Question about IBM ThinkPad T30 2366 Notebook
I have a IBM T30 2366 laptop and it keep freezing when I turn the computer on.
  • f_jeneva Dec 30, 2010
    At window start
    Genius:
  • IBM Master
  • 1,274 Answers
Freezing at what point? at bios or at windows start?
Posted on Dec 30, 2010
  • Friendly PC Repair
    Friendly PC Repair Dec 30, 2010
    have you tried to load the computer in safe mode? tap f8 key after turning on, and when it presents you with options choose safe mode with networking. if it loads just fine, then you need to look at recently installed software/drivers to see what has changed since the last time it worked. an easy way to do this is to hit the windows key and the R key at the same time and when presented with a dialog box type 'eventvwr' and go to system. that should tell you all the latest changes
IBM Thinkpad R31 1.13GHz Keeps beeping a steady beep when i first turn it on
Step 1:
The memory of your computer was cannot support the system that you load. Just upgrade the memory or else replace of higher memory.
Step 2:
Just load operating system that your used previously. Because that was the compatible system that they used.
Apr 05, 2013 | IBM ThinkPad R31 2657 Notebook
My name is Luis and my Ibm thinkpad r40 keeps freezing and my screen goes black.
Hi, could be simply your computer is going into sleep mode and not waking back up. try changing your screen saver option to not hibernate or sleep.
Aug 18, 2009 | IBM ThinkPad T40 2373 Notebook
Computer Freezes unless pressure applied
With the laptop turned off, take out the hard drive completely from the laptop and then reseat it back into its slot and make sure its nice and snug.
Then go ahead and turn it on and see it will run without freezing on you and having to apply pressure on the keyboard.
If that doesn't work then disconnect the keyboard and see if it will run smoothly without the keyboard. If it does then you might have a stuck key on the keyboard that is making the unit freeze so you might have to replace the keyboard.
Jul 06, 2009 | IBM ThinkPad T43 Notebook
IBM T30 screen ramdomly goes blank and computer freezes.
Reset your bios settings to "Bios defaults", then disable power management.
In Windows, go to device manager and try to detect new hardware. Follows screen instructions.
Mar 27, 2009 | IBM ThinkPad T30 2366 Notebook
I keep losing my connection - IBM Thinkpad t42
Are you using IBM SW or Windows to manage the wireless? Occassionally, the IBM SW has issues with certain model routers and encyrption types.
You can also try unchecking the "Allow Computer to turn this device off to save power" in the adapter properties and
Adjusting the power on the wireless device to the max. By default IBM sets it in the middle to conserve power.
Mar 03, 2009 | IBM ThinkPad T42 Notebook
Problem with audio in ibm thinkpad t30,2366-y1b model
T30- no sound altho SOUND MAX drivers installed...
Try Control Panel, Sounds, Sounds (tab), choose a sound toward bottom of list. press the BLACK PLAY ARROW...if BLACK SQUARE appears at the arrow, your sound is installed $\& probably OK...
NOW,,,insert a musiv CD. then press the VOLUME BUTTON, (2nd one over from the THINKPAD button, & you should get sound aplenty !!
Dec 13, 2008 | IBM ThinkPad T30 2366 Notebook
IBM Laptop
Try going to Safe Mode. Normally you press F8 when you start the computer. When in Safe Mode, click Start -> Run then type msconfig. On the first tab, click on Diagnostic Startup. Apply, close and reboot the computer to Normal Mode. Lockups during startup are caused by startup programs.
Please rate this if you think this is helpful.
Dec 09, 2008 | IBM ThinkPad T30 2366 Notebook
R31 freezes up
Your computer shut down due a bad battery, Need to replaced.
Replace the battery first and see if your computer still freezing.
The reason(s) you may experience computer freezes, could be software related or hardware related; perhaps it's a combination of both.
Below is a broad list of some of common causes of computer freezes.
  • Memory
  • Video
  • Device Drivers
  • Bad Motherboard
  • Bad Devices
  • System Resources
  • Software
Sep 25, 2008 | IBM ThinkPad R31 2657 Notebook
IBM ThinkPad T30 2366 Notebook Logo
89 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
