Question about Sirius Satellite Radio Sirius Sportster SP-TK1 Satellite Radio Receiver
The sportster will loose power / disconnect with no warning. i am able to get t to turn back on by shaking the entire unit. I had the sportster removed and installed it in a car unit at a best by and the unit worked fine
    Scholar:
  • 149 Answers
Get a new dock if you think its the dock. If that doesn't fix it, then your dock connector has a broken solder joint from years of wear and tear. It's common, and a very easy repair. Just resolder the connector to the board.
Posted on Dec 30, 2010
How to reset warning light on ford transit connect
Disconnect the battery and leave for about ten minutes, let the entire system drain of power, no harm to leave lights on while the battery is disconnected. Turn off lights, reconnect the battery and the system should be reset.
Feb 11, 2015 | Ford Transit Connect Cars & Trucks
Disconnected the baseboard heater - turned power back on - no power
If the breaker (you mean from the main board?) is turning off there is a line fault or short somewhere. If the breaker is not kicked off then there is a loose connection or maybe a small blown fuse in the base board heater unit itself.
Feb 17, 2014 | Heating & Cooling
Electrolux z380 steam cleaner issue
Try this:
1. empty the cleaner.
2. pour some vinegar after DISCONNECTING POWER. Shake the unit for a few minutes and now empty the cleaner and watch what comes out as you shake out vinegar.
3. pour water into the unit upto suggested level and power up after closing the top lid securely.
4. wait until the indicator light turns off (if you have one).
5. press button to see if steam comes out.
warning: Never open the top cap while the unit is powered. you may get burnt badly.
good luck
Jan 26, 2014 | Kitchen Ranges
My washer shows me the F 11 message and it won't start up right away I pushed the start botton then wait and it will start back up but it will spin then it will show me that F 11 message again. Also it...
The shaking probably shook a harness connection loose.
F11 Serial communication error
Communication between the Central Control Unit (CCU) and the
Motor Control Unit (MCU) cannot be sent correctly.
Possible causes/procedure:
1. Unplug washer or disconnect power.
2. Check wire harness connections to the MCU, the motor, and
Central Control Unit (CCU).
3. Check the drive system for any worn or failed components.
4. Plug in washer or reconnect power.
5. Verify CCU operation by running a Diagnostic test or any
cycle.
6. Check the MCU by looking for operations of the drive motor.
7. Check the drive motor for powered rotations.
8. Check that the serial harness at the MCU is not mounted
upside down. The wires should be to the left when facing the
MCU connectors. Your tech sheet is in the bottom behind the service panel.
How to get into the machine
Dec 28, 2010 | Kenmore Front Load Washer
How to replace motherboard
1. Contact eMachines, and purchase an identical replacement motherboard.
2. Disconnect all the exterior cables from your computer (keyboard, power, mouse, et cetera).
3. Remove the side-panels.
4. Disconnect all the interior cables from your motherboard (power, data, audio, et cetera).
5. Unscrew any screws holding add-in cards (modem, video) in-place.
6. Disconnect those add-in cards from the motherboard.
7. Unscrew the mounting-screws that hold the motherboard to the case.
8. Lift out the motherboard.
9. Take the RAM out of the old motherboard.
10. Take the heat-sink-CPU-fan and CPU off the old motherboard.
11. Put the CPU and RAM onto the new motherboard.
12. Reverse the above steps, to reassemble.
Jul 17, 2010 | E-Machines eMachines Desktop PC
FO error message. Oven light stuck on. No buttons work.
The F0 is a Function Key Stuck error - Replace touch pad or touch pad and control board if it is one assembly. Refer to F1 Test for more information.
How To Perform A F1 Touch Pad / ERC Test
This test is easy to perform and will help you determine whether the Electronic Range Control (ERC, control board) or touch pad is defective when the F1 code is displayed.
Note: With some models, the ERC and the touch pad are one single unit and therefore this test is not necessary. The entire assembly must be replaced.
Warning: If you have any doubts in your ability or safety of the repair, please contact a qualified appliance repair technician.
1. Disconnect the power to the range by either unplugging the power cord, or turning the power off at the circuit breaker. Always make sure the power as been disconnected properly before beginning this test.
2. Access the control panel.
3. Disconnect the touch pad ribbon from the ERC.
4. Reassemble the control panel. Make sure to check for any additional defects such as frayed or lose wires that could be causing the problem.
5. Turn the power back on.
6. Wait up to an hour for the F1 code to reappear. This could be accompanied by an alert such as a beeping sound.
7. If the F1 code reappears, replace the ERC. If it does not, replace the touch pad.
Nov 06, 2009 | GE Monogram ZET3058SHSS Stainless Steel...
I am replacing the lower oven baking element. After pulling the defective one out, I find no female receiver for the male connection tabs on the element. Are they loose wired? I am used to just plugging...
They probably are loose wired unless you see a porcelain receiver for them... it is CHEAPER so they do it! Maintainability? None !!!
With power disconnected, you MIGHT be able to "fish" the leads back out and attach before mounting the element.
Oct 17, 2009 | Viking VEDO205 Electric Double Oven
Presario v2000 display problems
there is someting loose inside the computer so you may have to open it and check for loose conections or pices that they may be loose or video conectors
Jan 05, 2008 | HP Compaq Presario V2000 Notebook
Sportster back light problem
I had the same issue with my Sportster Replay SR2. The backlight was usually out, but would flicker on, especially when I would apply pressure to the back.
The unit only has two screws at the bottom, which I removed. I couldn't seem to remove the back cover and was afraid I might break it, so I snugly put the screws back in and decided to give up until I could find some more information on how to remove the back.
Voila! After putting the unit back into its cradle in my car, the back light worked! I believe that the screws had simply loosened over time, and the connections for the backlight simply were not making contact.
I'm not sure how long this fix will last, but so far so good. So before doing any soldering or monkeying with the connections, just try tightening the screws first to see if it fixes the problem as it did for me.
Nov 17, 2007 | Sirius Sportster 4 SP4-TK1 Satellite Radio...
Dlp tv will not "fire up"
if your tv is on warranty take it back to the supplier.the problem with your tv is in the power supply there is a open regulator in that circuit along with the H .O. Transistor there is a black that feeds from the HOT to the flyback which also needs to check probably it is also open.good luck my friend
May 06, 2007 | Samsung DLP HL-P5663W 56" TV
Sirius Satellite Radio Sirius Sportster SP-TK1 Satellite Radio Receiver Logo
256 people viewed this question
Top Sirius Satellite Radio Audio Players & Recorders Experts
John
John
Colin Stickland
Colin Stickland
Tom Chichester
Are you a Sirius Satellite Radio Audio Player and Recorder Expert? Answer questions, earn points and help others
