Question about Garmin nuvi 650 GPS Receiver
Inpre boot I cant adjust.dot appears but no matter how I touch it nothing happens
  • Garmin Master
  • 2,130 Answers
This is a very common problem caused by a certain style of touchscreen that is being used.
The only way to fix this problem is to replace it with a style that does not have this problem.
Troubleshooting and more detailed information can be found here: http://www.sharc.net/gps_LCD_repair.htm
Sorry but there is just too much info to retype here.
Posted on Apr 12, 2011
What is wrong with the screen when it says to Touch Dot?
You can just use a plastic pen or anything with a nib to press it, instead of using your finger. After pressing 5 to 6 times it should work
Jul 16, 2014 | Garmin Nuvi 200 205 250 255 260 W
V.w. golf convertible 98.M300RC remote.
it may have to be coded to the car by a dealership
Apr 18, 2014 | 1995 Volkswagen Golf
Touch screen calibration
To calibrate the StreetPilot c-Series touchscreen, follow these steps: Begin with the device turned off and unplugged from a power source Power the device on and continue to hold the power button for 1 minute Release the power button when the screen displays "Press Dot" Accurately touch the dots as they appear The dots will change location A stylus or pencil eraser may be used to accurately touch the dots Touch OK when the "Calibration Complete" appears The touchscreen is now calibrated.
Oct 16, 2013 | Garmin StreetPilot C330 GPS Receiver
Dots appear on the touch screen
hi lea, does this dots and lines appears occasionally or it just stays there? because if its permanently there, then you might need to replace the lcd part of the lower screen (not the touch screen part) but if its occasionally, then try to see if it happens when your on the lowest brightness or highest brightness, if it is then you will have to adjust the variable resistor on the motherboard of the DS,let me know if you have to do this.
Dec 20, 2011 | Nintendo DS Lite Console
Red dot seems to disappear when you move the sight right to left or up and down.
You are simply moving the dot out of the field of view.
The Aimpoint is set up to allow you to hit now matter where in the field of view the dot appears. High, low, right, left, it doesn't matter. If you can place the dot on target, your bullet will hit where the dot appears. Too much angle away from the center will move the dot out of your field of view however, This is apparently what is happening to you.
Oct 10, 2010 | Aimpoint 10338 CompML2 4 MOA
My ipod touch wont let me type in my passcode when i try to open
You may need to reset
To reset the iPhone or iPod Touch, press and hold down the Sleep/Wake button and the Home button simultaneously at the same time for at least ten seconds, then the LCD display will clear and the Apple logo appears on the black background. When Apple logo appears, reset is done.
Sep 22, 2009 | Apple iPod touch
Touch screen does not work
1) Ensure that a cartridge is not inserted
2) Hold down the Hint button while turning the unit on
3) When the LEAPSTER menu screen appears, press the A button
4) Touch each of the crosshairs that appear with the stylus
5) Restart unit
Mar 22, 2009 | Leapster Learning System
My touch screen has froze up & know matter what i do i can't the proble
Assuming that you cannot switch it off and on again, try removing the battery for a couple of minutes before re installing. Failing that a cold reboot my work ..... with the unit switch off press and hold the bottom right corner of the touch screen and the press the power button. The Zumo splash screen should appear....continue to hold the botton right corner until the reset default screen instrution appear and follow them. This has work in the passed.
If you have recently download a latest software via the Garmin web updater this can sometimes cause conflicts and you may need to re-install a prervious version. from the Garmin link attached.
http://www.gpsinformation.org/perry/zumo/
Sep 07, 2008 | Garmin zumo 550 GPS Receiver
Garmin c330
Try to calibrate the touch screen. Push and hold the power button on until you see a white dot on the screen. This is the calibration mode. Touch the dot and another dot will apppear, now touch this dot again, keep doing this until the unit reboot.
If you touch the 1st dot and nothing happens then the digitizer on the LCD is dead. If the unit is still under warranty, get a RMA and return it to Garmin.
Dec 26, 2007 | Garmin StreetPilot C330 GPS Receiver
Garmin nuvi 650 GPS Receiver Logo
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
