Question about Weller 8200 Soldering Gun
Which trigger position activates 100 watts - Weller 8200 Soldering Gun
    Brigadier General:
  • 4,088 Answers
The first position is 100 watts, all the way back is 140 watts.
Posted on Jan 08, 2011
  • drallim Jan 09, 2011
    You can tell when the gun is on higher power because the lamp will get brighter.
  • Kevin Weaver Sep 19, 2017
    How about changing the dual heat trigger over to a toggle switch. If eliminating the lower heat is easier, ok. Having issues with the copper connection plates making contact.
Error code c4
It's either the micro-switch that trigger the needle positioning gear is jammed, and or the plastic gear probably missing some tooth that fails to triggers the micro switch to initialize when you turn on the unit.
Mar 18, 2014 | Singer 5500 Fashion Mate Sewing Machine...
4 ohm and 8 ohm speakers
You can plug in higher ohm speakers , the higher the ohm the higher the resistance is, it is a danger when you plug lower ohm speakers into a higer ohm Amp , at a high volume that will cause them to blow , the center speaker would be fine to use a higer ohm speaker , your best choice is to buy a Active Subwoofer, which means the sub has it's own power supply , and u can blast the thing as much as u like , thn u can turn the bass down on all the other speaker's so u can play it louder , and have the sub turned up has high as u like , this is the best way to get great sound with high volume , buy a Active sub woofer , any active subwoofer is ok , a active sub woofer has its own volume and inputs on the speaker ,
Dec 09, 2007 | Audio Players & Recorders
Need DC car adapter for Duracell powersource mobile 100
the positive pin is the one to the right when looking at the power connector with the mobile 100 standing up correctly, the negative is the one at the far left. I made mine start charging this way: Still don't know what the middle pin is for. Just make your own cable out of an old car plug and possiblly a pc power source connector. it's not that difficult.
Apr 20, 2013 | Xantrex Technology Duracell Powersource...
Does peak 100 watt inverter have a fuse inside? It is brand new & i can't make it active.
yes it does have a fuse inside where you plug it in the lighter should have a metel tip on the end will be spring and fuse inside behind metal tip
Jul 04, 2011 | Peak Performance Peak PKC0AM 100 Watt...
A 40 W fluorescent lamp gives out more light than a 4o W filament bulb.explain whether the fluorescent lamp is actually using electrical energy at the same rate as the filament bulb??
The lamps are both using 40 watts of energy, but the fluorescent lamp gives more lumens (visible light measurement) than the incandescent.
Fluorescent gives at least 5000 lumens for 100 watts.
Incandescent gives 1750 lumens for 100 watts.
You can see that if you had a 100 watt incandescent, it would be 1750 and you would only need 35 watts of flourescent.
Gary
Feb 19, 2011 | Vacuums
I have a 1000 Watt Inverter, along with a regular car battery when the electricity goes out; Question: Can I use the 1000 Watt inverter and connect a 100 amp, deep cycle battery? I use regular house...
Yes, just be sure connections are heavy enough wire, and obviously the inverter uses 12 vdc input. Hook jumper wires positive to positive, negative to negative, on all 12 volt batteries. Deep cycle batteries will work better than car batteries. Just remember, when re-charging them, that they last longer when charged slowly, so don't use a high amp setting on charger and to monitor them closely, and do it in a well ventilated area, away from any ignition sources.
Apr 14, 2010 | Schumacher 1000 Watt Inverter with 2 GA....
Camera taking pictures of nothing.
The sensor will detect movement up to 45 feet...If there are trees blowing in the wind it will trigger the camera...
You will have to relocate the camera position....
Jan 11, 2010 | Bushnell Trail Sentry 11-9200 Digital...
Generator stopped producing electricity
if the generator has been sitting for a while you might have to excite the magnets to start producing power. plug in a reversible drill and with the generator running turn the drill in the reverse direction by hand while holding the trigger in the forward position.
Mar 24, 2009 | Yamaha 4500 Watt Electric Start Generator...
Charger Voltage and Watt Differences
it hardly matters if u are using a 90 watt adapter instead of a 65watt
it will charger the battery much more faster
so you can use it
it should power on your system without the battery.... just check that first
Jun 07, 2008 | HP Compaq Presario C304NR Notebook
Combining an integrated receiver and an external amp.
yes, you are "forgoing the 100 Watts of my integrated receiver and now just using the 100 watts from the external amp"
Jun 03, 2007 | Home Theater Direct MA-1235 Amplifier
Weller 8200 Soldering Gun Logo
578 people viewed this question
Top Weller Welding Tools Experts
Lawrence Oravetz
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Weller Welding Tool Expert? Answer questions, earn points and help others
