I pluged in my ipod and then my DCM230 did not even read the ipod but it reads everything else like the cd, and the radio. Can you help me?
My radio/CD player constantly says "ERR" and CD's won't play anymore. It doesn't show the time or the radio station either, just "ERR". I can hear it, like it's trying...
HI lisasmith566 IT is not a fuse problem .
the problem is your the CD part of the radio
must likely the cd is stock or more likely the cd drive motor is defective .
FIRST try pushing eject on radio and see CD comes out if not you need a new radio .
good luck vote
Jul 27, 2011 | 2003 Chevrolet Tracker
My Philips DCM230 home stereo system wont produce any sound. The CD is playing, the voulme is on, and the mute is off. What could be the problem?
Your output I.C. might be faulty. Output I.C. is the one converting the audio from cd's,tuner,auxiliary to sound which passes to your speakers.
Since your Output I.C. is defective then the unit will not generate any sound even your inputs(cd,tuner,auxiliary) is working.
It is quite technical so I've advice you to look for a qualified technician to isolate the problem and do resoldering also for some dry joints on the main board.Dry joints also will might caused for damaged a parts.
Thanks for using fixya.
Jan 05, 2011 | Philips DCM230/37 iPod Docking Executive...
My ipod nano 5 its not being recognized or open or read by itunes and by any computer , its like if the ipod its not even pluged in,please help!!!!!!!!!!!!
if they battery is completly dead it will do that for like 5 minutes. but a light screen should show up indicating its charging. just wait for 10 mins if it doesn't connect then
update itunes.
Oct 25, 2010 | Apple iPod nano
AM radio tuner set as MW tuner. How to switch to U.S.A. AM mode?
AM is just another name for MW. The Radio should tune to a strong signal regardless of the frequency the radio is set to. It should also sweep the entire frequency looking for stations. I'm assuming it has a channel scan setting, plus options to set a number for the station. AM/MW are very much dependent on the position of the either internal or external Ariel. If you have the radio in the wrong position or you have some electrical equipment nearby it could block the signal for the station you want, but not affect the others. Which might explain why it can't find the station you want.
May 05, 2017 | Philips DCM230/37 iPod Docking Executive...
Kenwood iPod Interface
I have a Pioneer Premier Deck in my van and I get the same problem I just unplug it and plug it back in
Mar 06, 2009 | Kenwood eXcelon KDC-X579 CD Player
Ilive ib7 ipod won't play
Hello, I had the same problem and I was about to return it to the store and finally figure it out...
The IPOD buttton wont work unless you really plug the IPOD in the craddle... I was thinking all the time that it was pluged, but it was not... You need to aligned it.. When you think is pluged look between the IPOD and the Boom box and you will have a better view... If you have the Classic IPOD like me, you will have to slide the plug on the boom box to the right... Try my friend....
Jun 06, 2008 | Apple iLive IBCD3816DT Portable 2.1...
Radio sound but NO cd or ipod sound
Radio is screwed.
But try these these steps:
Clean the eye of the head for reading CD. Must open up the radio.
IPod: check for good connections from Ipod to PCB.
Feb 23, 2008 | Alpine CDA-9856 CD Player
55 people viewed this question
 Grubhead
Grubhead
