Question about Philips HTS3410D/37 700W DVD Home Theater System System
My Philips HTS3544/37 does not power up on the first attempt after a complete shut off. The only way to get it to power up is to unplug it from the power source, wait a few seconds and plug it back in. However, it usually takes 2-3 cycles to get it to stay powered up. Once it is powered up and a movie is loaded, it is fine. Please advise.
SOURCE: Powers off by itself.
Has anyone gotten a resolution for this the only answer I saw was the SSB Board. Is there a cheap place to get parts. Philips model 50P8341 goes off by itself also wont come back on if you unplug it for a while it will come back on.
Posted on Nov 04, 2006
Raveler
  • 36 Answers
SOURCE: philips model#HTS3544/37
According to the manual, there is not a dedicated ear-phone jack on the unit. However, it does have an analog audio-out jack in the back which could be connected to a y-cable adapter, and then connected to headphones with a built-in volume control.
Posted on Dec 31, 2007
SOURCE: Turn on power, but no picture, when you turn off power see picture for a few seconds before tv shuts off
Even, I have the same problem...looking for a help on internet but not finding any...if you know...please post on this site.
Thanks,
Posted on Jan 13, 2008
  • 36 Answers
SOURCE: Power Up Problem
You have a 8.6v supply error according to the 7 error code being displayed, what you can try is when the set goes to blinking disconnect the Y sustain board (if looking at the tv from the back the board on the left) from the upper left side of the power supply, if the error code stops then you know your Y sustain board is pulling down your power supply and causing the error, if the error code continues you have a probelm with your Logic Board (located under your Small Signal Board) disconnect this from the Y sustain board and see if the error code stops if it does you know that the Logic board is bad, if the error code is still blinking then the 8.6v supply line from the Power supply is faulty and the Power Supply needs to be replaced
Posted on Aug 13, 2008
  • 3 Answers
SOURCE: Not booting
When the unit remains at the booting menu it is normally a sign that your Hard drive has failed. The hard drive in the wacs700 seems to run extremely hot, probably due to it's encaged location and poor airflow. It is possible to replace the drive yourself but it is fiddly.
You could send the unit back under warranty or get it repaired.
I charge £50 + cost of the HDD + postage to repair the fault.
No fix = no fee but you will need to pay for return postage. I only replace faulty Hard Drives and don't carry out other fault finding repairs. HDD Choices up to 300GB.
Robsony@btinternet.com
Posted on Aug 28, 2008
My WD 57733 will attempt to power up (almost like a whistling sound as it attempt to power up) then will power back down.
When was the last time you replaced the lamp? That sort of sounds like the ballast is unhappy with a bad lamp. The 57733 is a good TV. The other possibility is a stuck/dirty color wheel.
Check the lamp and see if it looks worn out(dark or grey in the tube down the center). Also make sure its either a Philips brand or Osram brand.
Let me know and Ill see what I can recommend next
Sep 12, 2016 | Mitsubishi WD-57733 57" HDTV
Unit powers up, then off 3 times before completely shutting down. At that time, the unit has to be unplugged from wall to try another time,
I have the same problem with my unit. It started today so I went and unplugged all wires(inputs and outputs) going to the unit. I plugged the receiver in and still the same results. Was there an answer to this question.
Apr 30, 2014 | Yamaha Rx-v565 Receiver
How do you clear memory - its telling me its full but I have no message saying cartridges need replacing
Issue: ERROR LCD: MEMORY FULL
Solution: Press ON/OFF switch to reset the multifunction device
Reset the device when it is not functioning properly. If the device is not functioning properly or to clear memory, reset it. important.gif Important: If resetting the printer's power does not clear the error or return the machine to a functioning state, it may be necessary to attempt a service reset. for instructions to attempt a service reset.
  1. On the operator panel, press and hold the <ON/OFF> button for one second. (The display will go blank.)
    Note: It may be necessary to unplug the power cord if pressing the ON/OFF button does not shut off the printer.
  2. Wait approximately ten seconds and then press the <ON/OFF> button again.
  3. Wait until the device has completed its cycling process before submitting another job request.
Service Reset:
  1. On the operator panel, press and hold the <ON/OFF> button for one second to power off the printer. (The display will go blank.)
  2. Confirm the printer is not on and then unplug the power cord from the back of the printer.
    If the power cord was disconnected (as stated in step 1) in order to shut off the printer, go to step 3.
