Question about Briggs Stratton IC Horizontal OHV Engine 305cc 1450 Series 145 Gross Torque 1in x 3 2132in Shaft Model 2053320537B1
Engine won't shut off from on off switch - Briggs Stratton IC Horizontal OHV Engine 305cc 1450 Series 145 Gross Torque 1in x 3 2132in Shaft Model 2053320537B1
    Genius:
  • 1,267 Answers
Sounds as if the ground lead has broken on the switch. The way these engines shut off is you ground the spark lead, thus depriving the plug of a spark to fire the cylinder.
Posted on Dec 30, 2010
Trying to locate fuel shut off switch
There is no fuel shut off switch on Oldsmobile or any other GM vehicle . When fueling the vehicle did you stop when the pump kicked off ? or did you continue to fill to top ? Flooded the charcoal canister an engine ! Is the check engine light coming on !
Jan 16, 2016 | 1999 Oldsmobile Intrigue
Troy Bilt GTX 18 lawn mower engine won't continue running
ck. to make sure the wire to the ignition coil is hot. may need to replace the ignition switch.
May 24, 2013 | Garden
Intrepid won't shut off
Use Diagnostic Unit, you will not find your fault any other way, (ie) fitting parts that you might think will work , is costly.
Oct 29, 2017 | 1997 Dodge Intrepid
Vanguard Briggs & Stratton won't shut down
Your kill wire from the switch to the coil is bad,disconnected or connections dirty...or switch is bad...try disconnecting the kill wire on the coil and using a jumper ground the coil directly to the engine or frame it should shut down if it does it is the wire or switch do the same at the switch if it shuts down it is the switch..if not the wire has a break..good luck..
Feb 04, 2012 | Briggs & Stratton Briggs Stratton Vanguard...
Engine won't shut down
Look on the back of the injector pump for a wire connection. If there is no wire there find it and reconnect it. If it is there, the ignition switch may not be stopping power to it.
Jul 28, 2017 | Cars & Trucks
Engine starts fine, runs fine for about 5-10 minutes of various speeds. Then it shuts down suddenly regardless what trottle possision. Engine will start right away again, but promblem will accure after few...
Could be so many things, I know on modern Harleys there is a shut off relay that turns off the engine if the bike is on its side. If that switch goes out, the motor won't run. Probably have to take it to the dealer.
Jul 08, 2011 | Honda Fusion Motorcycles
Front right side hit . replaced concerter and won't crank over /or start fuel pump doesn'd even come on when key is on ?
ricks63toy, I believe that Ford still uses what is called an inertia switch even in the hybrids. This switch will shut off in the event of an accident shutting off the fuel pump. This is a safety feature built into the vehicle. Seeing that this is a newer vehicle I trust that you still have the manual. If not, the switches are usually located in the trunk. Look on the side walls of the trunk and see if you can locate it. It is usually marked by a sticker. When you find the switch, push the red button down until you hear a click. This will reset the switch and allow power back to your fuel pump. Good luck with this.
May 17, 2011 | 2010 Ford Fusion Hybrid
Briggs Stratton IC Horizontal OHV Engine  305cc 1450 Series 145 Gross Torque 1in x 3 2132in Shaft Model 2053320537B1 Logo
78 people viewed this question
Top Briggs Plumbing Experts
John Trevino
Jim Parker
Jim Parker
Are you a Briggs Plumbing Expert? Answer questions, earn points and help others
