My laptop is not switched off.during that time if i fold the pc my screen goes off.when i open folding screen remain close.i moved the mouse pointer also pressed power button but screen remain close.HOW WILL I OPEN MY SCREEN?
  • 536 Answers
Remove the battery and the power cord from the laptop and the press the power button down and hold it down for 30 seconds. Re-install the battery and the power cord and try to turn on your laptop as usual.
Posted on Dec 30, 2010
07 corvette top will retract but deck lid makes no effort to close, then top will not go back up. Need to release pressure in block lift top up about 1/4 of way then top will go back up
Manually Moving the Folding Top from the Down Position
Important: Allow the system a minimum of four minutes to bleed down pressure after the last cycle.
Manually release the folding top cover latch using the emergency release cable.
Raise the folding top stowage cover.
Manually raise the folding top, holding the 5 bow up.
Manually lower and latch the folding top stowage cover.
Manually unfold the top and latch per normal procedure.
Manually Moving the Folding Top from the Up Position
Manually release header latch per normal operation.
Manually lift front of roof off of the header and raise the #5 bow at the same time.
Manually release the Folding Top Cover latch using the emergency release cable.
Fold the roof down into the well.
Manually close and latch the folding top stowage cover.
Power Folding Top System Components
The power folding top system consists of the following components:
• Folding top control (FTC) module
• Body control module (BCM)
• Folding top control switch
• Serial data communication
• Folding top cover latch actuator
• Folding top cover pull down actuator
• Folding top pump motor with valve manifold
• Position switches and limit switches:
- Pin receiver switch
- Luggage barrier switch
- Folding top cover open switch
- Top open switch
- Top closed switch
- 5 bow raised switch
- 5 bow lowered switch
• Tonneau release relay
• TONNEAU PULL DOWN ACTUATOR Fuse 20 A
• TONNEAU RELEASE Fuse 10 A
• BATT 2 Fuse 40 A
• REAR FOG/ALDL TOP SW Fuse 10 A
• Folding top mechanical components:
- Folding top
- Folding top cover
- Folding top valve 1
- Folding top valve 2
- Folding top valve 3
- Hydraulic lines and cylinders
Folding Top Cover Latch Actuator
The power folding top system includes a folding top cover that is powered open and close by a hydraulic system that is controlled by the FTC module. A power unlatch motor is used to unlatch the folding top cover before the folding top control (FTC) module powers the top cover open. The folding top cover unlatching is requested by the FTC module via class 2 message, but is executed by the body control module (BCM). When requested, the BCM applies battery voltage through the folding top cover release relay control circuit to the tonneau release relay. The relay is energized and battery voltage is applied through the folding top cover release control circuit to the latch actuator. The actuator is energized and the latch releases the folding top cover.
The electronics on this are very complex ,
System Operation
Before any movement of the power folding top is allowed, the folding top control (FTC) module must be aware of the following conditions:
• Unlatch the header. The FTC module reads the pin receiver switch is Inactive.
• The windows must be normalized. Refer to Power Window Reinitialization.
• The ignition must be placed in Accessory or RUN.
• The transmission must be placed in PARK, or with manual transmission, the park brake must be applied.
• Trunk status must not be ajar.
• The luggage barrier must be in place.
• The pump motor temperature must be within the operating range.
After the last cycle of power folding top operation, allow the hydraulic system a minimum of 4 minutes to bleed down before attempting manual operation of the top.
Your best bet take and have it checked for DTC'S - diagnostic trouble codes .
DTC B3666 Rear Tonneau Position Error
DTC B3667 Tonneau Release Circuit
DTC B1011
DTC B1291
DTC B1420
DTC B3602
DTC B3666
DTC B3667
DTC B3670
DTC B3971
Jan 23, 2017 | 2007 Chevrolet Corvette Convertible
When opening the top, it all works until it is time for the truck to close and then it doesn't.
What make ,model an year vehicle ? Could be a sensor or a control module . Some of these convertibles are very complex , could set DTC'S diagnostic trouble codes .
The hydraulic lines and the cylinders
GMLAN communication to the Body Control Module (BCM)
Open/Close request circuit to the driver and passenger window motors
Power and Grounds
Folding Top Main Power Fuse 30A
Folding Top Logic Power Fuse 20A
Ground G301 for the FTC module and G305
Folding Top Open/Close Switch (S15 and S16)
Rear Compartment Limit Switches
Rear Compartment Lid Release Switch (S3 and S4)
Rear Compartment Lid Release Switch-Front Hinge-Left (S11 and S12)
Rear Compartment Lid Release Switch-Front Hinge-Right (S9 and S10)
Folding Top Front Location Pin Guide-Left (S17 and S18)
Rear Compartment Lid Release Switch-Left (S19A)
Rear Compartment Lid Release Switch-Right (S19B)
Rear Compartment Partition Position Switch (S20)
Folding Top Front Location Pin Position Switch (S13)
Folding Top Front Latch Actuator Position Switch (S14)
Hall Effect Sensors
Folding Top Header Latch Cylinder Sensor (S1)
Rear Compartment Cylinder Extended Sensor (S2)
DTC B367F 58: Roof Stowed Ready to Latch Sensor Circuit incorrect reaction after event
DTC B367F 59: Roof Stowed Ready to Latch Sensor Circuit circuit/component protection time out
DTC B367B 58: Deck Lid Anti-Rotation Latched Sensor Circuit incorrect reaction after event
DTC B367B 59: Deck Lid Anti-Rotation Latched Sensor Circuit circuit/component protection time out
Your best bet is probably to take your vehicle to a qualified repair shop.