  3. Press the <ON/OFF> button repeatedly five times.
  4. Re-connect the power cord.
  5. Press the <ON/OFF> button to power the printer back on.
  6. Wait until the device has completed its cycling process before submitting another job request.
Aug 29, 2011 | Canon PIXMA MX310 All-In-One Printer
Canon mx310 error message 5b00
  1. On the operator panel, press and hold the button for one second. (The display will go blank.)
  2. Wait approximately ten seconds and then press the button again.
Service Reset:
  1. On the operator panel, press and hold the button for one second to power off the printer. (The display will go blank.)
  3. Press the button repeatedly five times.
  5. Press the button to power the printer back on.
    • This procedure will not resolve a physical hardware issue.
      For example, a paper clip is wedged between the paper feed rollers or gears; or, the scanner assembly is detached from the inside housing.
    • This procedure will not resolve all service errors or LCD related anomalies.
      Service errors appear as four characters (a combination of alpha and numeric codes).
Aug 27, 2011 | Canon PIXMA MX310 All-In-One Printer
I ran the battery on my MP3 player completely down and it shut off. I charged it and now all the songs are gone... is there a way to recover the lost songs?
Try this:
1)Perform a system reset, which won't erase your files, to attempt to correct playback. Locate a thin object, such as pen tip or unfolded paper clip and insert it into the small reset hole on the bottom of your GoGear. Hold the thin object in place until you see the unit shut down completely. Your system has been reset. Power the device back on to see if the corrupted files have been corrected. If the reset failed to correct the issue, perform a file recovery on your GoGear.
2)Initiate a file recovery by first connecting your GoGear to your computer. From your computer's "Start" menu, choose "Programs," "Philips Digital Audio Player," "Area Device Manager" and "Philips Device Manager." The Philips Device Manager software will be activated. Inspect your GoGear to confirm that it is turned off. Plug the small end of the supplied USB cord into the bottom of your GoGear while holding down the "Volume Up." Insert the larger end into a free USB port on your computer. Hold the key as the "Philips Device Manager" reads your GoGear and activates recovery mode. Click "Repair" and follow the onscreen prompts as given by the "Philips Device Manager" to complete the process of memory recovery. Disconnect your GoGear from your computer properly after the process is complete and restart your MP3 player.
3)Reload and replace the files onto your GoGear by first connecting your GoGear to your computer. Plug the supplied USB cord's small end into the bottom of your GoGear and the large end into your comptuer's USB port. Initiate Windows Media Player by clicking on its icon if it doesn't start upon connection with your GoGear. In the left pane of the WMP, click "Philips GoGear Aria." Click the arrow on the top left edge of the WMP window, followed by "Music." Highlight all files, and click "Delete." Click the "Sync" tab on WMP, and drag and drop the music files you would like to replace and reload into the "Sync List" panel. Click "Start Sync." The files will be freshly loaded onto your GoGear.
4)Properly disconnect your GoGear from your computer to avoid memory corruption by first closing all applications in use by the GoGear (WMP). Click the USB device icon in your system's tray (located on the bottom right corner of your screen). Follow the prompts in order to safely remove your GoGear from your computer. When your computer tells you it's safe to remove your GoGear, unplug the USB cord from your GoGear.
Hope this helps!
Apr 08, 2011 | Philips GoGear ViBE Digital Media Player
Hp 6910p laptop wont turn off. Fan running. what gives?
Something is keeping it from shutting down. This could be caused by a faulty application or driver. My suggestion is to hold the power button down until the unit completely shuts down. Take out the battery, unplug the ac-adapter, attempt to power it on and then put the battery back in. Attempt to restart the computer.
Good Luck!
Mar 29, 2011 | HP Compaq Business Notebook 6910p - laptop...
My Philips 20PT633 has started shutting off mid program.
Consult your technician there is a semiconductor problem inside your tv. Probably lose connection, and need to resolder.
Jun 08, 2009 | Philips 20PT633R 20" TV
It hangs on the first screen!
when i plug it in to charge it just stays on the philips welcome screen and just stayz like that wen i reset it does the same thing
Sep 10, 2008 | Philips GoGear Flash MP3 Player
Power cycles on/off without actually booting or starting
Unplug/replug try again. If fails, see if you are still under warranty with Philips.
Jun 17, 2008 | Philips DVDR3455H/37B
76 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
