Question about Panasonic Televison & Video
I have a projection tv that as gone a little fuzzy, a little to the side, and there a blue blur behind all the objects on the screen. how do I fix it? The model NO. is PT-47WX51CE and the chassis NO. is DP820
  • Panasonic Master
  • 8,617 Answers
You will need to replace the convergence ICs they are both STK392-120 and you can get replacements at the following link and they provide free instalation instructions with pictures. Heres the link.
http://servicemanuals.vstore.ca/
Posted on Jul 07, 2008
Red and blue color on TV is aligned but blurred, green is ok
U have a CRT Tube coolant problems.Tries Websites MCMElectronics.com,Tv reapair World.com to buy CRT tube coolant to recharge ur CRT.
Feb 26, 2010 | Sony KP-46WT500 46" Rear Projection...
Fuzzy background on tv picture
This is probably a combination of 2 things. In both causes 1 and 2 below, I would suggest checking the TV with a BluRay Player with BluRay disc connected using an HDMI Cable. If you complain about this, then the TV is probably not that great. Expect a $200 jump to a better model at the least (but this depends on what you have now). Honestly, this is fairly normal and wont change much with the next TV.
CAUSE 1: Motion BLUR
Motion blur occurs when fast moving objects are displayed on LCD TVs. Basically, it takes time for the LED lights that make up the picture to turn ON and OFF, when and object shown on the TV is moving faster than the LCD TV can turn these lights ON and OFF, you see the trail left behind as the lights dim to OFF. This look like blur because you see the current image and the trail of the old images. 120HZ and 240HZ LCD TV are supposed to improve this but honestly, they are at times 300+ dollars more and not really worth it. Very little difference except in some few cases.
CAUSE 2: Digital TV
Digital signals are hit or miss. Good or BAD. If you are watching Cable, Satelite or Antenna; it is likely you are seeing some BLOCK NOISE. This block noise is caused by missing information or Noise in the video signal. This will cause the picture to Pixilate (you see blocks and things start looking blurry too). This happens with poor signals. This also happens with the HD channels when they have more information than bandwidth (more data than that have space to send it...image shoving an elephant into a VolksWagon Beetle)
May 27, 2009 | Televison & Video
RCA projection tv is blue and fuzzy
may be convegence try turning down the blue screen and see that that does see if the picture clears...
Feb 04, 2009 | RCA Televison & Video
How to fix fuzzy pic & red,blue,green lines on your screen?
Typically this is due to a convergence chip failure. This repair can be done pretty easy with the proper instruction. Have a look at this video to help determine if you truly have a convergence problem.
Jan 26, 2009 | Toshiba 57H82 57" Rear Projection...
Blue shadows appear to be behind white objects
TV shows large red spot in middle of tv when dark show are on, you can see it more.  Now blue spots on upper right side too.  Spend way to much on this tv to have these kinds of problems only after 3 yrs.
Nov 16, 2008 | Hitachi UltraVision CineForm 55VG825 55"...
Fuzzy blue shadows blurring
Search for convergence problems... I have same problem. Appears that there are two chips (IC) to replace to fix problem. TV repair man cost about $400 do it yourself about $50 if youe brave..
Aug 11, 2008 | Televison & Video
Repair on problem blue dot
Good Day, flavrlen;
This is your fix it is not costly and if you handle a screwdriver you can do this in 30 minutes:
PANASONIC:
MODELS: PT-44LCX65, PT52LCX15, PT-52LCX65, PT-52LCX35, PT-61LCX65,
PT-61LCX35.
SYMPTOMS: 1. FUZZY SPOTS
2. FUZZY SPOTS
3. FUZZY SPOTS WITH STAINS
4. FUZZY SPOTS & UPSIDE DOWN
5. FUZZY SPOTS WITH LINES
CORRECTION: SYMPTOMS CAN BE CORRECTED BY EEPROM
CORRECTION TOOL; (LSUQ0100).
Good Luck, big IRISH.
Jul 09, 2008 | Panasonic PT-52LCX65 44" HDTV
RCA 52" HDTV Rear Projection TV MM52110JX1
Replace FL231 400ma fuse. this will fix your problem.
Oct 26, 2007 | RCA D52W19 52" Rear Projection Television
Televison & Video Logo
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
