Should I be getting a lot of water draining down the drain tube? I never used the unit until now and. It started pouring water out of it today. So I didn't know if that is normal for it to drain a lot of water once the heat turns off. I have been searching online and there really isn't much that tells you how to use the unit. I bought my house and it was already installed.
    Genius:
  • 1,267 Answers
Yes, you get a lot of water from the condensate that accumulates on the air handler finns. My house unit during the summer generates a gallon in two hours during the hot summer months. The water run off is dependent on the humidity.
Posted on Dec 30, 2010
Ice builds up under the pull out freezer drawer then melts allowing war we to flow onto the floor
It is most likely that the defrost drain is blocked in the freezer causing the water to drain through the air vents. You will most likely have to remove the rear panel in the freezer and pour hot water in the drain trough until the drain clears up and the water drains down the drain tube.
Aug 16, 2014 | Maytag MFD2560HES Bottom Freezer French...
My kenmore refrigeratot model 58087 has ice in the bottom of the freezer section. I assume this is from a clog somewhere in the automatic defrost lines. How do I get to these lines to clean them?
Unplug the unit! You have to remove the shelves and the rear panel of the freezer. I take two coffee cups filled with water heat them in the microwave for 2-3 minutes and keep pouring them on the ice until you see the drain, keep pouring the hot water at this point and let the hot water sit a little keep doing this until the water drains down if it doesn't drain down then you still have ice in the drain tube or you have a object in it so use compressed air if you can. Use a lot of bath towels to help with catching the water inside the unit while working in the freezer.
Sep 27, 2011 | Kenmore Side by Side Refrigerator
I have a Maytag fridge model # PSB2151GRW without the ice maker , there is a steady build up of ice on the bottom shelf of the freezer and a puddle of water on the floor ...
Ok so here comes the fun part. Unplug the frig! Two people due this much faster. Remove all food and shelves from freezer. Get ya some bath towels place them on the floor and some on the bottom of the freezer. Take 2 coffee cups and heat them for 3 minutes. Remove them and remember they are hot! Pour a cup of hot water where the ice is and let the towel soak up any water. Now fill that up and heat for 2 minutes now. Pour the other cup on the ice and keep rotating until the ice is gone you will see the drain hole which is going to have ice down that tube so keep pouring hot water until the water drains into the drain pan below. If you can't clear the drain tube use compressed air or a turkey baster can help out too. Wipe down the inside of freezer walls to eliminate the condensation now your ready to party... Don't forget to plug the unit back in the outlet!
Sep 26, 2011 | Refrigerators
Ice collects on bottom of freezer, and melts on the floor
Hello, Thank You for using FixYa. I will be helping you today.
You have a frozen drain. You need to remove the back panel in the freezer. Do not touch anything behind the panel and dont poke anything. You need to remove as much ice from the bottom as you can. Then use boiling water to pour in the bottom section under the evaparator,I would put a towel in the unit to help catch the water. Keep adding new hot boiling water until the drain clears up and the water starts to drain. It can take a while sometimes the whole tube will freeze. You can add a duckbill to the end of the drain hose behind the unit to help stop this from happening part number 8055306 Just push it on the end of the drain line.
Thank You and please rate my answer if it was helpful..
Jun 28, 2011 | Maytag Refrigerators
Water freezing on the bottom of freezer
You have a problem with your auto defrost system. The drain line that should take the defrost water down to the drain pan in plugged up.If you look inside the freezer way down at the bottom and back you should be able to see the drain trough and the start of the drain line. You need to defrost the trough and clean out the line. You can also move the refrig. out from the wall and try to get to the drain that way.I hope you find this helpful.
Jun 28, 2011 | Kenmore Side by Side Refrigerator
Water leak from freezer
Hello, Thank You for using FixYa. I will be helping you today.Sounds like you have a frozen drain.If there is ice on the bottom of the freezer. You need to remove the back panel in the freezer. Do not touch anything behind the panel and dont poke anything. You need to remove as much ice from the bottom as you can. Then use boiling water to pour in the bottom section under the evaparator,I would put a towel in the unit to help catch the water. Keep adding new hot boiling water until the drain clears up and the water starts to drain. It can take a while sometimes the whole tube will freeze. You can add a duckbill to the end of the drain hose behind the unit to help stop this from happening part number 8055306 Just push it on the end of the drain line.
Jun 20, 2011 | KitchenAid Refrigerators
I have a sheet of ice in the bottom of my freezer model # MSD2754GR. I break up the ice and a day later I have another shhe of ice. Any suggestions?
Jun 19, 2011 | Maytag Refrigerators
Ice is forming on bottom of freezer under basket Has been doing this for approximately 3 weeks Have checked water connection, appears OK Don't know what the problem is to attempt fixing it
The evaporator coils frost up in normal use and every eight hours or so the entire unit shuts down and the defrost heater comes on to melt the frost. This cycle last about 20 minutes. The melted frost drips into a drain pan and through a drain tube to the drain tray under the freezer/refrigerator where it's evaporated by the condenser fan.
Your drain tube may be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing it out with hot water and clorox may help.
Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the inside of the freezer at the bottom of the rear cover.
Jun 17, 2011 | Amana ABB2223DEQ Bottom Freezer...
Maytag side by side fridge has ice forming in bottom of freezer and leaking onto floor in front of freezer door
You have a frozen drain. You need to remove the back panel in the freezer. Do not touch anything behind the panel and don't poke anything. You need to remove as much ice from the bottom as you can. Then use boiling water to pour in the bottom section under the evaporator,I would put a towel in the unit to help catch the water. Keep adding new hot boiling water until the drain clears up and the water starts to drain. It can take a while sometimes the whole tube will freeze. You can add a duckbill to the end of the drain hose behind the unit to help stop this from happening part number
Jun 16, 2011 | Maytag MSD2756G Side by Side Refrigerator
Leaking water inside fridgerator
You need to manually defrost then let sit over night .Pour warm water down the drain hole if does not go down fast than you will need to clean drain tube out with wire start at the rear of the unit and there will be a drain tube going in the drip pan good luck :)
Sep 10, 2008 | Whirlpool ET1FHMXLQ / ET1FHMXLT Top...
Heating & Cooling Logo
67 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
