Question about Woods Outdoor Lighting Timer
How do i remove an event from programing - Woods Outdoor Lighting Timer
Removing event from programming is dependent on brand and model number of timer.
Identify timer and then add a comment.
Some timers are reset by unplugging them. Some timers have a reset button.
Each timer is different.
On Utilitec 0192773, the manual says to press PROG button to find setting, and then press RESUME button.
http://waterheatertimer.org/Program-wire-Utilitec-0192773.html
On ST01C timer, press MODE until screen displays PGM, then press ON/OFF to find setting, then press + until program displays, press ON/OFF and then press + until SKIP is displayed.
http://waterheatertimer.org/ST01C-program.html
Use following links to help identify your timer:
http://waterheatertimer.org/GE-timers-and-manuals.html
http://waterheatertimer.org/Woods-timers-and-manuals.html
http://waterheatertimer.org/UPM-timers-and-manuals.html
If you do not want to identify your timer and add a comment for further free help, then take advantage of fixya phone support.
For a price, fixya expert reads steps from the manual while you program the timer.
Posted on Dec 30, 2010
How do i remove sierra event planner from my windows 10. Managed to remove Hallmark card studio but cant now reinstall it.
in windows 10 on the charms bar, touch the search option and type in what your looking for and it should come up. you can also go to the my pc which should be the c drive and see if there is a folder of the program and see if you can delete it also
Mar 20, 2016 | Sierra Hallmark Card Studio Deluxe 2005...
In "Event Viewer" errors relating to MatSvc" appears several times daily
Go into control panel, add remove programs and uninstall Microsoft Fix It.
May 22, 2013 | Microsoft Windows XP Home SP3 for PC
How do I remove Facebook events from my Samsung S Planner calendar?
I had this problem on my Galaxy S5 - There's 2 steps to fix it.
1) Remove the declined event from Facebook
In the Event page, you'll see buttons for "Join" "Maybe" "Decline" and "..." click the ... and choose "Remove me from guest list"
2) Clear out calendar data and Resync
On your device, open the full Application Manager (usually in settings / Applications / Application manager / All ) and look for "Calendar Storage" - choose "Clear Data" (and "Clear Cache" too, to be safe)
Open the Splanner app settings and choose sync.
Hope this helps!
Apr 22, 2013 | Samsung GALAXY Note Smartphone Unlocked
I have a ET100C and the lights will only stay on for a few seconds in both manual and auto modes
Before you attempt any reprogramming, you might be better served by performing a RESET on the clock. TO RESET TIME SWITCH COMPLETELY: Press the recessed RESET switch for five seconds to remove all eight available events and to reset time of day clock to 12:00 A.M.
After resetting, try reprogramming again. The procedure below is copied from the manual (which can be downloaded here):
TO MANUALLY TURN ON OR OFF: Program Selector switch must be in RUN position. In AUTO or MANUAL Press ON/OFF button. Display indicates load is either on or off.
TO SET TIME: Slide Program Selector switch to TIME SET. Press HOUR and
MINUTE buttons individually to select current time of day. Note that clock is a 12 hour AM/PM repeating clock.
TO SET OR CHANGE PROGRAMMED SET POINTS: Select PROGRAM mode with Program Selector. Note that the event display shows Event #1. There are eight possible programmed events. Four ON and four OFF which are programmed alternately. All available events need not be used.
Press the HOUR and MINUTE buttons separately to program the first ON time
desired. Note the ON indicator (OFF in the next step) will only be displayed after the hour has been selected unless an ON time was previously entered.
Press EVENT button. The display now shows the next Event #2. Press HOUR and MINUTE buttons separately to select first OFF time or Event #2.
Press EVENT button to select Event #3. This is the second ON time. Program the ON time by pressing the HOUR and MINUTE buttons. Repeat this procedure for up to 4 ON and 4 OFF times (8 Events) as required. Return Program Selector switch to RUN Position. Be sure Manual/Auto switch is in the AUTO position.
TO OVERRIDE PROGRAM: Program can be overridden at any time by selecting the MANUAL position. Program set times will be maintained but will not operate the controlled load(s) automatically.
TO CHANGE OR DELETE PROGRAM SET POINTS: Place Program Selector switch into PROGRAM mode. Press EVENT button to step through the eight possible events. Note that the times which have been programmed will be displayed or 0:00 will be displayed if no set point has been entered. To change an event time, press the HOUR and/or MINUTE buttons to change the time currently in the program to the new time desired. Press EVENT button to proceed to next programmed event. To remove a programmed Event: Press the ON/OFF button two times. When this is done, the display will show 0:00 and the event number.
I hope this helps & good luck!
Nov 16, 2011 | Intermatic ET100C Energy Controls -...
I have Calandar Creator 10 and have created a family calandar which I use from year to year that includes birthday events, holidays etc. and phases of the moon. This year, when I went from Dec. 2010 to...
