Question about Dryers
I am trying to replace the heating element in a kenmore dryer moodel number 417.83042300. How is this done?
  • Dryers Master
  • 8,220 Answers
Posted on Dec 30, 2010
Replace the heating element
here are some results I found on youtube one might help you see how it's done
http://www.youtube.com/results?search_query=Kenmore+HE5+Electric+Dryer+Replace+the+heating+element
Nov 24, 2014 | Kenmore HE5 Electric Dryer
Dryer not heating
Check Heating elements if ok check the in line fuse that go to drying element and if it open replace it and clean filter and check pipe that blow out side make sure it not stop up because if in line fuse is open stop up filter and pipe that blow air out side will cause the heating element in fuse to open up. And check for lose wire going to element to.
May 30, 2014 | Kenmore 98702 Stacked Washer/Dryer
Kenmore dryer will not heat up
I couln't bring anything up using the model number you gave, but generally an electric dryer will have heat if the heating element gets the signal from the switches and it is not open.
If everything works beside the heat, then I would make sure that the heat selector switch is operational and if it is then to replace the heater element.
Jun 17, 2011 | Kenmore 600 6963 Electric Dryer
My kenmore dryer is blowing only cold air. What is wroge? We already checked the heating element and timer...???? This dryer is only 4 years old.
The heating circuit is composed not only by the heating element and the timer but also with a high-limit thermostat, a thermal cut-off, and a cycling thermostat. The high-limit thermostat and the thermal cut-off are both mounted on the heater housing to monitor and regulate the heater temperature while the cycling thermostat is mounted on the blower housing to monitor and regulate the temperature of the exhaust air.
All of these components are wired in series and a failure in any of them results in the dryer not heating. The proper troubleshooting is by checking the continuity of each of these components with a volt-ohmmeter and replacing the ones found without continuity (open).
A continuity check can also be done by bypassing each of the three components, never the heating element, and then starting the dryer. The dryer should heat, otherwise the problem is somewhere in the timer, the heating element, or the centrifugal switch within the motor. When the dryer heats up, unplug it then un-bypass one of the bypassed components and start the dryer. If the dryer stops heating then you have found the failed component; replace it. If the dryer does not stop heating, do the same to the remaining components until you find the failed one. Just make sure the dryer is unplugged before touching the components.
Replace both the high-limit thermostat and the thermal cut-off if any of them has failed. Indicate the exact model number of the dryer if you need further or more specific advice.
Jun 12, 2010 | Kenmore 63942 Dryer
How to replace a heating element for a kenmore
Hello there
i am posting instruction for this dryer below
(For some help with that, and before buying an element you might not need, please see my article entitled 'The No-Heat Dryer'). Note: Always check airflow out the vent before firing up your dryer with its new element. A partially clogged vent can burn out an element - even a brand new one - fast! Just run the dryer on the 'no-heat' or 'fluff' setting, then go outside and check for a good strong flow of air from the vent hood. If there's any doubt, Whirlpool makes a cool little airflow test kit for their dryers that will tell you for sure, from inside.
There are basically 3 styles of heating elements in use for these dryers.
1) Most common is the 'long' one, part number 4391960, accessed from the back of the dryer, and which looks like this:
wpl%204391960%20el.jpg To replace this one, power down and pull the dryer out and remove the back cover. You'll see a long, vertical 'can' on the right side, with the element coil inside. To remove this can, simply pull the element wires (can be hard to remove; I use a long-nosed pliers), the limit thermostat wires just above them, and the thermal fuse wires if equipped (this is a little device mounted high on the side of the can, with two wires attached). One 5/16" hex screw at the top and a little strap holds the can in place. Remove this screw (You can look through the small hole that lines up with it, originally to poke a long screwdriver through), tip the can rearward, and lift it off its two bottom hooks. Once the can's out, one screw holds the element inside. Remove it, and the old element coil will slide out. Slide the new one in, reverse this process, and you're done!
Nov 13, 2009 | Kenmore Dryers
Heating element quit working on model # ler4624bw2 Whirlpool electric dryer
Hello there
Here is a couple of links that will help you replace the heating element along with some manufactures that can also help ok?
Best regardss michael
  1. Whirlpool Dryer Heating Element 279838 Kenmore | Estate ...unknown.gif ... REL4632DW0,LER6638DW0 LER4624BW2,LER7646AW2,KEYS677EZ0,REL4632DW1,LER6638DW1 ... Model: Whirlpool | Kenmore | Sears | Roper | Kitchen Aid | Estate. Shipping ...whirlpoolpartssurplus.com/cart/whirlpool-dryer-electric-h...
  1. How to Replace Your Electric Dryer's Heating Elementunknown.gif How to Replace Your Whirlpool, Kenmore, Roper, or Kitchenaid. Electric Dryer's Heating Element ... 3 styles of heating elements in use for these dryers. ...www.davesrepair.com/DIYhelp/DIYreplacingWPLdryels.htm - Cached
  2. How to Replace the Heating Element in A Whirlpool Dishwasherunknown.gif How to article - how to replace the heating element in a whirlpool dishwasher. When your dishwasher heating element goes bad, your dishes will not dry quickly. Before...ehow.com/how_5337380_replace-heating-element-whirlpool-di...
  3. How to Replace the Heating Element in A Whirlpool Ovenunknown.gif How to article - how to replace the heating element in a whirlpool oven. If the lower heating element in your Whirlpool oven no longer gets hot, or if you n
Oct 15, 2009 | Whirlpool Dryers
DRYER HEATING ELEMENT
Kenmore dryers are manufactured by Whirlpool. In many cases the part numbers are identical between model numbers. Look at the dimensions of the heating element and compare part numbers. Chances are, the parts are identical.
Jun 29, 2009 | Dryers
only 2 things can be wrong, the heater element is toast or one of the safety thermostats is fried, most likely it is the heating element. make sure its well connected(while unplugged!!!)
Jun 14, 2009 | Kenmore 63942 Dryer
No heat in my stack-pak kenmore dryer. The element is ok and there are no broken cables/wires. 220 does come in to the unit and show up at the componets.
There is a thermal relay switch that is blown. Replace it.
Model number please and I will give you the part number.
May 23, 2009 | Kenmore Dryers
Dryers Logo
Top Dryers Experts
