Question about Dryers
Breaker popped, so went and turned it back on. Now there is no heat. What could be the problem?
    President:
  • 228 Answers
In your dryer behind the tumbler there are coils with insulators. up against the dryer wall their should be many holes that allow the heat to come into the tumbler. run your dryer about 3 minutes with settings on heat , then open the door and peer thru to the back while the tumbler is spinning. if you don't see part or full radiat heat. the heating coils will have to be replaced. you can purchase them from most appliance parts store. just make sure you provide the brand and model # and possibly the ser#. good luck!
Posted on Dec 30, 2010
I have a whirlpool rf368lxpb 1 range. When I turned on yesterday there was a pop sound. The light saying the burner comes on but the burners don't heat also I checked the oven same thing the heating...
Try shutting off the main breaker then turn it back on. This works then ok you would know that there could be a loose connection or bad breaker. Hope this helped
May 14, 2014 | Kitchen Ranges
Circuit braker keep popping
Sounds like the heating element has gone out again. Once you reset the circuit breaker and the tub turns on it will start to circulate the water. This usually runs like this for about 2 mins and then the tub will recognize it is cold and send power to the heater. If the element is back at that point it will blow the circuit breaker.
If this circuit breaker pops as soon as you turn it on then you most likely have a bad circuit board.
Rod
www.uspartscenter.com
Jan 30, 2013 | Jacuzzi Home
Last week when my wife turned on the oven a flash and popping noise happened and the circuit breaker popped. I ordered a new control board part number WB27T10229 and installed it. When I turn the circuit...
The broiler is a different element. Sounds like your main (bottom) element is out. Turn off breaker and remove. To test, use an ohm meter and ohm out the element. If yuor meter reads 0 or OL (open load) your element needs to be replaced.
May 19, 2011 | Kenmore 95882 / 95884 / 95889 Electric...
Only large flame comes out and fan does not start
Since this is a propane unit, do not turn it back on again without the fan working. First check to see if the unit has a pop out style breaker, reset it if popped. Check to see if you did not trip a breaker at the breaker box.
Dec 01, 2010 | Reddy Portable Forced Air Propane Heater...
Have Challenger Type C 2100 circuit breaker in residential home electrical panel. Manually turned to off position and now cannot turn back on. Pops back to off position. Also says HACR type and common trip...
First HACR is heating, air conditioning,refrigeration. So in other words you could use it on an electric furnace or air conditioning.
IS this the main breaker for the panel? or for and electric furnace. I'm assuming its for the furnace, perhaps back up heat for heat pump. See if there is another disconenct on the furnace, turn it off and see if the breaker resets. IF so you have a short or overload in the furnace.
If' it IS the main for the panel, turn off all the other breakers in the panel, and try to reset the breaker. If that works, turn the other breakers back on one at a time. IF it "POPS" then it is tripping. Don't keep resetting, find the problem.
Jul 19, 2010 | Challenger Connecticut Electric UBITB-A230...
After a "pop" - the oven no longer works
You should have thrown the breaker before moving the oven. The element likely shorted and blew the breaker. make sure the breaker is off. replace the element and plug it back in and reset the breaker.
Eric
Sep 22, 2009 | Ovens
Frigidaire ES400 range - oven will not opperate, range will
Me too. Oven was on, big "pop" and breaker went. After re-setting the breaker (and setting the clock on the range), the stove top works fine, and the controller for the oven seems fine, just that neither the top or bottm elements will heat up in the oven. 240 V is getting to the control module, but it is not sending out any juice to the oven elements.
Any fixes out there?
Mar 30, 2009 | Kitchen Ranges
Dryer won't turn on.....
Its possible that you blew out the thermal fuse on most dryers it is located on the blower wheel housing. You can test the part with an ohm meter, if has continuity its good if not it's bad.
Mar 18, 2009 | Kenmore 64722 Electric Dryer
Dryers Logo
80 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
