Question about Braun Flex Integral 6520 Electric Shaver
Capacity of recharge went down to from 60 to 20 min after 3 years of usage. How to open for battery replacement.
  • Braun Master
  • 1,624 Answers
You will find compatible batteries for model 6520 at shaveroutlet.com. See link below. You will need two
http://shaveroutlet.com/shaver-replacement-parts/shaver-replacement-battery-aa-nimh-p-108.html
To open shaver, remove the two round screw covers on the bottom by prying them out. Remove screws underneath. Slide outer case off the bottom. You may need to reposition the lock to get it all the way off. Inside, you will need to unsnap and remove the black cover to access the batteries. For easier replacement, it is suggested that you use a modified installation technique. This is to break the tabs off of the old batteries rather than unsoldering them from the circuit board. This allows the old batteries to be removed but leaves the tabs attached to the circuit board. You can then solder the tabs from the new batteries to the old existing tabs
If you are not able to repair the shaver yourself, shaveroutlet.com can do it for you. See link below
http://shaveroutlet.com/shaver-replacement-parts/professional-battery-replacement-for-most-models-p-374.html
Posted on Dec 31, 2010
Hi. I have new Samsung SGH-X495 and I have not used it for 3 years . I started to charge the battery for 7 hours but still charging. I just to find out either this is normal after 3 years charging or I...
Rechargeable batteries fail if stored for long periods in a flat state.
If the cell phone battery is more than 3 - 4 years old then the battery could be worn out. Rechargeable batteries have a finite number of charge and discharge cycles and will lose their charge capacity over time, i.e. won't charge to 100% and gradually the charge reduces until the battery won't charge up at all. OR The battery shows a 100% charge but when the adapter is disconnected the battery drops off to zero capacity in a very short time. If the battery drops to an unacceptable charge level then the battery needs to be replaced. Rechargeable batteries will fail if stored in a discharged state for long periods.
Feb 28, 2013 | Cell Phones
Will not hold a charge and the scren went black
If the laptop battery is more than 3 - 4 years old then the battery could be worn out. Rechargeable batteries have a finite number of charge and discharge cycles and will lose their charge capacity over time, i.e. won't charge to 100% and gradually the charge reduces until the battery won't charge up at all. OR The battery shows a 100% charge but when the adapter is disconnected the battery drops off to zero capacity in a very short time. If the battery drops to an unacceptable charge level then the battery needs to be replaced. Rechargeable batteries will fail if stored in a discharged state for long periods.
Feb 21, 2013 | Fujitsu Siemens LifeBook Computers &...
When charging cell phone it says full charged after 5 min then when i take it off charger it says low battery... What is wrong with my phone?
the battery has lost its capacity because of ife usally happens after 2 years or more of usage the battery has to be replaced
Jan 28, 2013 | Samsung Galaxy Attain 4G for MetroPCS with...
Built in battery wont hold its charge
If the recharageable battery is more than 3 - 4 years old then the battery could be worn out. Rechargeable batteries have a finite number of charge and discharge cycles and will lose their charge capacity over time, i.e. won't charge to 100% and gradually the charge reduces until the battery won't charge up at all. OR The battery shows a 100% charge but when the adapter is disconnected the battery drops off to zero capacity in a very short time. If the battery drops to an unacceptable charge level then the battery needs to be replaced.
Aug 21, 2012 | Cameras
My aspire 5100 wont hold charge without charger
If thelaptop battery is more than 3 - 4 years old then the battery could be worn out.Rechargeable batteries have a finite number of charge and discharge cycles andwill lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up at all. OR Thebattery shows a 100% charge but when the adapter is disconnected the batterydrops off to zero capacity in a very short time. If the battery drops to anunacceptable charge level then the battery needs to be replaced.
Aug 05, 2012 | Acer Aspire 5100 Notebook
I have samsung corby GT -S3653 it's battery backup is only 20 min and during call it automatically switch off
If the cell phone battery is more than 3 - 4 years old thenthe battery could be worn out. Rechargeable batteries have a finite number of chargeand discharge cycles and will lose their charge capacity over time, i.e. won'tcharge to 100% and gradually the charge reduces until the battery won't chargeup at all. OR The battery shows a 100% charge but when the adapter isdisconnected the battery drops off to zero capacity in a very
Apr 13, 2012 | Cell Phones
My Acer Laptop is about 3 yrs old and since the last month the battery has been running down within half an hour while in the past it used to last at least for three hours.
Sep 25, 2010 | Acer Computers & Internet
Battrie wont last
You probably need to replace your batteries again most batteries in a owc need to be charged 12 hrs a day for the first month at least to build up the capacity if not they will slowly dwindle and wont last long and will need to be replaced
May 29, 2009 | Pride Mobility Products Used Jazzy...
How long is needed to recharge the Tyco R/C 9.6v turbo NiCd batte
It appears your battery pack has a capacity of 700 mAh.
If this is correct it would take 3.5 hours to charge with a 280 mA charger.
Apr 11, 2009 | Toys
Fully charge the Mobilepro battery
No. Lithium Ion batteries prefer a partial rather than a full discharge. Repeated full discharging robs the battery of its capacity (useful life), the Lithium Ion battery prefers shallow over repetitive deep discharge cycles. Besides cycling, the performance of the Li-ion is also affected by aging. Capacity loss through aging is independent of use however the capacity is affected by both aging and usage. Battery wear-down on lithium-based batteries is caused by two activities: actual usage or cycling and aging. The wear-down affects by usage and aging apply to all batteries but this is more pronounced on lithium-based systems. The Li-ion batteries prefer a shallow discharge. Partial discharges produce less wear than a full discharge and the capacity loss per cycle is reduced. Simple Guidelines to extend useful life of the battery Charge the Li-ion often, except before a long storage. Avoid repeated deep discharges. Keep the Li-ion battery cool. Prevent storage in a hot car. Never freeze a battery.
Sep 14, 2005 | NEC MobilePro 900 Handheld
Braun Flex Integral 6520 Electric Shaver Logo
149 people viewed this question
Top Braun Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Gary
Gary
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Braun Health and Beauty Expert? Answer questions, earn points and help others
