Question about Logitech Cordless Mouse
My logitech wireless Mobile Mouse 3000 (p/n X817408) just stopped working. The red light under it is still on but the green LED light goes off after a few seconds. Already replaced with new batteries... now what?! Help!
  • 166 Answers
SOURCE: Laser Mouse MX 1000 By logitech
Pretty much I cannibalized a pack of battery charging adapter plates, soldered the three wires to them, trimmed & bent them a little.. and then epoxied them down to the battery hold-down in their appropriate places. A little trimming was done on the plastic so the contacts could reach in far enough without obstruction.
After having the mouse sit around useless without a working battery in it.. for months, which definitely irritated me... I looked up 3.7V li-ion batteries and came across the "klic-5001 battery" (google it) and ordered two. The first one I destroyed trying to solder the wires directly to the battery contacts.. which just ruined all the internal li-ion battery components(i.e. DO NOT TRY DOING THAT)... the second battery, which I never tampered with whatsoever, is connected to the mouse via the contacts I described above. The klic-5001 batteries by the way do fit very well in the hold-down meant for the original battery.
End result: one, exceptionally well working MX1000 mouse which I can replace the rechargeable battery inside anytime it begins to get to aged and not working so well... ^_^ It charges as normal and the battery monitoring works like nothing ever changed.
Posted on Dec 29, 2007
SOURCE: Logitech mx1000 Not charging.
I had the same problem with the mouse MX1000 not charging when it is on its charger.
Then, I realized that I forgot to plug the adapter for the charger - this charger is not taking its power from the USB port but from an external charger!
Once I plugged the charger, the mouse recharged without any problem.
I hope this helps.
This mouse is really great, once this question of recharge is solved.
Stephan
Posted on Mar 24, 2008
  • 51 Answers
SOURCE: Logitech Wireless mouse stopped working
Logitech cordless devices are designed to always achieve at least 4 feet of good signal. Generally speaking, if you ahve the green light on the connect unit and the batteries are good on your actual mouse then it should work when you perform the synchronization procedure in the manual.
If it is still not working after you re-perform that you should consider relocating your laptop to try again from another environment (any electronic or electrical devices like zip drives, cd drives, etc can cause interferance). try it on a non metallic surface and if possible even try elevating the connect unit a few inches.
If it's still not working, uninstall and reinstall the drivers for your mouse and try again. If after all that it is still not working it's probably a hardware problem and you should contact logitech support for a possible warranty item replacement.
Posted on Jun 30, 2008
  • 20 Answers
SOURCE: Wireless Mobile Mouse 3000 not working
I suggest you do the following. After having synchronized both connecting buttons in mouse and receiver, take off battery and next look for a tiny thin button that protrudes from one of the sides where the receiver is placed in mouse, hold it depressed and put back a new and fresh battery releasing simultaneously this button. Mouse would work correctly. Good luck!!! Chawah.
Posted on Aug 03, 2009
rustysheriff
  • 344 Answers
SOURCE: I plug my wireless Microsoft Notebook Optical
Have you syncronized it with the receiver?
Normally you press a button on receiver then press another button on underside of mouse to sync it.
Posted on Apr 14, 2010
My microsoft wireless mobile mouse 3000 has stopped working. Everything including the battery and green light is working but when inserted into the USB cursor will not move.
Push the little red "connct" button on both the bottom of the mouse as well as the wireless receiver. If that does not work try referring to the quick start guide here.
Jul 11, 2011 | Microsoft Wireless Mobile Mouse 3000
I have a Microsoft Wireless Notebook Optical Mouse 3000 which was working yesterday but is now not responding. The red LED on the bottom of the mouse is flashing, but the green LED on the USB receiver only...
you might have to uninstall the mouse then restart your computer then reinstall the mouse and its drivers
make sure the battery is good (has full charge)also you might test the usb device for the mouse is inserted correctly into the usb port (if applicable)
click start control panel mouse you should see 4 tabs buttons,pointers,pointer options and hardware under hardware you can troubleshoot also you can select properties under driver you will have options to update driver,rollback driver or uninstall and under hardware you can troubleshoot
in xp
hope this helps
Feb 01, 2011 | Microsoft Wireless Notebook Optical Mouse...
I need to change the battery on my wireless mobile mouse 3000!
You can access the battery compartment in the Microsoft Mobile Mouse 3000 by pressing the release button on the underside of the mouse while prying up on the back of the casing. The red LED on the underside of the mouse will illuminate when a good battery is installed.
Hope this helps.
If this helps you resolve your problem, please
indicate by giving me a rating of 4 or saying thanks or both
Thank you for using FixYa!
Dec 03, 2010 | Microsoft Wireless Mobile Mouse 3000
I have a microsoft wireless mobile mouse 3000. I
try to look at if you plugged it properly. or bring it where you bought it and ask your question to them
Dec 20, 2009 | Microsoft Wireless Mobile Mouse 3000
Wireless mouse stopped working. green light works
This can happen when the battery's are starting to die. Replace the batteries and then test the device again.
Oct 09, 2009 | HP Wireless Optical Mouse
My Logitech cordless mouse just stopped working. The Logitech connect device is plugged into the laptop and the batteries in the mouse are working as the green light is on.
Replace the batteries anyway.
It does not take much battery power to light that LED.
Whenever a wireless mouse STOPS working for no reason.
I immediately suspect the batteries.
You can first try switching to another USB port.
This often causes system to Wake UP and realize a new devise has been detected.
Does this happen in one spot?
There could be some device close by that is interfering with the signal.
Hope this helps.
Oct 04, 2009 | Logitech Cordless Desktop EX110
Microsoft wireless mouse 3000 - all lights are on; flash upon reset, but still doesn't work. Running Vista 64-bit.
Try to take off battery and next push and hold down the small button that protrudes where the receiver is placed in the mouse, put back battery and simultaneusly release the button,it might make the mouse operate correctly. Good luck!!!! Chawah.
May 28, 2009 | Microsoft Wireless Notebook Optical Mouse...
MS wireless notebook mouse 3000 not working?
A friend of mine brought me this problem with exactly the same problem. here is what I found. The small notch in usb device socket under the mouse was malfunctioning. If you press this notch you will find the mouse red light blink. If you further try pressing this notch at some point the mouse red light comes on constantly. Thats it, hold it there and try to connect first by pressing the usb device connect switch and then the mouse connect switch. The moment the connection is made the usb device stops blinking and the red light on the mouse starts blinking. Wow, it works now. Some one might just open the mouse and fix this microswtich for a permanent solution.
Jul 08, 2008 | Microsoft Wireless Notebook Optical Mouse...
Jun 26, 2008 | Logitech Computers & Internet
Logitech Cordless Mouse Logo
282 people viewed this question
Top Logitech Computers & Internet Experts
micky dee
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