Calendar Creator 10 has the four moon phases from Jan 1990 thru Dec 2010. To extend past 2010:
- File Open Collection ' Local Disk(c:)'Program Files'Calendar Creator' Template'Events'Phases of the Moon.bcc
-For each of the four events (First Quarter, Full Moon, Last Quarter, and New Moon) change the Repeat Until date past 12/31/2010 to 12/31 of the year you will add data for
-For each of the four events, click Advanced Repeat Rule you can selete the drop down under Exceptions / Pick exception and there you can see the dates by month and year from Jan 1990 thru Dec 2010 for the event. You need to extend this list. First obtain the moon phases from some web site like www.timeanddate.com/calendar. (note that this site calculates the mone phases base on New York time). The simply select each of the dates for the event you are modifying by clicking that date on the calendar in the upper right hand of the screen. Just advance the calendar thru the months and years you want to enter data for. You can check the list when finished by selection the ExceptionS Pick exception drop down box.
- Save your changes by clicking OK and Ok again. Make changes for all for events.
- Select File and Save Collection
- You need to replace the Phases of the moon events in your calendar by removing the old events and importing the new events. To remove the old Phases of the moon in your calendar, select Events'Categories highlight Phases of the moon and delete. Then add back the changed events by File'Import Events and browse for the Phases of the moon.bcc file you changed.
I hope this gets you what you need.
Nov 19, 2010 | Broderbund Calendar Creator Deluxe 10 Full...
Need instructions to program Intermatic Model #E140C wall switch timer.
Do you mean Intermatic E104C box-type timer? Intermatic does not make E140C
Manual says "refer to programming instructions on time switch door"
http://www.intermatic.com/~/media/files/intermatic/products/instructions/timers/et104c%20-%20english.ashx
Manual says timer has 8 events per 24-hour day ... 4 'on' events and 4 'off' events. Normal operations, selectors are set to AUTO and RUN.
Using sketchy info from manual about programming:
Set sliders to MANUAL & TIME/SET
Press EVENT for event 1 ... set hour and minute using HOUR & MIN buttons ... this will be 'on' time
Press EVENT for event 2 ... set hour and minute ... this will be 'off' time
Set all 8 events ... 4 'on' and 4 'off'
Move sliders to AUTO & RUN for timer operation
Sep 15, 2010 | Hardware & Accessories
Programming Utilitech Item # 0192773
Go through the normal setup. Year, month, day, time, DST and the location (north, center, south).
Hit program and make sure all events are clear. Program the first (ON) event, press the TIME button and press /- (with the hour segment blinking) until you see the Sun/Moon symbol indicating the sunset time. Press PROG and program the (OFF) event. Press the /- buttons until you see the Sun/Moon symbol indicating the sunrise time.
Hitting resume clears events if you accidentally entered them.
Make sure you display shows AUTO and you're good to go.
Jul 29, 2010 | Hardware & Accessories
How we can remove active directory in windows 2003 safe mode ?
hello,
you just try to remove as force.
go to run, after this type " dcpromo /forceremoval ".
it will do this for you, if any issue on active directory or ad database.
you can do this command in normal or safe mode.
thanks,
Apr 25, 2010 | Microsoft Windows Server 2003 Enterprise...
Runtime error 365
This is a VB error right?
All i can advice is remove the unload from the event. in case, you can add a timer in your form, in the click event start the timer, and remove the objects in the Timer event (and remember to stop the Timer)
And while scanning for more solution, i bumped into this site and here's a solution that i think might help you.
  • There is an Unload statement in the Paint event for the form or for a control on the form that has the Paint event. Remove the Unload statement from the Paint event.
  • There is an Unload statement in the Change, Click, or DropDown events of a ComboBox. Remove the Unload statement from the event.
  • There is an Unload statement in the Scroll event of an HScrollBar or VScrollBar control. Remove the Unload statement from the event.
  • There is an Unload statement in the Resize event of a Data, Form, MDIForm, or PictureBox control. Remove the Unload statement from the event.
  • There is an Unload statement in the Resize event of an MDIForm that is trying to unload an MDI child form. Remove the Unload statement from the event.
  • There is an Unload statement in the RePosition event or Validate event of a Data control. Remove the Unload statement from the event.
  • There is an Unload statement in the ObjectMove event of an OLE Container control. Remove the Unload statement from the event.
Mar 28, 2010 | Acer Aspire 55421462 Notebook
Event source = dvd maker .. event id=1001 .. error code=2..version =6.0.6000.16386 ..error code=oxebo2ob88
Un install your DVD burning software , reboot, and then install it clean.
(some programs have it in the start/programs/my DVD program/uninstall and others do not, if not, then go to control panel./add remove programs/mydvd programName
and click uninstall and then reboot .
Thank you and good luck.
Oct 26, 2008 | Computers & Internet
Woods Outdoor Lighting Timer Logo
94 people viewed this question
Top Woods Hardware & Accessories Experts
Gene Haynes
Colin Stickland
Colin Stickland
Are you a Woods Hardware and Accessory Expert? Answer questions, earn points and help others
