Question about Denon AVR-1082 Receiver
What inputs on the Denon AVR 1500 do I use for connecting a turntable
    Brigadier General:
  • 8,546 Answers
If the turntable is old-school (not self-preamplified) just connect it to PHONO.
If the TT is self-preamplified use any available Line Level input, like AUX.
Posted on Dec 30, 2010
How do I connect a turntable to a Denon AVR 485.
If there is not a PHONO input, you may be out of luck.
Dec 21, 2014 | Denon AVR-485 Receiver
How can I connect my I pod Touch to my Denon AVR 1803 reveiver?
Connect the 3.5mm cable to the iPod headphone output and the two RCA plugs into any unused analogue audio input on the Denon AVR 1803. Then choose the appropriate input on the Denon, press play and enjoy the music. Be careful about volume. Start with the volume on the iPad low and adjust to suit.
Cheers, Don.
Aug 07, 2014 | Denon AVR-1803 Receiver
Turntable
is the turntable a new one if so there is a setting on it for pre amp or computer connection. if its an old school turntable it should work fine.
Apr 11, 2014 | Denon AVR-1803 Receiver
Do I need an external amp for my turntable if I have the Denon AVR-3801 receiver?
If you do not have the proper phono inputs, "built in preamp" you will need a external amp, since most receivers and amps have done away with this, the signal from the turntable is very weak and not enough on it's own.
Mar 03, 2012 | Denon Audio Players & Recorders
I have a Pioneer PL-S50 turntable that I want to connect
hi you need a Phono Input Attenuator Line Adapter
the above link is for one on ebay but they are also available through radio shack
Jan 06, 2010 | Denon AVR-689 Receiver
How do I hook up a turntable
You may have two possibilities depending on the configuration of the turntable.
Your Denon should have inputs marked for 'Aux,' 'Line' and possibly, if it is built with the expectation of use with a turntable, 'Mag' or 'Magnetic.'
Your turntable may have a 'Line' output or only a shielded cable carrying a very small voltage from the magnetic head. I assume the pickup is magnetic and not crystal which has a much higher output level but also a higher impedance that requires a matching input.
You should have any of the above outputs in pairs and if the color coding conforms to current standards, there should be in- and outputs marked with red (right channel) and white (left channel).
I would first try connecting the turntable's leads to the 'Line' input since most later turntables have a small amplifier circuit built in that will take the signal from the pickup, amplify it, and match it to the levels and impedance of the line input on the Denon.
There isn't any danger of making a fatal mistake and you should hear right away if there is excessive distortion or a loudness even when the level is set to a low setting; this implies that the output from the turntable is higher than that input wants to see.
Oct 03, 2009 | Denon AVR-1907 Receiver
I have a Denon AVR-1500 Reciever and I would like to connect my iPod to see if I can drive my home speakers from my iPod, the aux jacks and other choices of input jacks do not seem to accept the formatted...
How are you trying to connect your ipod to the Denon? i.e. What connector, or cables are you trying to use?
If nothing else work, you could try and use the headphone output of the ipod to connect to your receiver. ( Cable required would be stere pin to RCA stereo out). The volume control of the ipod will then become the gain control.
Mar 08, 2009 | Denon AVR-1082 Receiver
Vinyl on Turntable sounds thin and trebley through Denon AVR-1603
You will need an adapter amp which converts the tiny tiny signal from a magnetic phono cartridge up to the line level that you need to feed into your AUX input jacks. They cost about $20 to $30 dollars and can be found at Radio Shack. Unless of course you have a phono input jack on the back of your Denon unit. Good luck.
Nov 26, 2008 | Denon AVR-1603 Receiver
Output from Denon D-700?
Hi ...
If there's a tape monitor in/out on the D700,turn the tape monitor on and connect the "Play out" phono jacks on the 700 to the line-in on the computer. Spark up the turntable and you should be able to listen to the vinyl on the PC while recording.
Nov 21, 2008 | Denon AVR-1803 Receiver
What to use for Audio-out on Denon AVR-2807?
Hi Karmor
Use the Tape Out(rec) connections on the Denon. If that model has a rec out selector, then be sure to select phono as well. All sweet and ready to rip them files!!
regards
Graeme
Mar 15, 2008 | Denon AVR-2807 Receiver
Open Questions:
Denon AVR-1082 Receiver Logo
256 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
