Question about Nintendo Video Game Consoles & Games
Unable to connect to my wireless internet,after doing all steps. getting error codes,51031 and, 51032
4 Suggested Answers
brucew79
  • 24 Answers
SOURCE: Error Code: 52030 unable to connect to Belkin
This error code usually indicates a problem relating to wireless security. Please try the following troubleshooting:
  1. Are you using WEP or WPA security on your router?
    1. Log into the router using the default IP (consult your router's manual for assistance)
    2. Locate the "wireless security" section of your router settings and find the WEP or WPA key.
    3. If you are using 64-bit encryption, the WEP Key must be a 10-character key consisting of numbers or letters A through F.
    4. If you are using 128-bit encryption, the WEP Key must be a 26-character key consisting of numbers or letters A through F.
    5. The WEP Key must be a Hexadecimal (0-9, A-F, no other special characters or letters).
    6. If your router has multiple slots for a WEP Key, make sure the active key is the one in the #1 slot.
    7. If you are using WPA, the Wii console is compatible with the following types:
      • WPA - PSK (TKIP)
      • WPA - PSK (AES)
      • WPA2 - PSK (AES)
  2. If your WEP or WPA key is correct, then the problem might be related to MAC address filtering:
    1. From the router settings, locate the "MAC address filter" settings (also known as "access control", "access list", or "network filter" depending on your router model).
    2. If the Mac address filter is set to "enabled", then you must add the Wii's MAC address to the "allowed" list. You can locate the Wii's MAC address from the "console information" page (located under "Internet" in the Wii Settings).
    3. If the Mac address filter was disabled, then continue troubleshooting.
  3. If your connection was working previously, try power cycling your router and modem by unplugging them both from the wall. Wait a few minutes, and plug the modem back in. Wait a couple of minutes for the modem to initialize, then turn on the router. Try to connect the Wii console online and test for proper response. (Some routers may lose their connection to the Wii console while it is in Standby or turned off for a period of time. Check with your router manufacturer's website for the latest firmware, as there may be an update that will help prevent this issue from occurring in the future.)
  4. Try adjusting the "Channel" your wireless router broadcasts on. We highly recommend setting your wireless router to either channel 1 or 11. This can potentially increase the download speed. For information on accessing your router's settings, click here to select the brand name and model number of your router (if available).
  5. Try a "Manual Setup" with the Wii console (how to), using your network's IP configuration settings. To access these settings:
    1. On your PC, click "Start" and then "Run."
    2. Type "CMD" into the field that appears to open a new window.
    3. Type "IPCONFIG/ALL" and press "Enter" to display a list of internet settings. Locate the settings asked for by the Wii console during the Manual Setup process and enter them.
Posted on Oct 29, 2009
derfisdabest
  • 55 Answers
SOURCE: I can't get my wii to connect to my wireless
go to settings wii settings then click internet and click any connection search for access point then type in pass(optional) and then click ok go back to wii menu and connect
Posted on May 02, 2011
  • 55 Answers
SOURCE: I am getting error code 52230. Unable to connect
sir you can visit this site to help you fix your wii console on your own... thank you sir please rate me
http://www.nintendo.com/consumer/wfc/en_na/ds/results.jsp?error_code=52230&system=Wii&locale=en_US
Posted on Jul 02, 2011
Testimonial: "THANKS FOUND IT."
Cannot connect to internet on my Nintendo to view nexflex error shows 52130
You may need to manually assign a DNS server. NIntendo has instructions for that here:
Nintendo Customer Service Nintendo Wi Fi Connection Error Code Results
If this doesn't help you can try calling the nintendo support line at the bottom of the explaination
Oct 10, 2014 | Nintendo Wii Console
Error code 52130, trying to hook up to the wireless internet. Any Suggestions?
Error Code: 52130 The Wii is unable to connect to the Internet
Likely cause: The wireless router is incorrectly connected, or the Wii console will need a DNS manually entered.
How to fix: Check the way your router is connected; manually assign a DNS to the Wii.
  1. Check the connections to your wireless router:
      Even if you are able to get a working Internet connection to your computer through the wireless router, if it is not properly connected to the modem, the Wii and other devices may not be able to use it.
    • Most routers have five (5) ports on the back. Typically there is a set of four, with a single port either farther away from the rest, or separated with a different color border or line. This single port is often labeled "Internet" or "INT." Make sure the cable coming out of your modem is plugged directly into this "Internet" port, and not into one of the other four that are grouped together.
