I want to play bookworm on line for free on my new I pad,I can do this on my computer at work. how come I can,t om my own I Pad
    President:
  • 1,102 Answers
Since the game you want to play is on the internet, your Ipad needs to connect to a wireless network if it is WiFi enabled, otherwise you will need to have a "data" plan for it.
Posted on Dec 30, 2010
How thick is the lining on a new brake shoe
Lining thickness is dependent on a few factors. A. Is your lining bonded to the shoe or pad, or is it Rivited to the shoe or pad? B. What is the application? Lining thickness is determined ultimatley by the manufacturer. Generally speaking on Automotive and light truck applications new lining for brake shoes is between 6/32nds and 12/32nds of an inch. Add a couple 32nds if rivited. On front brake pads the lining is much thicker when new. On average a new brake pad can have lining between 10/32nds to 18/32nds. Pads are in need of replacement when bonded lining has worn to 2/32nd and rivited lining has worn to 3/32nds since the rivet head can come in contact with the disc brake rotor or drum at 1/32nds. Lining can also break free from the pad or shoe when they get that low due to rotor or drum out-of-round. This can cause lining to break free from the pad or shoe and cause dmage to the drum or rotor surface. When replacing brakes, its always good to have drums or rotors machined or replaced. For rotors, there are three specs to take into consideration. 1. Minimium machining thickness. If rotors are machined beyond their reccomended minimium machining they will warp due to heat. This warping will eventually lead to brake pedal pulsation. 2. Run-out; Run-out is measured using a dial micrometer and usually .003 to .005 of an inch is considered excessive. 3. Material Thickness Variation; or parralleism is measure with a micrometer. .0003 to .0005 ten thousandths of an inch is considered excessive. It is extremly hard to find a rotor that will pass all three of these measurements. If someone tells you the rotors do not need to be machined because they "look good", don't trust them because they don't know what they are talking about. Rotor condition can not be determined by the human eye. Drums have a maximium diameter they can not exceed, as well as an out-of-round specification as well. A good brake job will always have drums and rotors either machined or replaced. Money can be saved if they can be machined as it it cheaper to machine than replace.
Nov 28, 2014 | Cars & Trucks
The cursor jumps backward in text. It jumps several lines up and down.It also does not respond to a simple left tap when I need it to open or close wish to delete something. I am not accidently doing...
Replace the mouse with a known good working one.
If you are not using a mouse (bad news) the touch pad may be failing.
In that case, an easy test and fix is to disable it in "Control Panel" then install a mouse in the USB Port.
If the problem is corrected then it is your touch pad.
Here is a link to the manual from Dell. FREE!
http://support.dell.com/support/edocs/systems/ins6000/en/om/D5181bk5.pdf
See Page 42 on disabling the Touch Pad.
Go to EBay and insert "6000 Dell Inspiron touch pad". It's cheap but difficult to replace.
Jul 24, 2011 | Dell Inspiron 6000 Notebook
I have a dell xps M1330. Its mouse pad is behaving weird. If I try using it, it doesnt work but if I keep holding a shortcut key(play/stop/volume keys) while using the mouse pad it works fine. Any help?
hi,
your mouse pad dose not connect to the ground of device so when you keep and hold any
shortcut of keyboard , this connection done , and mouse pad work.
for this you (if you can) or a technician must remove the keyboard and change the flat cable
between mouse pad and devise .
good luck
gorbesia
Jun 19, 2011 | Dell XPS M1330 Laptop
I need the free registration code for bookworm adventure deluxe
i need the order number and registration code of bookworm adventure deluxe
Dec 19, 2010 | Knowledge Adventure Bookworm Adventures...
Touch pad faulty and cursor jumps and cannot read emails, or type replies, using external mouse, but cursor will wandering. Less tha one year old.
Clean your Pad with a moist wet tissue and dry.
In Control Panel -> Devices manager -> uninstall the mouse/pad driver and either use detect new plug-and-play hardware via the top of the tree in the device manager listing (eg. you Computer name) context menu or simply reboot to force a new re-install of the driver for your Pad and Mouse and see if it solves the problem.
If your Pad is the Synaptic type, install your Netbook driver for the Pad.
Hope that re-installing the driver and Pad utility solve your issue let me know how you go.
ps. Worst case, your Aspire One should still be under manufacturer warranty.
Sep 27, 2010 | Acer Aspire One PC Notebook
It hooks up to my labtop computer but it won't play in any of my games
you need to install drivers for it and go to the web site that sells it and you can download them for free. then you have to calibrate all buttons with the instructions give after you have loaded the drivers for the game pad.
Feb 01, 2010 | Saitek Cyborg Rumble Pad Game Pad
Konami wii dance pad left & right arrows not always working
This is typical. What normally happens is the pad is bunched while playing. It slides around on the floor, and the better the dancers are at playing, the more wear and tear the internal components have to endure. Finally something goes wrong inside. If you're serious about dancing, you have two choices. Either buy what's called a metal dance pad (expensive), or mod a plastic one (preferably brand new, only played gingerly first to make sure it's working. The best place to find suggestions on modding is the forum on ddrfreak.com
Feb 13, 2009 | ezGear ezDance Dance Pad for Wii
Signature pad writes straight line instead of signature
you can either try to unplug the pad for a minute. or uninstall the pad and then reinstall it again. and if that doesnt work then someone watered or damaged your pad some how.so you would have to buy a new
Dec 01, 2008 | Computers & Internet
How to play ps2 games on pc
there is the software called pcsx2 software which allow to play ps2 cds on pc
Dec 18, 2007 | Computers & Internet
Computers & Internet Logo
52 people viewed this question
David Payne
David Payne
