Question about Refrigerators
I also need to know what size my frige is now. It is a Kenmore model number 596.72289202
  • 10 Answers
SOURCE: kenmore frige model 59658692890 evap fan will not start
It won't run if unit is stuck in defrost.
Posted on Jan 25, 2008
  • 9 Answers
SOURCE: leaking water from kenmore freezer to refrig below
its possible that the drain pan behind the back freezer wall is clogged or coverd with ice, sounds like when unit goes into defrost melt water leaks under sides of drain pan and into fridge. unplug and remove back freezer wall if drain is covered with ice defrost the ice, can be prevented by loosely coiling a piece of solid copper wire around element and into drain slightly radiant heat during defrost should keep drain fromicing over. if drain is just clogged wth debris clean drain and you should be good to go, hope this helps you.
Posted on Mar 14, 2009
kram26
  • 544 Answers
SOURCE: My Kenmore fridge, Model 596-58692890
HI,
if the compressor is running your ref. should be getting cold. Their is a defrost timer but when it is in defrost the compressor shuts off. I think you do have a leak.
thanks,
Posted on Mar 24, 2009
  • 103 Answers
SOURCE: Moldy Ice from Ice Maker
Hi: Does it have a water filter? Sears parts is offline at the moment, so I can't tell. Most of the newer models do. The 596.xxx tells me that it was built in the Amana factory for Kenmore. Most likely there is a water filter in the top of the fresh food compartment. It has been growing mold in storage, and the lines too. It's on the upper right side, behind a housing with a tab to release it. Lower the housing and remove the water filter. Did you receive the bypass plug with the ref.? It looks like a large plastic wing nut with the same fitting as the water filter. If so put it in and flush the system with city water. Most city water has chlorine to clean your lines. If you install a new filter without flushing the lines it will remove the chlorine as it's supposed to do, but the lines from the filter wont get clean. If you don't have the plug, buy one. Flush the system and then install the filter. I hope this helps, Jeff
Posted on Jun 07, 2009
  • 20 Answers
SOURCE: Refrigerator Model 596-65232403 2 Yrs old
Ed, check your freezer gasket..it may be partially frozen or torn..RDS
Posted on Apr 23, 2010
When was Kenmore Model 1068628480 manufactured ?
Check the mfg. sticker inside the unit. Since appliances change often, the model number may not identify the year and size.
Jan 05, 2015 | Kenmore Refrigerators
Tip
Finding Your Model number on Older GE Refrigerator (Frige)
Finding Your Model number on Older GE Refrigerator <br /> <br /> If it is a side by side look in the frige side on the side walls near the bottom. <br /> <br /> Also check the bottom right side of the frige between the door and the base.
on Mar 23, 2011 | Refrigerators
Kenmore refigerator keepsgoing into defrost mode
Hi, If you changed relay, overload, & capacitor on the compressor and it still clicks on and off, the compressor has gone bad and will need replaced. Is this unit under five years old?
Vic
May 28, 2009 | Kenmore 56549 / 56542 / 56544 / 56546 Side...
What is the part number for the water filter for a Kenmore Coldspot refrigerator model 106.54209300?
The part number is 4392922 for the water filter. You can purchase this water filter at the below link for $ 34.49
http://www.freshwatersystems.com/p-3051-whirlpool-kitchenaid-deluxe-filter-4396510.aspx
FreshWaterSystems
1.877.335.3339
May 17, 2009 | Refrigerators
Fridge not cooling
Is there any frost buld up in freezer compartment?Is your freezer fan running?Need more info You may have a freezing issue you will need to leave doors open over night to make sure it is free of ice .Plug it in in the am and see if it works if it does then it froze up.And will need to replace part .Need more info to let you know what it may be Good luck:)
May 10, 2009 | Kenmore 60721 Refrigerator
A friend wants to know were the model number is and load size
Inside the lid will have the model # and capacity. If not - a tag right where the hoses connect is a likely spot.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Mar 29, 2009 | Kenmore Washing Machines
Leaking water from kenmore freezer to refrig below
Mar 14, 2009 | Kenmore Refrigerators
Kenmore dryer
The belt you will need for that unit is part # 341241. These belts will fit almost all Whirlpool and Kenmore models except for the DOTT (Dryer Of Tomorrow, Today) dryers. A DOTT dryer is a Kenmore model only, and has a front kick plate and the lint filter in the door.
Jan 27, 2008 | Dryers
Refrigerators Logo
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
