Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
I have this tv and the antenna wire got stepped on and broke, is there a solution wth going in and replacing the connector. I was thinking and adaptor fron antenna cable to rca connector? is thiis possible?
    Genius:
  • 1,030 Answers
Well yes and know...let me explain.at theshop this is a very common occurence that we see alot... this connector is atached to a thing called a tuner. the tunner is what the tv use to select the channel. withhout this you cant change channels what can be done is atach a vcr and then use the rca inputs.. you will have to change channels using vcr.some cable boxs do this also again chaning through the cable box. this can be repaired depending how much damage has been done our shop ussaly charged around 85 dollars to repair the connector.
Posted on Dec 30, 2010
HOW TO CONNECT ANTENNA TO MODEL # LDVD22-10A
You will need an antenna with a standard 'F' connector (Think Cable
wire end) Find the matching screw on 'F' terminal on back of tv & screw/push on (screw on type of connector is better). Then turn on the tv, go to TV input, & do an auto channel scan. It may take awhile. Be patient. After the scan is over, you should have SOME channels. I say that because Digital signals are the only ones available by antenna, & they ARE VERY SENSITIVE TO ANTENNA LOCATION & ORIENTATION. If you get no or few channels,l move the antenna & do auto scan again.
Samuel Morris
Camtek Of NY
Oct 13, 2014 | Televison & Video
Antenna connector broke from tv. Can I use another IN connector, or is it easy to fix?
if it is the aerial connector whats broke make sure there is nothing stuck in the back of the tv then simply replace tv plug you can buy them fo about 50 pence
Aug 29, 2013 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
WE DISCONNECT OUR SATELITE hOW DO WE GET REGULAR TV
You must have these first.
1. Aerial antenna - buy this at your local home depot. Any aerial antenna available will be fine. Please see the sample picture.
2. Antenna wire (RG-6 cable wire) - connect one end of this wire to your aerial antenna and then the other end to your tv.
3. RG-6 connector - other end of the cable wire must have a this connector to attached it securely to your TV.
Some Aerial antenna has a cable wire packaged, this is much better than to assemble #2 and #3.
After the connection had been done, go to the menu on the tv, scroll down to antenna connection and then press auto tunning to saved all the viewable channel in your area.
Let me know if you need further assistance.
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
Jdvillanueva
Jun 21, 2011 | Hisense LHD3204US 32 in. LCD HDTV
Hello, my 25" Magnovox (#mt2501c)
Tv fell off about 3 feets or more?Yes,turn on the tv see if u getting any power to the unit?Might have broken main PCB board too.If unit still have power,check see if tv get statics screen have colors shaded in red or mutiples colors,mean the tv CRT(tv tube) yoke is dead and damages scrambles radiation.Or the tv getting power but have high pitch sqeeling noises or rattles noises,tv have the CRT-(tv tube) is crack by the neck or broken totally.CRT have damages problems or dead tv is worthless,beacause of CRT(tv tube) is dead,not fixable even that antena connector input is replaced.
Feb 17, 2011 | Philips Magnavox MT2501C 25" TV
I was removing the antenna, and it broke off. Do
Depending on if your car has a power antenna or not, you may have to replace the whole unit.
The good news is, no, you usually don't have to replace the wires on most GM vehicles. Open your trunk, remove the insulating carpet from the side of the trunk where your antenna is located , to expose the power antenna unit.
This is a stock photo of what the power antenna unit and kit looks likes.
Unplug the electrical connector from the antenna . Unscrew the plastic ring on the outside of the car, where the antenna rest on the body of the vehicle. Pull the antenna unit inside through the hole to remove.
You can usually get a new one for about $89 bucks at Autozone.
Installation is the reverse of remove. Make sure the ignition key is completely off when performing the replacement. Follow all installation instruction on the package. Improper installation could cause rain to leak in your antenna during bad weather and not be water tight.
May 25, 2010 | 1995 Chevrolet Camaro
No signal on samsung 40"lcd tv
IF it is an ATSC tuner ,newer type ,( digital tuner) it needs better antenna, most importantly Check the cable from Antenna to the connector. using multimeter , put on resistance ,any, anc check both ends of the cable, when there is no change on the multimeter consider the wire is broke somewhere. Make sure the antenna is pointing towards the tv station. also check www.antennaweb.org i think to see the DTV channels in your area. GL
Apr 08, 2010 | Televison & Video
1998 buick park ave. rear window defroster not working. fuse is good, has anyone replaced the black box located next to rear window where element plugs into along with the antenna. element on window is not...
