Question about Nordic Track Exercise & Fitness
I have a NordicTrack c2200. I find that the tread belt is not running smoothly while running on it. As I run, the belt temporarily stops during each running step, causing me to trip up. I tried to lube, tighten and loosen the tread belt. The motor seems to be running fine. The belt does stop completely if I press hard enough on the belt, at any speed...thank you
    Novelist:
  • 129 Answers
There are a couple possibilities.
Remove the motor cover and run the machine.
Check the tension of the motor belt. It may need to be tightened. I have a NordicTrack c2200.  I find that the tread - 2manyhobbies.jpg
Check that the pulley has not broken free from the front roller by stopping the walking belt when the machine is running. If the belt stops, but the motor and pulley keep turning, the pulley has broken free from the front roller.
If this is the case, with a drill and small drill bit, drill a hole through the pulley and roller on the inside edge of the pulley, between the ribs (not where the motor belt travels) and put a screw through the plastic into the metal roller.
Otherwise, change the roller.
Good Luck.
Posted on Dec 30, 2010
Tread belt not turning on
please LUBE the deck belt with WD-40 or grease . and try to loose a little the deck, the idea is to lift- 2-3" max.
Of course is time too, to maintenance Motor
Feb 12, 2015 | Nordic Track NordicTrack C2200 Treadmill...
STARTS AND THEN ITS STOPS??
If the timer is set it will always stop at EXACTLY the same time.
If the motor is overheating, it will usually slow down before it stops; and the time will be a little different each time.
Congratulations, I only know one other person who has worn out a nodic track.
Feb 03, 2015 | Nordic Track Nordictrack C2200 Treadmill...
NTL 1192 is the product.
The reset switch is to close to main switch, reset it. See your instruction manual in section troubleshooting. for identify the reset switch. or download your instr. manual from www. fitness.manualsonline.com
God bless you
Nov 07, 2012 | Nordic Track Nordictrack C2200 Treadmill...
C2200 treadmill motor problem
1)measure the voltage input motor, if there are The motor need repair or replace.
2) mEASURE the output voltage board, for input voltage motor, if there are NOT the board is faulty, see the block diagram.
3) Test th drive belt for loose or break and replace.
Jun 28, 2012 | Nordic Track Nordictrack C2200 Treadmill...
I have a Nordictrack c2200 treadmill. All of a sudden I feel like I am going to fall through when I run near the front of it. What could be the problem? And if it is the deck, can I flip it and use the...
The deck is most likely broken, It would need replaced if this is the problem. The nordictrack models do not have decks that can be flipped. That is usually reserved for a commercial grade machine of a different brand.
Aug 13, 2010 | Nordic Track Exercise & Fitness
My c2200 treadmill will not reset or operate other than the incline from 4 degrees thru 12 degrees. fan nor tread will operate. Pulse sensor does work. is there reset instructions
This is dinesh from AADHI FITNESS SERVICE CENTRE...
Search for the details in justdial india...
Can we come to ur place and check the machine... My contact no is 9986202487
Jul 28, 2010 | Nordic Track NordicTrack Treadmill, A2550
Nordictrack exp 1000 trips safety and stops abruptly...
Inspect belt and deck. The deck should be smooth without any grooves, pits, or exposed wood. The belt should have a consistent ridged feel from one side of the belt to the other (a belt can be worn out without any sensory signs of a problem). If you feel deep grooves in the deck or uneven wear on the underside of the belt, part replacement is necessary. Visually look at the underside of the belt. It should have a consistent look. Black streaks in the belt are a sign of bottom-layer wear through. Very worn belts will feel smooth in the areas you normally walk- you would think smooth is good but not in belts because the smoother the belt, the more contact area. Continued use of your treadmill may damage expensive electrical components. 85% of all Treadmill problems are cause by worn belt and deck I would revisit the scene of the crime again.
Jun 10, 2010 | Nordic Track Exercise & Fitness
My NordicTrack EXP 1000 stops in the middle of a workout. Before it stops, I smell a rubber smell. 1) Does the tread need lubrication? 2) Is the motoer burning out?
my nordic track 1000 stops several times during the workout. I can step to the side and the belt may or may not start back up. The display continues to display the set machine. any suggestions?
Jan 03, 2010 | Nordic Track NordicTrack Treadmill, A2550
Tread is sliding and rubbing agianst right side of track.
Make sure treadmill is running when you adjust belt. The treadmill belt tracks as the belt goes around. I usually put machine on 2-2.5 if belt is not rubbing instantly. If belt is already against plastic, turn adj. counterclockwise on the opposite side about one full turn. You can usually move belt with your foot to see if it aligns any with turning on the treadmill. Once belt is not rubbing, turn treadmill on and continue alighing the belt.
Jul 20, 2009 | Nordic Track NordicTrack Treadmill, A2550
Exercise & Fitness Logo
799 people viewed this question
Top Nordic Track Exercise & Fitness Experts
Matt Olenzek
Matt Olenzek
Ross Metcalfe
Ross Metcalfe
 Atlanta Fitness
Atlanta Fitness
Level 1 Expert
Are you a Nordic Track Exercise and Fitnes Expert? Answer questions, earn points and help others
