Question about Saws
Master craft mod #10114 table saw missing miter guage assembly for table, need replacemnet
Sell for scrap metal prices are good and your wife will be happy you got rid of it.
Posted on Jan 11, 2011
Makita LS 1000 miter bed does not turn freely; probably jammed up with saw dust. What is the best approach to cleaning the rotating bed?
PDF]TECHNICAL INFORMATION - Makita
www.makita.nl/images/files/onderdelen/nl/LS1020-TE.pdf MAKITA 255mm(10") Miter saw. Models No. Description. New Tool ... Optional accessories. The main specifications are common with #LS1000. Saw blade:.Missing: bed
Jul 22, 2015 | Makita Saws
I have a Pro-Tech table saw Model 4008 and neet a miter gauge assembly. The bar is 5/8ths. Any comparable replacements out there?
I tried all of my sources.
all I can suggest is try running an ad on Craigslist ... or search Pro-Tech there and see what pops up.I've seen them without rip fences , with bad motors etc. but otherwise complete for $30 ...
good luck.
Apr 08, 2013 | Saws
HOW DO I TILT SAW TO MITRE?
Hi, there should be a leaver or knurrld nut or handle at the back of
your saw loosen this and you should be able to tilt the saw over to the
left (normaly) under neath facing you , you should see a curved
angle guage and arrow marker 90--45 ...T.C.
Mar 20, 2013 | Hitachi C10FCE2 10" Compound Miter Saw
I bought the 10" compound
I have been in the same situation in the past, with a mastercraft miter saw to a point of using playing cards to get that nice tight miter joint. placing the cards between the fence and the piece i was trying to miter.Rioby makes mastercraft all thought they are a good saw they have their limits to the precisions of their cuts. good for fences,decks, stuctural framing ect, were a degree two is not a big thing,but when making furniture or interior trim work or picture frames or hobby craft you need to buy a good pro saw like a dewalt or bosh sliding compoud miter saw they may cost more **** their worth the money they are very precise and will last a life time if taken care of .It will be worth the money when you get that perfect cut every time you use it,it will put the JOY and fun back in your projects and not to mention qualaty in your master pieces.
Apr 01, 2011 | Ryobi 10 In Miter Saw With Laser
I have a Craftsman 10" table saw model number: 137.248830. The saw doesn't make square cuts, it is more of a problem when using the miter. I have followed the alignment procedure so that the right...
I assume that your alignment procedure is about adjusting your miter gage. But you should first verify if the blade is parallel to the miter slot (the slot the miter gage slides in). This is adjustable underneath the saw, and sometimes comes crooked from the factory or comes loose later on. To check if the blade is parallel to the miter slot you can do this.....1. unplug the saw. 2. Raise the blade as far as it will go. 3. Clamp a piece of wood to your miter gage so that it just touches the blade as close to the front of the saw as possible. 4. Use a marker and mark that spot on the blade. 5. Now slide the miter toward the back of the saw, and rotate the blade by hand so that your piece of wood hits the same spot as where you checked in the front. You can see a large misalignment by eye. But you can get a little precise by using a piece of paper between the wood and the blade as a feeler gage. Or better yet, use a drop indicator instead of the piece of wood and you can measure the difference. If this isn't as close to parallel as you are able to measure it, you need to turn the saw over and find the bolts that attach the whole assembly under there to the table top. Once you have this in alignment, you should be able to set your miter to be square against any good square. If you don't have a high quality square, you can go to a tool store (Sears or whoever) with your miter gage in hand, and set it to be square against their most expensive square. If the square is square, and the blade is parallel to the slot and it still won't cut square you either have a bad blade or there is too much play in the saw's arbor. Try to wiggle the blade side-to-side - any wiggle at all is too much.
Jan 20, 2010 | Craftsman 10" Table Saw
Miter slots on table are not parallel to blade
Either the saw is a cheapo and you can't do anything about it. If it is a better quality saw it should have at least four bolts or lugs where it it fastened to the table. Turn it upside down and locate those bolts. Loosen them - don't remove them- and turn it right side up. Now shift the motor assembly around until it is parallel with the miter slot. Make sure it is unplugged the whole time. Turn it upside down again and tighten the bolts. Recheck it and if it moved repeat the procedure.
Nov 03, 2009 | Delta Saws
I juat bought a craftsman table saw model # 113.19063, would like to locate a owners manual and a miter gage, pluse a place to get replacement parts
The sears online store is at www.managemyhome.com and you can get manuals and parts for some current models there. For older machines, try this website.
Most miter guages are relatively interchangeable, so it's possible a current Craftsman model will work in your miter slots. Just check the depth and whether or not there's a slot in the bottom sides for a key to lock it in place, then compare the depth to the new one you find. There are also aftermarket and specialty miter guages available from the standard woodworking tool catalogs and online. Replacement parts could be an issue.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Jul 03, 2009 | Saws
Cannot rotate the Dewalt 708 mod 3 saw horizontally
If you have loosened the handle a little and pulling the adjustment trigger didn't allow for movement,you may need to remove and clean the turn table.(don't forget,the handle must be loosened for the turn table to rotate)
Please rate this a fixya
Feb 09, 2009 | Cross Dewalt& 12" Double-Bevel Compound...
Dual voltage motor on table saw
get a step down power supply form a ac supply store.
Dec 12, 2008 | Jet 708668PK/Model JTAS - 10XL50 - 5/1PK...
Saws Logo
162 people viewed this question
Top Saws Experts
Tom Chichester
ray gallant
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Saw Expert? Answer questions, earn points and help others