  2. Manually change your Wii console's DNS settings. To do this, follow these steps:
    1. Access the Wii system settings (how to), and use the right arrow twice and select "Internet."
    2. Select "Connection Settings," and choose the connection file (1, 2, or 3) that are you are currently using.
    3. Select "Change settings" and click the right arrow 3 times to reach "Auto-Obtain DNS."
    4. Select "No," and choose "Advanced Settings."
    5. Click into the "Primary DNS" field and enter: 8.8.8.8
    6. Click into the "Secondary DNS" field and enter: 8.8.4.4 Select "Confirm," and then "Save."
    7. Select "OK" to start the connection test. Once the test finishes, try to download the update again.
  3. If you are still getting this error code after trying the steps above, please call 1-800-255-3700 for further assistance.
Nov 26, 2011 | Nintendo Wii Console
It says unable to connect to the internet. error code 020100
Error Code: 020100
The Nintendo DS is unable to connect to an Access Point. What to do will depend on where you are connecting from:
PCHELPSTER007 from youtube
Aug 07, 2011 | Nintendo DSi White Console
Error code 52130
This is from Nintendo support's website
Error Code: 52130 Was this information helpful?
    6. Click into the "Secondary DNS" field and enter: 8.8.4.4 Please note: These are public DNS's provided by Google and are subject to Google's Terms of Service. If you prefer to not use this service, doing an Internet search for "public DNS" will provide you with several other options you can use.
    7. Select "Confirm," and then "Save."
    8. Select "OK" to start the connection test. Once the test finishes, try to download the update again.
    Good luck
Jul 19, 2011 | Nintendo Wii Console
How do I get my Wii to connect to my internet wirelessly? When I try I get error code 51331
Sorry to hear you are having problems with your wii. According to Nintendo, error code 51331 is:
Error Code: 51331
Unable to connect to your wireless network
This error code is more specific to having incorrect security settings on your wii. Your encryption key is wrong when trying to connect to your wireless internet. Double check your encryption key with your router's settings and try again.
You can see the official support article from Nintendo here:
http://www.nintendo.com/consumer/wfc/en_na/ds/results.jsp?error_code=51331&system=Wii&locale=lang
Apr 27, 2011 | Nintendo Video Game Consoles & Games
Trying to connect my wii to internet but getting error code 32007 how can i fix
Error Code: 32007 There was a problem downloading the latest Wii update.
Please check the following:
  1. Our servers may be down temporarily or experiencing a high amount of network traffic, especially after a new update has become available. Wait a few hours and try again. If you are still receiving this error after waiting, check the next steps.
  2. Satellite Internet often causes this Error Code. You must have a cable or DSL internet connection. Other connection types, such as dial-up and satellite, are typically not compatible. Contact your Internet Service Provider if you are not sure what type of internet connection you have.
  3. Does your internet service provider (ISP) require that you log in whenever you wish to use the internet? If so, your ISP may not be compatible with the Wii console. Please contact your ISP for additional information.
If you are still unable to connect, and have waited a few hours, please try the following:
How are you attempting to connect your Wii console online?
    Wireless Router:
  1. Try adjusting the "Channel" your wireless router broadcasts on. We highly recommend setting your wireless router to either channel 1 or 11. Be sure to try both channels if the first one you try does not work. This can potentially increase the download speed. For information on accessing your router's settings, click here to select the brand name and model number of your router (if available). (The "Channel" setting is typically found in the "Wireless" section of your router's setup utility.)
  2. If adjusting the "Channel" did not work, please review our "Slow Download Times or Errors Received While Connecting" troubleshooting tips by clicking here.
  3. Are you using a Netgear brand wireless router? Our expeirence shows disabling the "SPI Firewall" of the router may help the connection. The "SPI Firewall" option is typically found under the "WAN Setup" tab of the router's settings. For information on accessing your router's settings, please click here and select the model of the Netgear router you own (if available).
May 09, 2010 | Nintendo Wii Console
I have a acer aspire 5570Z, unable to connect online...
Open network connections and disable your wireless connection (right click) then renable it and try to connect. What program are you using to manage your wireless connection?
If you are using your manufaturers software then try using windows xp (or vice versa)
Aug 25, 2009 | Acer Aspire 5500 5570-2609 Laptop
I can't connect to the internet via my router
i have bought a dlink wireless router.hooked up to desktop computer ;with no problem. but can;t get a signal for my laptop (toshibs 2000 professional) can you help me what am i doing wrong ;do i need to buy something for the laptop.
Jun 07, 2009 | Dell Wireless 2350 Router
Connecting to Netflix with a Roku video player
What is the exact error message??
Are you unable to connect to LAN or Internet Or Wireless network
May 31, 2009 | D-Link DIR-625 (790069292637) Wireless...
Wii Internet connection
When you are not able to connect with Internet from Your Wii, means there is something wrong with the settings. You may go to Wii Fix Guide and check out the guide available there, This DIY guide will show step by step pictures to fix the problems yourself without any technical knowledge.
Oct 29, 2008 | Nintendo Wii Console
Video Game Consoles & Games Logo
46 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Bee Santiago
Raj Patel
phil
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
