Question about Kenwood Audio Players & Recorders
My DP-48 CD Player is erratic. Sometimes it plays and can search, memorise, replay and do all I ask of it. Other times, it cannot even play the first track but keeps revolving over and over. Please note: it is NOT a faulty CD, since the machine can misbehave or behave on the same CD. Can you help?
Same thing is happening with mine, its old asf and won't play a CD without skipping the entire way through, I recommend you just reset it by unplugging it for a day with the power button on, that might help reduce any static buildup in the ribbon cables. Anything from over 20 years ago will have many ribbon cables, which build up static causing electrical errors in the unit. I usually just turn it off for a few hours and then it works fine. But if that doesn't work, it's probably the spinning mechanism, since it's so old, the motor probably needs lubricating, if it's rusted or bent, then it is unfix able. I only recommend this if you didn't plan on taking it to a professional AV repair store. I hope you get to read this as I realize your post is from 7 years ago. good luck.
Posted on Sep 24, 2017
My cd-48 sometimes gives disc info but reads no disc when play is pressed???
i found my dads Marantz CD-48 on the attic and had the same problem. Some CD`s the player was able to play instantly others not, getting the Error Message after trying to read the disc. My problem was solved after i opened it up and cleaned the linse of the player with a cotton swab.
Mar 10, 2014 | Marantz CD-48 CD Player
Nikkai car stereo
The CD player is failing to track the CDs accurately and is likely to become more erratic over time.
Dec 03, 2013 | Computers & Internet
My action replay ds leaves the start screen but then just goes white even before it reaches the main menu.i tried blowing on it it and it still does the same thing
Hello dijanilaplac,
There can be many problems with your Action Replay DS. Try taking the Action Replay out of your Nintendo DS Lite Console, and look at the part those goes into the DS. Make sure nothing is bent, or missing. If something is, it might mean you may have to have it repaired, or replaced. Also keep in mind that sometimes Action Replays can be sensetive, so don't move it around while playing, or it may cause your DS to freeze up.
If you just bought this Action Replay recently, it should have been supplied with a CD to insert into your computer. You should install Action Replay onto your computer. When you have been brought to the main Action Replay Code Manager, find your USB and Action Replay plug in. Plug the small end into the top of the Action Replay cartridge, and the USB into the computer. Now a New Hardware wizard should have popped up on your computer.
When prompt, select, "Install from specific location.", then click next. Then select Search from CD-ROM. Sometimes it may sound different, just select the one that says something about searching from a CD-ROM. After this has completed, reset your Action Replay.
If the problem persists, feel free to contact me, for questions, or replies.
Nate,
Aug 28, 2011 | Nintendo DS Lite Console
Sometimes i put a CD in and it will start to read it and then come up with CD error, is there any reason for this? Other times it will play it fine until you go to change the CD then you have the same...
Hi, It could be a scratched cd or a dirty lazer inside the unit. Any car wax or pledge works wounders on cd and dvds. And if it's the player you cold look for a lazor head cleaner. It lloks like a cd only it has fine hairs that brush of the lens of the lazer. good luck
http://www.amazon.com/Maxell-DVD-LC-DVD-Lens-Cleaner/dp/B00000JPPI
Oct 31, 2010 | Blaupunkt Lausanne CD31 CD Player
I have a Kenwood music system (quite old ) cd player DP-322 after you load the disc it sometimes just plays 1 track or doesn't play at all if you open the draw and then close it and select random play it...
you need to have the lazer lense cleaned by a pro or buy a lens cleaning cd and load it about 5 times i think youl find it will fix your problem
cheers
sonic boom electronics australia.
Apr 21, 2010 | Audio Players & Recorders
Kenwood cd player DP-M6010
After retrieving the cds from the unit I replaced it with my iPod. It seemed to me to be the most cost effect method to solve the problem.
Feb 08, 2008 | Audio Players & Recorders
When you play the CD it keeps on skipping
http://www.free-service-manuals.com
Have heaps of manuals. Do a search.
Jan 22, 2008 | Dual XDMR7710 CD Player
Playing CD-RW audio CDs on Kenwood DP-J2070
try to play a song from original cds.
maybe you brunt it in mp3 file, or its a different format. try to burn your song to cd-r.
if still, try to use nero to burner..
if it wont play your original cds and burnt cds,then the optical lens or the board is broken.
hope I helped you.
Dec 06, 2007 | Kenwood DP-J2070 CD Player
CD plays CD's intermittently does not recognise some CDs
in my side i already encountered that problem.this is what eve done,i'm just clean the lens with cotton and one drop of alcohol, after cleaning,its work.....just follow what i'm doing....
Aug 25, 2007 | Sony SA-VA100 System
185 people viewed this question
Top Kenwood Audio Players & Recorders Experts
 Grubhead
Grubhead
da surgen
Are you a Kenwood Audio Player and Recorder Expert? Answer questions, earn points and help others
