Question about Frigidaire Refrigerators
I purchased a brand new Frigidaire refrigerator this month (December) and for the past couple of weeks the ice dispenser and water dispenser were working just fine until today. The ice maker stopped creating ice and the water dispenser is no longer releasing water. I checked the water line and confirmed that water is still going through the line and reaching to the refrigerator so that piece is ok. I even tried dispensing the left over ice that was created thinking that maybe there was too much in the designated ice spot however, that didn't work. Is there a quick fix to get the ice and water dispenser working again? The refrigerator is new so I don't understand whats going on. I am at a lost of what to do... please help.
  • Frigidaire Master
  • 3,740 Answers
Hi and welcome to FixYa, I am Kelly.
Your Refrigerator is still under the manufacturers warranty so there is little you can do before contacting customer service. Having said that; there is something you can do before calling for service. I suspect that just maybe your freezer is too cold and the plumbing for the comparement and door water supply may have frozen. Empty the freezer and place a fan blowing into the freezer compartment for over 2 hours. It makes a water mess so be prepaired for the necessary tending to the drips. After the over 2 hours of manual defrosting with a fan check the water in the door function to see if you have water flow. If you have flow at this time you need to begin raising the freezer temperature until you no longer experience water line freeze ups. If after the manual defrosting period you still have the problem you will need to call for warranty service.
One other thing to check is to depress the door light switch and make sure the light is going off when the door is closed. Even if you discover that the light is staying on with the door switch plunger depressed you must contact the Frigidaire service team for warranty service. Since you did not provide a model number there is a possibility that your light switch is actually located in the upper door hinge area. The number for warranty service is listed below.
To reach a service team member, please call:
1-800-374-4432
Monday-Friday, 9:00am-5:30pm (EST)
There are many things I could have you do but all of them would void your warranty.
Thanks for choosing FixYa,
Kelly
Posted on Dec 30, 2010
Ice maker quit working
Good Afternoon Kevin,
I understand that your Frigidaire refrigerator, model# FRS26R4A, is not making ice. There are a couple of things you can check. First, check the wire signal arm to make sure it is in the "down" or ON position. The ice maker turns off automatically when the ice container becomes full. To stop the ice maker, lift the wire signal arm until it clicks, and locks in the "up" or OFF position. Second, check to see if the water dispenser is dispensing. You might need to change your water filter. It's recommended you change it every 6-8 months. The other thing if your appliance is not dispensing water is there might be a kink in the hose or maybe the water supply has been cut off. Hope this has been helpful.
-Best Regards-
WP
Mar 27, 2014 | Frigidaire FRS26R4A Side by Side...
My new refrigerator's ice maker and water dispenser doesnt work
Since this is a brand new unit, I wouldn't waste the time or money troubleshooting it yourself; contact the place you purchased it from and exchange it.
Jul 14, 2008 | LG LSC26905TT Side by Side Refrigerator
Continuous knocking noise from ice maker. Ice maker has been off for past 3 months. Only thing that will make it stop is turning it off or unplugging it.
Hi Marcel,
Thank you for contacting fixya.
Our ice maker recently had its water inlet freeze up, preventing water from filling the trays. The mechanism kept dutifully trying to push nonexistent ice cubes into a bin that never filled up, which might account for the knocking noise in your case.
To defrost it we just unplugged the unit, took all the food out of the freezer section, and left the door open for a couple of hours. It wasn't long enough for any of the frozen food to defrost, and since we were careful to minimize opening the refrigerator section's door, the food in that part stayed cold enough to be safe as well.
Feb 09, 2014 | Frigidaire FPHB2899LF
Freezer light, ice maker, and ice/water dispenser stopped working
did you replace the light . or just tighten it . and is ice cream soft . it sounds like the tempt is above 15 deg . and needs to be colder . this may be a control problem . but ck the little things first . clean the coils / make sure inside fan and under neath fan are going . re ck control settings . .. if problem does't go away . then look at control ..
Jul 29, 2010 | Frigidaire Refrigerators
FROZEN WATER FILTER - UNRELIABLE TEMPERATURES
About the dual water control valve the side that feeds the ice maker could be defective. Fill the ice maker with tap water and let freeze. If it dumps and does not refill the water control valve will need replaced. Here is a link to the water control valve.
WR57X10032 Water Control Valve
As far as the temperature control here is a link to the Temperature Control Here=>
WR55X10095 Temperature Board Encoder Below are some photos. If I can help answer any questions let me know, Sea Breeze appliancepartsse@yahoo.com 6b49f39.jpg053ba1a.jpg
Jul 28, 2009 | GE Profile Arctica Stainless Steel Top...
Ice maker not making ice
Try changing the filter; our refrigerator did the same thing.
Jul 17, 2009 | Frigidaire FRS6R5EMB Side by Side...
Frosty Ice dispenser
you need the flap in the dispenser replaced ,,, you can get a door flap kit to fix it ,,, i know cause i still have one here from when i closed my shop ,,, if flap isnt closing tight the air goes in and it frost up the opening and dispenser / larry
Dec 08, 2008 | Frigidaire FRS3R5EMB Side by Side...
Water dispenser and Ice Maker
it might be your selenoid that closes the ice door in the chute but the water thing is says another thing might be wrong if you need service call 562-688-3627
Oct 10, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Frigidaire Refrigerator - Model # FRS26ZSG
The housing is probably cracked due to it freezing.
Dec 02, 2007 | Frigidaire FRS3R5EMB Side by Side...
Refrigerators Logo
Top Frigidaire Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
