Question about LG Dryers
The male and female parts of the door latch lack about 1/4 of an inch matching up. How do I adjust this?
  • LG Master
  • 8,220 Answers
Level the machine.
Posted on Dec 30, 2010
Hoover apollo deluxe dryer
Can you give a model number?
Jan 30, 2014 | Dryers
Kenmore he2 electric dryer
Most of them dryer door latch come in 2 parts male and female. Yank the female out the frame with pliers, the new female snaps in place. The only thang ya can screw up is getting the male mounted sideways so pay attention when installing it to the door. The part is
Part Number 306436 (AP4037288) replaces 19950209, 3-13912, 3-6436, 313912, 33001791, 3472, AH2029855, EA2029855, PS2029855, R0601523, W10116757, Y313912.
Read more: http://www.appliancepartspros.com/whirlpool-dryer-door-latch-306436-ap4037288.html#ixzz2r9VW52Ec
Jan 22, 2014 | Dryers
How do you use the mixer with a regular combo amp and stereo mic cable?
This is not hard to do, but it will require some adapters. Hosa company makes adapters to accomplish this. For example, if your Stereo mic has "1/4 inch male phone plugs" Hosa makes and adapter that has 1/4 inch female plug to Male XLR connectors. The Mackie, and just about every mixer in the world these days has Female XLR connectors for it's microphone inputs. So that will handle tha.
I'm not sure what you mean by the "combo" amp. If it has XLR inputs you can use Tip Ring Sleve male output jacks to the output. If your amp as conventional 1/4 inch female input jacks. Than a simple
1/4 inch Male to Male Guitar Cable will work fine. DON'T USE A SPEAKER CABLE as it is uninsulated and you will get 60Hz hum.
I hope this helps,
That looks like a great quality mixer you have!
Happy New Year,
Mark
Jan 01, 2011 | Mackie 402vlz3 Mixer 402vlz3 402vlz3 Vlz...
I have front loader dryer and the door is popping
Buy door latch kit from parts supplier. Comes with male and female parts of latch. Replace female part first and see if problem correct. Replace male if necessary. Don't worry if parts break off and fall inside while removing old pieces.
Kit is very inexpensive. If after replacing both parts your door still pops open check to make sure door is not sprung. To do this place a known straight edge across center of door from left to right and be sure there are no gaps between door panel and straight edge. If no gaps, replace hinges. They are likely bent.
Sep 30, 2009 | Kenmore Dryers
REPLACMENT CD LID LATCH FOR DURABRAND MOD. CD-1493
http://cgi.ebay.com/CD-DOOR-LID-LATCH-LOCKING-DEVICE-STEREO-BOOMBOX-PART_W0QQitemZ220225587206QQihZ012QQcategoryZ48626QQtcZphotoQQcmdZViewItem
Dec 20, 2008 | Durabrand CD Player with Cassette...
Door won't fully latch, light stays on, dryer won't function
There is typically a small plastic piece that catches the door and keeps it latched. The door has the male side and the frame of the dryer has the female side.
Either the male part on the door has broken off (or bent) or the the female part on the frame has broken. Replace this part and you'll be back in business. It is typically called a door latch and it comes with both the male and female parts.
Here is a picture
of a typical one.
Sep 22, 2008 | Dryers
Washer front loader
Does your model have a Male Female latch, where the femal receptor of the male plug is plastic?
Regards,
Worldvet
Sep 06, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Spring came off freezer door on chefmate RS-06DR. Don't know to attache spring to freezer and door
I had that same issue - a little tricky to describe the fix, but here goes (very non-technical terms used here):
1) take the freezer door off if it hasn't already fallen off
2) unscrew the single screw that holds the plate (that the freezer door attaches to), onto the interior side wall of the fridge.
3) gentle ease the plate away from the fridge wall. It has some plugs that expand to keep in snug to the wall. Now that the plate is off you can work more easily with the spring and door.
4) The spring has 3 parts, the hockey stick end, the spring tube in the middle, and the u-shaped end. The door has a longer top guide (male) and a lower, shorter guide (male), and a tiny hole about 1/2 inch from the top guide. The plate has a bottom bracket (female), a top hole (female), and the top ledge that contains the top hole.
5) insert the hockey stick end of the spring into the tiny hole of the door while fitting the spring tube over the doors top male guide.
6) (this is the tricky part) - force the u-shaped end of the spring so it straddles the top ledge of the plate so that one part of the wire is above the plate and one part of the wire in below the plate.
7) while doing #6, the top male guide of the door should be inserted into the top female hole of the plate
8) snap the lower male guide of the door onto the female guide of the plate
9) you now have the door assembly intact. gently push the plugs of the plate back into the side of the fridge and screw the screw in.
It took me awhile to figure out, and the above instructions are from memory so if I got it a little wrong, you'll hopefully be able to figure it out. The keys were understanding where the spring fit and taking the plate off the fridge. Good luck.
Apr 28, 2008 | Refrigerators
Dryers Logo
60 people viewed this question
Top LG Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Mike
Mike
Are you a LG Dryer Expert? Answer questions, earn points and help others
