Question about Cst Berger 56DGT10 5Inch Digital Transit with Vertical Tilt Sensor
What do a reading- E05 mean when the instrument is turned on,this do not allow any other readings to be done and will not go off .
    Scholar:
  • 87 Answers
E-05 I believe is a Horizontal angle reading error. There is nothing that you can do to fix it yourself, it will either need parts or it's signals aligned, probably both. You'll have to find a repair shop to send it to. I would recommend making sure they can fix these in house, because this is the type of thing a lot of shops send out, and that will inflate your costs.
Posted on Dec 13, 2014
What does error code E05-73 on my Panasonic DP-C263 mean and how can I fix it?
E5-73 is a HDD Abnormal Operation. First try turning the system off, counting to 30 and turning it back on. If it persists you want to check the HDD connections. May be a failed HDD. Panasonics exact answer is:
1. HDD connector is disconnected.
2. SC connector is disconnected.
3. HDD is defective.
4. SC PCB is defective.
Apr 10, 2012 | Office Equipment & Supplies
I have e05 message then an err 002 message, not sure how to fix. Is it possible the prongs are bent were the CF vard is input
Error 002 says memory card is full. Try to delete the card or reformat the card and observe
if camera wont allow to format the card. Try plugging it to a computer or laptop that hs Memory card slot and can read SD/MMC cards and format the card from the laptop
Jan 08, 2011 | Canon Rebel XT / EOS 350D Digital Camera
What does an E05 message mean? Purchased summer
All I can tell you is that my Toastmaster instruction book contains the same types of warnings.
E-01, just means the oven is too hot, but warnings E-02 , 03,04,05 and 08 all say you should unplug the machine and call the manufacturer....Sorry for the bad news....
Nov 22, 2010 | Breadman TR888 Corner Bakery Bread Maker
E05 error message & Service light on What does this mean? Is it something that can be fixed easily?
E05 is Ignition / Flame Failure in this model.
The most common cause of this is a bad ignitor, but can also be a bad flame sensor or ignition module.
Here is a link to the original manual with a very good service and troubleshooting section to accurately describe how to do this. I will put a simpleanswer on here, but it might be neccessary to do some reading too.
Turn off power to heater.
remove both front doors to compartment
Turn on power to heater.
Make sure the mode is set to pool/spa on.
turn temperature up to desired
within 30 seconds the fan should come on.
once the "thermostat" light comes on in the front LCD then pay attention to the ignitor
The ignitor should now be glowing. (if ignitor dosent glow, repeat this process and use a multimeter to ensure power is getting to the ignitor)ignitor part number is 471602
after 30 more seconds you should hear a little "pop" coming from the gas valve.
This is the gas valve opening to try to ignite. If the ignitor is working and the burner ignites, and then goes off with an E05 code, then this would indicate a bad flame sensor (part number 471603)
in rare cases, this code can be tripped by a lose wire on either of these parts.
The parts diagram in the manual on pages 33-34 will help to guide you where to look for these parts. It is always best to familiarize yourself with the heater before work is done.
Link for manual : http://www.pentairpool.com/pdfs/MiniMaxNTOM.pdf
If this post has helped please rate the post positively
if you need more assistance e-mail me @ adamh@newconceptchem.com
Nov 02, 2010 | Pentair Minimax NT Heater
After inserting into ear and press button to take the temperature it is reading POS. What does this mean?
POS means "Positioning" problem. Make sure that the instrument is inserted into the canal correctly or you will get this error reading. take care!!! Guy
Sep 08, 2010 | Health & Beauty
Hot tub heats from 85 to 98, then E05 message. Max setting is 104. It's run for 2 years with no issues getting to 102-104. I have the Pentair manual, troubleshooting chart, but wanted to see if anyone had...
Could be the temp sensor about 50-60 bucks, the book will say the board about 350-500 bucks. Try the temp sensor first. If it's reading over what the water is then that is probally the problem.
Jun 27, 2010 | Pentair Mastertemp Pool & Spa Heater Dual...
What does error code E05-11 mean?
there is a communication error on the device most propably caused by a problem with the large capacity tray feed unit loom. there is a techinical update for this problem and you would need a technician to attend.
May 15, 2010 | Panasonic Workio DP-4530 Copier
I have a Pentair Mastertemp 250 pool heater with an error message E05. What does this mean?
This is an ignition flame falure code. Could be you don't have gas getting to the pilot, no spark to ignite the pilot or your ignition is not reading the flame. Sorry to say but it's probally time to get the pool guy out to look at it. Good luck.
Apr 15, 2010 | Pentair Mastertemp Heater
switch off then on, pull top cassette out slightly. this will provide a temporary solution. a service technician will need to see the machine.
Mar 29, 2010 | Panasonic Workio DP-4530 Copier
I have a E22078 Wind Vane. How do I check the wiring continuity at the cockpit without climbing the mast? Can I use a multimeter to read impedance up to the wind instrument?
You can read the motor/generator windings with a volt ohm meater. Is it dc or ac? You should be able to read some voltage as long as it is turning? If it is a dc generator it will read dc voltage at the slightest of wind speed. If it is an ac generator it may have to be above 5 mph to get a reading. No reading could mean a broken wire.
Sep 10, 2009 | Raymarine St60 Wind Vane Ducer E22078
Cst Berger 56DGT10 5Inch Digital Transit with Vertical Tilt Sensor Logo
135 people viewed this question
Top Cst Berger Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Are you a Cst Berger Measuring Tool and Sensor Expert? Answer questions, earn points and help others
