Question about Whirlpool GEW9250 Electric Dryer
The dryer is building up condensation inside the dryer and is not drying the clothes.
  • 51 Answers
MIGHT BE PROBLEM WITH FAN MOUNTED ON THE MOTOR AXLE AT THE BACK OF YOUR MACHINE OR SIMPLY OBSTRUCTED VENTILATION OPENING
Posted on Feb 02, 2011
Hotpoint WDUD9640 washer dryer clothes coming out wet and hot
check the exhaust tube externally and internally for excess lint build-up on the sides. You may not have the vent obstructed, but you may have the venting restricted. Clean out lint if there is excess. It may need a good scraping/ brushing to help your machine breathe. Just an extra thought.
Mar 11, 2018 | Hotpoint Dryers
Dryer is taking forever to dry clothes
If it cannot breath then there will be no air flow , if its a condenser dryer the point is that in every half year there must be a tangential fan blade inside to be cleaned because the gates of the blade can sit completely closed if the motor is defect of this fan then beware of fire if there comes to much dust inside , condenser dryers and fire hazard are close conected if there is no cleaning schedule for cleaning the machine from time to time
Sometimes there is a special provision to open to clean this read your manual.
But an air flow must be there , otherwise the heating element can made fire in a short time . By normal wash dryers with an outlet this chance is probability is much smaller and is the priority to clean For smaller fire risk due to less dust build-up by the machine here
Feb 23, 2016 | Dryers
My creda mode tcr2 isnt drying my clothes anymore
If your dryer is not drying like it once did or if you just have nottaken the time to give yourself a clean dryer in a long time then youneed to do that. At least once a year the dryer cleaning should takeplace. Lint build up in the dryer duct is one of the main causesfor your dryer to fail.
Here is the rest of this tip about DryerMaintenance
heatman101
Jul 30, 2011 | Dryers
Condenser dryer. Clothes are getting hot but not dry
heatman101
Jul 23, 2011 | Dryers
I have an IDC75 condenser dryer. Everytime i press the start button to start drying my clothes, it will not allow me to start it and immediatley shuts off the electricity in the whole kitchen. PLEASE,...
the culprit seems to be the CONDENSER BOX. This can quickly get blocked up by soggy wet lint/fluff debris from clothes. Some clothes shed more than others, so it is best to check this frequently. What happens is that when the CONDENSER BOX gets partially blocked up, it fails to condense the steamy moist air into water efficiently, and the insides of the drier start to get damp ans steamy. Depending on the amount of moisture, and the make (Some Zanussi and Hotpoint driers may be vulnerable to this), if any vulnerable electrical part get too damp, then there will be a "flash-over" between a live component and neutral or earth (usually a part connected to the casework). This can cause the kitchen circuit breaker to trip. The fix: remove your condenser box, and give it a good spray clean in the garden with your garden hose. Any large lumps of fluff/lint that are stubborn can be pushed out from between the condenser slots with a plastic ruler. Allow to dry. Then , with power removed from the drier, use a good flashlight checking that there has not been any build-up of fluff behind the condenser box area at the rear. You may need to remove the water tank as well to see more clearly. It is worthwhile also checking the little buffer-tank at the back, where there is a level sensor switch for the water tank level. If it is full of gungy water and lint, try to give it a clean out. Give your machine an hour or 2 to dry out internally a bit before attempting to dry any clothes, in case the breaker goes again. If it DOES go again, try leaving it for linger. If it still fails after being left for 24 hours, there may be a more permanent fault, inside the top back of the dryer there should be a wiring diagram(might be on the back panel of dryer) you will need to trace wires and with multimeter try to figure out what is causing the short. Hope this helps Tim
Nov 25, 2010 | Indesit Dryers
I have a GE model # DCVH680EJOMS front end loading Dryer and it seems to take multiple cycles to get my clothes dry. I discovered that Water is collecting in the flexible exhaust tubing...not just a...
Hi and Welcome to FixYa. I am Kelly
You already have discovered the problem. Lint has built up in the vent / exhaust ducting. Most of the time the through the wall vent flapper gets lint build up on it outside the house and then as that restricts airflow you get condensation in the ducting. The condensation causes the lint to form a cake like paste inside the ducting. THOROUGHLY Clean out your vent ducting from the dryer connection all the way thru the outside wall and your dryer will be fine. If you need to replace the ducting please do so. Ducting is cheaper than the electricity you waste on clogged ducting. You proved your dryer will work correctly when you dried a load of clothes with the ducting removed.
Thanks for choosing FixYa
Kelly
Sep 27, 2010 | GE DCVH515EF Electric Dryer
Dryer will not Dry!
A conventional dryer uses 240 volts to heat air, which passes through the tumbling laundry, picking up moisture, which is then vented to the building's exterior.
Your dryer uses 120 volts to warm air, which picks up moisture from the tumbling clothes, which then passes through a vent pipe in the back right corner of the dryer where a cold water spray causes the moisture to condense, run to the drain, and then is pumped out of the washer/dryer combo. There is no exterior vent to the outside of the building. Drying with your dryer will take at least twice as long as with a standard dryer. You can wash large loads, but can only dry small loads, and the clothes will not be as dry when dryer is finished as they will be with a standard dryer.
All that said, to make sure your dryer is performing as well as it can, you might like to take the back cover off and check the elbow at the very left bottom corner (when viewed from behind) to make sure nothing is obstructing the flow of water under the tub to the drain.
Aug 21, 2009 | LG WD-3243RHD Front Load Washer / Dryer
Burning smell coming from the dryer!
You have a serious clog somewhere in your dryer exhaust ventilation. I would recommend you STOP using the dryer immediately and clean both the interior and all the vent ducting from where it exits the dryer to where it exits the home. the burning is coming from lint build up in and around the heating element and its beginning to smolder. This is a potential fire hazard and may end up causing the heating circuits to fail. The condensation comes from the the inability of the hot air (which is mixed with humidity from your clothing) condensating inside the vent duct. The lint starts to collect and get wet to the point of saturation. Then it begins to cause water to form and leak out of the ducting and on to your floor. You do not want this condensation inside the dryer where the heating circuits are. The following link will provide with some guidance for future reference:
http://www.fixya.com/support/r385301-thorough_dryer_advice
Pay particular attention the paragraph where it discusses proper dryer ventilation. I hope this helps you. Let me know if I can be of further assistance.
Sep 28, 2008 | GE DBSR453EBWW Electric Dryer
Dryer needs multiple cycles to dry
I would check on the outside of the building. anti pest screens usualy plug up with lint. from the discription you have made it is definatly having troubles venting some where. Check every thing because venting is usualy not covered under warranty.
Sep 15, 2007 | GE DBSR453EBWW Electric Dryer
Whirlpool GEW9250 Electric Dryer Logo
98 people viewed this question
Top Whirlpool Dryers Experts
Tim Whalen
Sal De
Craig Butler
Craig Butler
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
