OC fail warning comes.pc does not switch on at 1st time.next time it asks to do setting in setup. my config is hp dx2280mt, 945 mb, core2 d, win 07 os.
    Sergeant:
  • 210 Answers
Hi, As I understand, you may have dead cmos battery or is not seated properly. I hope this this will you to solve the problem... Have a Happy New Year...
Posted on Dec 30, 2010
Win xp on toshiba lcd 32 bp10e
If your model Toshiba laptop has a Restore partition on thehard drive then follow these steps to restore your Toshiba to the Out of theBox condition.
1. Press and hold the 0 (zero) key and at the same time, tap the power buttononce to switch on
your notebook.
2. When the machine Starts beeping; release the 0 key.
3. When prompted by the warning screen; select Yes to continue with the systemrecovery.
4. Select Recovery of Factory Default Software; click Next.
5. Select Recover to out-of-box state. 6. Click Next again.
7. Click Next to Start recovery.
8. Restart the Toshiba laptop when there restoration process finishes running.Follow the prompts that appear on the screen to set up the laptop's date, timeand language settings.
Mar 29, 2012 | Computers & Internet
I need to install win xp on hp 540 and ineed to know if i have to configer from bios or i need win xp sata support OS?
Befor installation you need to follow the following steps
1. Start your laptop and press F10 continuously to go to BIOS setup.
2. Go to "System Configuration" -> "Device Configurations"
3. Set "SATA Native Mode" to Disabled.
4. Start the installation while keeping a finger on "F7" key.
5. After some time there will be continuous beeps.
6. Remove your finger for sometime and then continuously press "F7" key till the beeps are repeated. This is done to disable your BIOS ACPI.
7. And then do you normal Xp installation.
8. This should do
Jan 08, 2011 | HP Jornada 540 Pocket PC
Need the setup disc... it's asking for set up disc. Said my Config system is corrputed
You can try to reinstall windows with any cd ( if XP ) go trough the installation process and carefully see it will ask you if you want to repair the windows twice the first time the answer is not the second time if you say yes it will reinstall windows but that will not damage any of you settings.
if you are brave you can also boot with win xp cd and try to repair the boot sector.
boot on command prompt. then type
" fixmbr" with no quotes.
this fill fix only the boot sector and your system will work OK.
Jul 26, 2010 | HP Pavilion ze4400 Notebook
"cant install win-xp on CQ-60"
Hello.
Hope this helps...
These are the normal steps on desktop computers but
should work in your case too with a fresh installation
1. Enter bios settings and set CD Drive as first boot device
2. After reboot if you are asked if you want to start on cd chose yes.
3. start Win Xp installation from cd.
4. delete partiton on C; drive
5. create new partition
6. Start installation and format the c:drive
7. Follow the installation instructions,,,
Feb 10, 2009 | Compaq Presario CQ60-220US PC Laptop
Automatic switch to next bin when one empties
Touch MENU, then scroll to CONFIG DEVICE then to SYSTEM SETUP then to TRAY BEHAVIOR then to the top setting set it to FIRST from EXCLUSIVELY
Feb 10, 2009 | HP LaserJet M4345 MultiFunction Printer
Mobile fails to start while loading config.txt. The phone just switches off.
Download HP Universal Bootloader and reinstall the OS. I did it. It works fine.
Apr 08, 2008 | HP iPAQ hw6515 Pocket PC
LAN card not installing
u can use any brand . there's no problem in that . installation procedure is very simple. just buy a pci lan card. Insert it in the pci slot. Then switch on your computer , insert the driver cd provided with your lan card , then install the appropriate drivers.
Then, you can connect BSNL Broadband by connecting your ADSL modem with your LAN card.
Hope it helps..
Regards
Grydor.
Mar 06, 2008 | Computers & Internet
Oc failed enter setup to chwck oc settings
Could you please give us more details such as which computer (model number) and motherboard you're using? Do you know how to overclock and that's what you were doing? If so, you didn't overclock correctly and you need to change the settings back to the normal settings for your computer to boot up properly. You can change the settings in the BIOS, or "setup".
Jan 09, 2008 | Computers & Internet
Installing visual basic v5 on HP DC5700 (Win XP)
HP's software may be interfering with the installation process.  Make sure that all unnecessary software has been shut down, including AV, Antispyware, firewalls, etc. before you start the installation.  Checking the error log for specific info would help determine what is causing it.
Oct 19, 2007 | HP Compaq Business Desktop dc5700 - Core 2...
HD Audio Hardware
Hi, To be able to help you on what audio driver to install, pls specify brand, model and version of your motherboard. If not printed on the MB itself, maybe you can check the info on POST or visually check the audio chipset on the mobo. Pls post back the info/details. Kind regards.
Aug 12, 2007 | Microsoft Windows XP Professional With...
Computers & Internet Logo
60 people viewed this question
David Payne
David Payne