May 23, 2016 | Cars & Trucks
On a 207 G6 GT Pontiac retractable hardtop where is the sensor that gives the message top not secure. Top goes up and down seem secure will not allow the trunk to open with the key or door button
The retractable hard top is controlled by the folding top control (FTC) module.
The folding top control (FTC) module
Hydraulic pump assembly; valve 1, valve 2 and motor
Power and Grounds
Hall Effect Sensors
Your best bet is have the system checked for DTC'S - diagnostic trouble codes ! If it showed a message top not secured there is a DTC stored in the control module ! there are 24 possible DTC'S
May 29, 2015 | 2007 Pontiac G6 GT
Black screen during log in
Try booting in safe mode by hitting F8 every second after you turn it on until the boot screen comes up. Then select "safe mode" If it loads up in safe mode then delete the graphics driver from Device Manager.
If you were able to delete the driver in Device manager then reboot and get the driver from here:
http://www.dell.com/support/drivers/us/en/04
May 15, 2012 | Dell Obsidian Black 15.6" Inspiron N5050...
Mousepad on laptop too sensitive, jumps and opens links all the time
Hi I also have OS Vista, try this:-
go to the bottom left corner of the screen to the windows button and single click it, move the cursor to "control panel", leave it there and a whole new list of stuff will appear, move the cursor to "personalization" and click it once. This will open a box on the screen. Single click on "mouse pointers", this will open another smaller box with 8 tabs inside. You can click on any of these tabs and adjust your mouse actions to your own preferences, eg; how the pointer looks, how fast you double click, how fast the pointer moves on the screen, anything you like :)
Once you have made all your adjustments, click "apply" in the bottom right corner of the box and this will save the changes you've made.
I hope this helps.
May 06, 2012 | Medion Computers & Internet
I must have hit a button and now the cursor is showing up on the big screen off the projector but I only want to see it on my laptop while doing my presentation.
Hi renee_pott, "You can choose the "Mouse Options" in the Control Panel.
First, click on the -> Start button -> Control Panel -> Hardware and Sound -> Mouse ->
Mouse Properties -> Pointer Options.
Try one 'or' more options:
* Snap To, place a (Check in the box) !
* Hide pointer while typing !
* Show location of pointer when I press the {CTRL key} !
  • Usually the "Mouse" pointer by { Default }, is displayed during a slide presentation, and when the mouse is moved.
  • " Try pressing the {Ctrl + H keys to "Hide" the mouse pointer}."
  • Left-clicking on the "Mouse" button, will advance [forward] the slide show.
  • Pressing Ctrl + A keys, will restore the "Mouse" pointer.
!"Take a moment to rate the help."
Thanks paul7of9
Mar 23, 2011 | Computers & Internet
My mouse causes me to have to gets in the retype all the time cause it goes back up in my sentence or highlights my words blue
This is a very common issue with mouse pads build into laptops computer and can be avoid by moving your hands away from the mouse pad (meaning to open more) during the typing process. You might also want to try to disable temporarily the mouse pad by pressing the mouse button sometimes located on top of your mouse cell or pad or, by pressing FN key along with "F's" key(from F2 to F12). There should be a pad with a hand meaning to either disabling or enabling your mouse pointer.
Finally, try to use and external mouse.
Good Luck!!
Jan 11, 2011 | Computers & Internet
HP TX1000 Tablet The cursor on my screen keeps going to the bottom left hand corner and stays there. The problem remains even when I used a USB mouse. Anyone knows what the cause?
click start button in lower left hand corner, then a pop out menu will come up, click control panel, then find mouse, click it, then go to pointer options and click it, see if theres a box checked that says something like (automatically move pointer to the default button in a dialog box). uncheck that box......hope this helps you.......
Jan 06, 2010 | HP Pavilion TX1000Z 12.1" Touch Screen...
Laptop screen
Sounds like the switch that tells the cpu when it's open or closed is going bad. On most laptops there is a little switch that protrudes from your keyboard (usually in upper corners). Try cleaning it with isopropyl alchol(rubbing alchol) and a q-tip and see what happens. If you can't locate the switch on your model get back to me and i'll research a little deeper for you. Hope this helps
Sep 14, 2007 | IBM ThinkPad 770 Notebook
Computers & Internet Logo
David Payne
David Payne