Rear Defogger Inoperative, But Heated Mirrors Operate Correctly
1. Connect scan tool. Turn ignition switch to RUN position. Turn rear defogger on. Using scan tool, display BCM
outputs. If rear defogger is being requested on, go to next step. If rear defogger is not being requested on, go to
step 10).
2. Ensure ignition switch is in RUN position. Remove rear defogger relay from rear junction block, located on center
right rear of passenger compartment, under rear seat. Connect test light between ground and defogger relay
harness connector terminal F3 (Brown wire). If test light illuminates, go to next step. If test light does not
illuminate, go to step 11).
3. Connect test light between ground and defogger relay harness connector terminal A2 (Red wire). If test light
illuminates, go to next step. If test light does not illuminate, go to step 12).
4. Connect test light between defogger relay harness connector terminals A2 (Red wire) and B3 (Purple wire). If test
light illuminates, go to step 13). If light does not illuminate, go to next step.
5. Disconnect rear defogger positive and negative feed bus connectors. Connect a jumper wire between defogger
relay harness connector terminals F3 (Brown wire) and A4 (White wire). Connect test light between ground and
positive feed bus connector terminal "A" (Black wire). If test light illuminates, go to next step. If test light does not
illuminate, go to step 8).
6. Connect test light between positive feed bus connector terminal "A" (Black wire) and negative feed bus connector
terminal "B" (Black wire). If test light illuminates, go to next step. If test light does not illuminate, go to step 9).
7. Repair open in Black wire between rear defogger and ground. Recheck system operation.
8. Repair open in Purple wire between rear junction block and heated backlight antenna module. Recheck system
operation.
9. Check for proper terminal contact at rear defogger connectors. Repair as necessary. Recheck system operation.
10. Check for proper terminal contact at BCM. If terminal contact is okay, replace BCM. Recheck system operation.
11. Repair open in Brown wire between rear junction block and instrument panel junction block. Recheck system
operation.
12. Repair open in Red wire between rear junction block and underhood junction block (located in right front corner of
engine compartment, between battery and strut tower). Recheck system operation.
13. Connect test light between defogger relay harness connector terminals F3 (Brown wire) and A4 (White wire). If
test light illuminates, go to next step. If test light does not illuminate, go to step 16).
14. Reinstall defogger relay. Disconnect BCM 32-pin Pink connector C2. BCM is located behind right side of instrument
panel, near rear of glove box. Using DVOM, check voltage between ground and BCM harness connector C2
terminal A3 (White wire). If any voltage is present, go to next step. If no voltage is present, go to step 17).
15. Repair open or short to ground in White wire between rear junction block and BCM. Recheck system operation.
16. Check for poor connection at defogger relay terminals. If connections are okay, replace defogger relay. Recheck
system operation.
17. Check for proper terminal contact at BCM. If terminal contact is okay, replace BCM. Recheck system operation.
Feb 25, 2010 | 1998 Buick Park Avenue
Broken Antenna wire
Oh, I get it now. That extra Sony one should work fine. Does this mean you got it working or are you still looking for a replacement? You can most likely find these on ebay by themselves or as part of a laptop wireless assembly.
Jul 01, 2008 | Zhone (6218-I2-200) Router
Paperclip broke off in my antenna jack of my TV
You could try a small, powerful magnet. You can get a magnet that is on a telescoping pole at some hardware stores - they're used to pick up dropped screws, and things like that. Something like this: http://www2.northerntool.com/product/200314334.htm
That might be strong enough to pull it out. As far as dismantling the connector - it's not really something you can take apart, or at least not something you can put back together afterwards. At best, you could open up the case, remove the connector and solder on a replacement connector. I think your best bet is the magnet pick-up tool.
-Dyllan
Jan 07, 2008 | Sanyo DS27800 27" TV
Antenna hookup broke off
You have to re solder the connector. The other solution is to patch from the Direct TV box AV out to the AV input on the back of the TV. This will bypass the tuner and give you a cleaner picture. However, if your TV does not have an external input you must re solder the connector. As easy as it may seem, this should be done by a qualified technician. Its not as easy as it looks and requires good soldering skills.
Nov 12, 2007 | RCA F19207BC TV
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
115 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
