Question about Universal Garage Wireless Keyless Entry System
I have a KLIK2 Remote Key less pad. I have tried to program the pad for my Lift master 1160LM Garage Door Opener. I have used Type 4 in the users manual (orange smart button) without success, any suggestions?
How do I program the garage door opener?
You post again, what the model is of the opener, the car model, it looks like this control is in a car.
Most times you need the garage door remote, then you have to hold a button and the remote button to sync the two.
What ever you are trying to program, if this is a car, you need the manual.
If you need more help, you need to post the model number of everything.
Not every car, every opener is the same at programing.
Imagine that, life simple.
Apr 03, 2013 | Building Materials
I have a Lift Master wireless touch pad but a Chamberlain garage door opener. How Do I change the frequency so the touch pad works?
You can't change the frequency but you can try programming.
Locate the smart/learn button on the rear of the motor unit near where all those white wires go. Press and immediately release this and then walk over to the keypad and key in any 4 digit code you like and press enter.
If this doesn't work then the keypad is bad or it is not the proper model for your opener.
Feb 19, 2011 | Sears Craftsman LiftMaster Chamberlain...
I recently bought a house which has a craftsman 1/2 HP garage door opener. The garage door opener works fine using the wall mounted pad and also the numeric key pad, but not with the remote that came with...
If you didn't, try programming the remote this way.
Press and hold the button on the remote and then press and immediately release the smart/learn button on the motor unit. If this doesn't work you need to make sure you have the correct remote for the model opener you have. Your model number doesn't bring any results from Sears Parts.com.
Nov 10, 2010 | Sears Craftsman LiftMaster Chamberlain...
My lift master security plus keyless entry pad for the garage door no longer will open the garage door when I key in the four digit code. Can I reprogram the entry pad and if sohow?thank you
You can try programming it but first make sure the battery is good. Locate the smart/learn button on the rear of the motor unit near where all those white wires go. Press and immediately release this and then walk over to your keypad and key in any 4 digit code you like and press enter.
May 20, 2010 | Sears Craftsman LiftMaster Chamberlain...
I need KLIK2 remote instructions
How do I connect KLIK2 to a linear with a learn button
Feb 17, 2010 | Universal Garage Wireless Keyless Entry...
Need instructions for model klik2 remote, lost mine
Don't try and sell me a new opener. I just need clear programming instructions.
Jim Scrivener 1605 Wood Creek Lane Allen, TX 75002
Aug 26, 2009 | Universal Garage Wireless Keyless Entry...
Programming car remote using garage door opener remote control fo
GOTO HOMELINK.COM
THEY MAKE THE SYSTEM AND HAVE INSTRUCTIONS YOU CAN DOWNLOAD.
PLEASE NOTE: NOT ALL BRANDS/MODELS OF OPENER WILL WORK WITH THIS SYSTEM.
HOPE THIS HELPS
Jul 03, 2009 | 2003 Lexus ES 300
Universal Garage Wireless Keyless Entry System Logo
714 people viewed this question
Top Universal Building Materials Experts
Terry Smith
Level 1 Expert
Tom Chichester
ray gallant
Are you an Universal Building Material Expert? Answer questions, earn points and help others
