. first question if you go into the customer setup menu. is the convergence option listed? If you have not got that option i suggest you read "the fl231 problem in the tips and trick section of this website. this can be a simple inexpensive repair..if you do have the convergence option then it can be one of three diffrent boards convergence power, convergence amp or small signal board. and will need further trouble shooting
Apr 04, 2009 | RCA Televison & Video
3D TV Blues, Greens, Red and a little yellow. RCA Modle # R52WH74
This is called convergence board failure. try to re calibrate the convergence. if the re calibration fails, this means your convergence board will need to be replaced or, rebuilt.
Feb 13, 2009 | RCA R52WH73 Projection Television
RED GREEN BLUE CONVERGENCE IS OUT.
if you have a rca hd56w66 chasis itc222 you may have the common fl231 fuse problem. I see this everday at the shop. to determine if you may have this problem. i have written a little article on this subject. Consult tips and tricks section under my profile. Going into maintence mode might have reset some settings.
Nov 24, 2008 | RCA HD56W66 56" HDTV
Convergence problem???
you must move red and blue lines into the green. change red to blue by useing the select button on the remote. till all convergance lines are white
Jan 12, 2008 | JVC AV-48WP30 48" Rear Projection...
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
37 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
