Question about LG WM-2277HW Front Load Washer
WATER LEAKING FROM AIR VENT IN BACK OF MACHINE
2 Suggested Answers
  • 249 Answers
SOURCE: water leaking out of back air vent
Check your filter,and see .!!!water may not be pumping out fast enough!!
Posted on Dec 20, 2007
Why is there waterl leaking from my power vent unit
http://waterheatertimer.org/Leaking-water-heater.html
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html#vent
Bad vent?
Improper vent? Undersized vent?
Vent termination cap located on roof has come off?
Bird nest in vent pipe?
Gene
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Oct 17, 2014 | Fasco Bradford White Water Hot Heater...
Looking at machine top left side in back leaking out of little vent
If its water you may have to lift the control housing and look underneith, there are soap despensing water valves there, thet could be leaking
Sep 22, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
Why does the air conditioner leak water from behind the unit. My air conditioner is placed in a wall and the back end of the conditioning unit sticks out inside the garage. I have ventilation by...
It is normal for an air conditioner to leak water out the back. This water is actually the humidity being taken out of your house. Being vented out in to the garage is always an issue with condensate water. I have seen some people take a funnel and run a hose outside the garage somewhere. Keep the vent closed. It will be harder to cool the house with the vent open because it lets outside air in to the house.
Jul 04, 2011 | Friedrich Heating & Cooling
Whilst wash on, water leaks from the underneath of washing machine. but cant see where it is coming from
if the water is leaking during the fill cycle when the detergent is being added from the drawer
ensure the draw is clear, if too much deturget rests has blocked the vent then water maybe running out on the inside.
if the problem is happening during the wash cycle this indicates a leak on your drum, ensure your door seal is intact and not leaking.
if the problem is during pumping, ensure that the pump is not causing a problem
maybe open the bottom vent and ensure the cover is seated properly and pump is clear.
also check the outlet pipe is not blocked or leaking and water is running back on the outside of the outlet pipe and under the machine
I hope this was useful.
May 23, 2011 | AEG Washing Machines
Leaks water on rinse cycle thru upper vent
Are you referring to the vent on the back of the machine? If your leaking water, you need to replace or install some new mushroom valves. These mushroom valves, go in both bellows on the top of the machine. One bellow goes from the dispenser box, to the tub. This is where the water goes into the tub, to fill. The other bellow, is attached to the top of the tub, to vent. These both have or are suppose to have mushroom valves in them. If they do not, you're machine will leak water out the back of the vent.
Mar 28, 2010 | LG WM2233H Front Load Stacked Washer /...
Mothers AC unit
That has nothing to do with the water. Sounds to me like it needs cleanning, (the water is not drainning toward the back of the unit) ,,(dirty filter, which its trying to **** air anywhere it can even thru the drain hole, or not enough slope, leanning toward the back so gravity can flow the water to the back of the coil! Thank you-very-much!
Aug 28, 2008 | GE Zoneline AZ38H12DAD Split System Air...
Rv air conditioner leaking
I have the same problem....it is a negative pressure problem holding water inside the unit until it overflows the pan and runs into the duct system. why this occurs....I don't know....I cant find a problem with my air return, but as soon as you turn in off, the water comes gushing out the drains on the unit. I resolved this....temporarily....by twisting up a paper towel into a wick, and placing one end up into the drain tray, with the other end lying well out into the exterior case. This lets the water wick out and keeps the tray drained. I don't understand the problem and don't know what the permanent fix will be, except maybe cutting a hole and placing an intake vent directly below the unit.
Jul 16, 2008 | Dometic Rooftop RV Air Conditioner
Water leaking out of back air vent
Dec 20, 2007 | LG WM-2077C Front Load Washer
LG WM-2077 Water leaks out of the Air Vent on the back
Be sure you are using HE detergent and only about 1 Tablespoon for a load. You are ending up with too many bubbles in the machine and when it goes to spin the bubbles come out the air vent. There is a valve that closes during spin but bubbles are not strong enough to lift the valve it has to be water hitting it before it closes.
LG WM-2277HW Front Load Washer Logo
136 people viewed this question
Top LG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
