Question about Friedrich QuietMaster Electric SS10J10AR Air Conditioner
Water Leaking into room
Water drips into room from air conditioner. drain must be clogged. how do I unclog it?
  • 182 Answers
If you can see a drain blow backwards through it.It may also just be angled the wrong direction(the whole unit).If you cant see an external drain,unplug the unit and take the cover off .you should then be able to clear it.
Posted on Jul 08, 2008
Condenser leaking
No reason to disconnect. Just use a snake to unclog the pipe.
Sep 07, 2014 | Heating & Cooling
My handler is leaking. The drip pan has a little water in it, I see a slow drip outside during operation. Near the blower water is coming out of one of the air ducts.
Hello, most likely you have a clogged condensate drain or a cracked or leaking condensate pan. First use a wet/dry vac on the outlet of the drain line, this will usually unclog the line. If the line appears to be clean then the pan will have to be replaced.
Sep 27, 2011 | Heating & Cooling
I have a Haier Air Conditioner window unit that is leaking inside the house. What are some possible causes and solutions?
There are basically 2 causes:
1. The rear of the AC unit is not tilted down enough, so that water in the drip pan flows to the drain hole in the rear of the drip pan. The general rule of thumb for rear downward titl is 1/4" to 1/2".
2. The drain hole in the drip pan, near the rear of the unit is clogged. Locating the clogged hole can be a challenge, as the clog will blend in with the drain hole. Patience & persistence are needed in locating it. A pipe cleaner works well to clear the clog from the hole.
Hope this helps you and thanks for choosing FixYa.
Aug 17, 2011 | Haier (HPE09XC6) Air Conditioner
Water leaking inside home and window seal
The problem you're having can be caused by 2 things. The drain hole in the drip pan is clogged and/or the rear of the unit is not tilted down enough, so the water can flow to the drain hole, near the rear of the drip pan. The general rule of thumb for the downward tilt is 1/4" to 1/2".
Finding the drain hole can be a challenge at times, as the clog can blend in with the hole. Patience & persistence are what's need in locating it. A piper cleaner works well to clear the hole.
Aug 07, 2011 | Kenmore Single Room Air Conditioner
My air conditioner is leaking water from the front side just below the control panel....what is causing this?
2 things generally cause this.
1. The rear of the unit is not tilted down enough for the water to flow to the drain hole in the drip pan.. 1/4' to 1/2" tilt is the general rule of thumb.
2. The drain hole at the rear of the drip pan is clogged and needs to be cleared. It can be hard to find, as the clog will blend in with the drain. Use a pipe cleaner to clear the clog.
Hope this helped you to troubleshoot and solve the problem. Thanks for choosing FixYa.
Aug 02, 2011 | Fedders AER08F2A Air Conditioner
It spits water out of the vent
sounds like the drain my be clogged, look outside and see if water is dripping, if not then try to unclog drain hole.
Aug 10, 2010 | Haier hwr10xc6 Air Conditioner
It is running well but leaking water...Is there suppose to be a drain?
The leaking water is the condensate from the evaporator coil produced as the unit dehumidifies the air.
The condensate should drip into a pan which has a drain which can be directed to the desired location (may need to add a drain hose to the drip pan).
The drain may be just clogged -- hope this helps you investigate the situation.
Charlie
Aug 14, 2009 | Amana PTC123B35AJ Air Conditioner
Whirlpool Air Con Drainage issue
Yes, there should be a place for the condensate to drain outside. It's apparently clogged and the drip pan is overfilling. Look for a tube or an opening outside where the condensate should be exiting. This needs to be unclogged.
May 31, 2009 | Whirlpool Electronic Window Air...
Fujitsu wall mounted air conditioner leaks into the room
Make sure the unit is level, this is very important. Check for blocked drain tube, which runs from the bottom of the drain pan under the cold coil to the outside. Clear tube with a piece of coathanger wire, be gentle.
Jun 03, 2007 | Fujitsu 24C1 Air Conditioner
Friedrich QuietMaster Electric SS10J10AR Air Conditioner Logo
412 people viewed this question
Top Friedrich Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Bill Long
Michael Vincent Cruz
Are you a Friedrich Heating and Cooling Expert? Answer questions, earn points and help others
