Question about Officina Del Tempo Watches
It seems that I have to replace my watch battery every month. Can you suggest what the problem may be? Thanks
  • 76 Answers
The circuit may have some fault,or,the battery must not having sufficient charge
Posted on Dec 30, 2010
Timex electric watch not running
Hi Mark,
It appears to be a battery problem. Have you changed the battery recently? How have you checked the battery? I suggest you check the battery's voltage, even if it is a new, replaced battery.
You need to be sure the battery is not the problem before looking elsewhere.
Need more detail if this does not help, including the model of watch. Also how long has this problem existed, and when did you notice a change - was there a specific time/event?
Feb 01, 2014 | Timex Watches
Polar ft40 watch doesnt work. I have replaced the battery and nothing happens.
This heart rate monitor has a generic flaw with the sensor. The touch sensor fails after a few months of use. It is not a battery issue. Return to where you purchased it. Buy another brand. All of the drug stores carry this watch which has an abnormal return rate. The sensor fails after a few months while the watch function is fine. Seems like planned obsolescence.
Sep 07, 2011 | Polar Electro Polar FT40F heart rate...
Womens Tide 3G FS80963 Watch My watch went blank. I've had it for only about 6 months- so I don't think it is the battery. I had just checked the time in my car, pressing the light button and it was...
Your battery may indeed be dead. Watches sometimes sit on store shelves for months and even years before you get them. If you have a stuck button it may be the light button and may have prematurely drained your battery. Either way a watchmaker would be able to determine the problem.
Mar 09, 2011 | Freestyle Tide 3.0G Black FS80963 Watch...
Seiko SGF204 second hand hesitates or jumps a second and looses probably 10 minutes an hour. Any suggestions would be appreciated. Thanks
When the watch jumps a second or seems to stop then tick twice, it indicates that the battery is low. You will need to take your watch to have the battery replaced.
Feb 28, 2011 | Seiko SGF204 Wrist Watch
Why would this watch loose time and have to be reset???..........repeatedly.
I had the same problem sometime ago but with a fossil. I had the battery replaced several times in the matter of a couple of months. It seemed to have happened during the very cold months. I also found that I put my watch in the same pocket I put my Iphone in too. I'm not sure if there was a relevance but after I stopped, the watch seemed to fix itself.
Jan 30, 2011 | Pulsar PXX006 Wrist Watch
I have had my Timex about 12 months and it has started losing about 15 minutes out of 24 hours. Could it be the battery? If not how do I fix the problem?
Sounds like a classic battery issue.
I suggest taking the watch into your local watch/ jewelry repair and have them replace the battery and test it. If it isn't the battery they should be able to tell you why you are losing so much time.
Dec 06, 2010 | Timex 27191 Wristwatch
I brought a set of watches mens and ladies gold colour from QVC the bstteries needs replacing have had them about 18 months - can you do anything for me. thanks Mary
I can only suggest that you call around your area where you live and see who replaces batteries. Try your local mall....most malls have a watch repair kiosk or call a local jeweler who sells watches.
If no place local, you can send them to an on-line repair such as the one in the following link: Good luck.
http://jjwatchrepair.com/
Aug 21, 2010 | Marcel Drucker Watches
Stuck second hand
You need a new battery, as there is not enough power to move both gears. You can send it back to Wenger and get battery replaced or just pop into your nearest watch repair shop and get it replaced. It will cost you $5.oo and will be done in 10 minutes time instead of months of waiting it back from Wenger. Rate me, plz.
Feb 26, 2010 | Swiss Army Wenger Commando 70728 Wrist...
I am writing to file a complaint regarding my wife's watch. The watch was purchased Dec. 2008. It stopped working twelve months later. The limited warranty stated that the watch would be repaired for...
Warranties only cover a failure due to manufacture. Unfortunately dead batteries are not covered by any maker as there is nothing wrong with a watch if the battery fails.
I year does seem a little short. Perhaps it was running for a time before you bought it? Who knows!
Feb 16, 2010 | Watches
I have gone through 3 different watches, 2 fossils and one Bulova. All of them would just stop after a couple of months. I would replace batteries, then they would stop again. Is there any truth to the...
This is not a myth, but reality. Every living thing has it's own electric field and so do the humans. The difference is in density of that field - some has stronger, some weaker. And this is the cause of fast battery discharge and mciromotor stoping. Very few people has this field so dense, that the battery driven watch stops as soon as this person touches the watch. Most common is the case when the wearer of the watch needs to replace watch battery very frequently,so, I suggest you are one of them.
Consider of buying an automatic mechanical watch (spring driven). These watches are more expensive then their battery driven counterparts, but they can last for generations if looked after.
Do not buy kinetic or solar powered watches as you will expierence the same struggle as with battery driven watch.
Rate me, please.
Mar 19, 2009 | Watches
Watches Logo
195 people viewed this question
Top Officina Del Tempo Watches Experts
Ansel Alberto
Ansel Alberto
Are you an Officina Del Tempo Watch Expert? Answer questions, earn points and help others
