Question about Olympus Cameras
My Olympus 740 digital camera does not auto focus any more. I can make it focus for the most part by zooming in, but is there anything I can do to make it start up focused? I had another Olympus camera model a few years ago that I had to send in to Olympus 3 times for the same problem.
  • 579 Answers
Take it off manual focus? There may be an "all reset" option in one of the menus that makes the camera factory default whenever its turned on, usually this is full auto mode. If the camera will only focus when the zoom is used, there may be a secondary lens inside the lens barrel that is not moving as it should. Time to service it if that is the case.
Posted on Jul 07, 2008
Olympus zukio 14-45mm lens does not auto focus or zoom not sure if it hit anything after the last shoot
does not do focus/zoom properly,is due to defective mechanism of the lens unit,so get it serviced.
Mar 29, 2010 | Olympus EVOLT E-500 Digital Camera
View finder usage
There's a small button next to the LCD screen that allows you to switch between LCD & viewfinder.
Feb 03, 2009 | Olympus Camedia C-740 Ultra Zoom Digital...
Olympus C-740 ultra zoom
You need a USB 2.0 cable, and hook it to your PC. The Operating System will auto detect it as a removable drive. Just pull off the jpg files from that removable drive. It will probably show up as e:\
Feb 12, 2008 | Olympus Camedia C-740 Ultra Zoom Digital...
Zoom lens Motor Problem?
The suggests the zoom control failure
Only Olympus can fix it to it will have to go back.
Nov 08, 2007 | Olympus Camedia C-740 Ultra Zoom Digital...
Auto Focus Problem
Way to check settings is to take the batteries out for a while, it should revert to factory default settings. I tell a lot of People to try this, it works an amazing number of times. Auto focus looks for vertical lines, what are You shooting at? Try rotating the camera 90 degrees, if it locks better,Bingo. Subjects without much contrast are hard to lock focus on
Sep 12, 2005 | Olympus Camedia C-740 Ultra Zoom Digital...
Focus Problem
Low light focus lock can be a problem with this camera. But in normal or bright light there should be no problem with auto focus lock. If this is a new problem, you should check to see if a setting has been changed. With so many options, it is easy to accidently set something that causes unusual results (been there, done that). First ... Go to the Setup Menu and see that the "All Reset" option is selected. This will cause everything to be reset to factory default each time you power-on the camera. Turn the camera off and then turn the camera on. Then take some test photos to see if your auto-focus-lock is improved. If that works, there is no need to check the items below. If that does not work, here are some control changes to try. Remember if you turn off the camera everything gets reset. That camera uses contrast detection for auto focus and it is normally set to "Multi-Area Auto Focus". Try changing it to "Spot Auto Focus" and do some tests, including with the camera set to one of the programs or manual mode. There is another setting called "Autofocus Area", you should investigate. Check your manual to determine what you can do with this control. There is another control called something like "continuous auto focus". Check the manual for further information. If none of the above help, it is time to see about some camera repairs.
Sep 06, 2005 | Olympus Camedia C-740 Ultra Zoom Digital...
IESP auto focus
iESP is the default auto focus setting for the C-8080 Wide Zoom camera. It uses a contrast detecting system to analyze the entire image by comparing the subject against the background to achieve focus. When the shutter button is pressed half way on the C-8080 Wide Zoom, the AF target mark automatically moves to an area of the image where it finds the optimal contrast.
Sep 04, 2005 | Olympus Camedia C-8080 Wide Zoom Digital...
IESP auto focus
iESP is the default auto focus setting for the C-5060 Wide Zoom camera. It uses a contrast detecting system, to analyze the entire image by comparing the subject against the background to achieve focus. When the shutter button is pressed half way on the C-5060 Wide Zoom, the AF target zone automatically moves the to an area of the image where it finds the optimal contrast.
Sep 04, 2005 | Olympus Camedia C-5060 Wide Zoom Digital...
Cameras Logo
69 people viewed this question
Top Olympus Cameras Experts
Willem.
Willem.
Are you an Olympus Camera Expert? Answer questions, earn points and help others
