Question about Whirlpool Duet GHW9150P Front Load Washer
Have a WGD 9400 SW Gas dryer. there seems to be very little heat in the drying process which is now taking forever. Any ideas.
  • 1,772 Answers
Sorry to read about your problem, I hope this helps you out.
Clean your dryer vents, and lint filters. You may need to clean vent from wall to outside. to test this.. unhook vent pipe from wall..and run dryer and see what happens. If the problem does not improve, you may have a defective heat coils.
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
2 Thumbs - Somewhat Helpful
Posted on Dec 30, 2010
Gas dryer heats at first then take forever to dry, auto dry setting does not advance
If it works to begin with and fails afterwards then that can only be them solenoids mounted on the gas assembly. Here is my home video which shows how to check and replace:
May 02, 2013 | Dryers
My dryer isn't drying like it should. It doesn't seem as hot as it use to be and it takes forever to get things dry. I'm not sure if it's lint build up or something more. Any help will be appreciated.
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101';';
May 01, 2011 | Magic Chef CYG4000AWW Gas Dryer
Do not seem to get hot enough takes forever to dry clothes
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Dec 23, 2010 | LG DLE2514 Electric Dryer
Whirlpool gas dryer Model wgd 5300 sq0 worked fine yesterday, dried some comforters and bedding. Today there is no heat, I don't think it is a lint problem, any ideas would be appreciated>
your glow rod,may be defective..this is like a pilot lite for the gas
I tried to help you. Please help me and Rate/Vote on my response, thanks and good luck
Dec 20, 2010 | Dryers
Does not dry thoroughly
Clean out the entire exhaust venting system. If a build up of lint is inside of it the moister sensor shuts down the heating process causing the time to take to dry clothes seem forever
Jun 13, 2010 | Bosch Nexxt 500 Dryer
Kenmore sreies 80 gas dryer, doesnt heat well'
replace the ignitor or the gas selinoids
Apr 20, 2010 | Kenmore 72802 Gas Dryer
Dryer taking too long to dry
If you can get the dryer outside, blow it out from the bottom with compressed air (using an air compressor or even a leaf blower). make sure the vent is clear and has no lint buildup. make sure the burner unit is also lint/dust free. If it is still heating, that is good news, and it is most likely a "breathing" issue. it also could be an issue with your gas pressure, however that is very unlikely. Best wishes in this project.
Oct 22, 2009 | Kenmore 73952 Gas Dryer
Whirlpool dryer has very little heat
Sounds like your not getting enough gas supply,there is a regulater that controls the flow of gas they can get carbon build-up and restrict the gas.You need to turn off your gas supply and unplug it,remove the regulator and clean the lines,or replace the part.
Hope this helped.Let me know by rating me or
for more help go to live chat.Thanks
Len West
Feb 16, 2009 | Whirlpool LER3622HQ Electric Portable...
Brand new dryer
try holding door switch down with your finger while pressing start button.if dryer starts then your door needs adjusting.
May 20, 2007 | Whirlpool GGW9200L Gas Dryer
Whirlpool Duet GHW9150P Front Load Washer Logo
59 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
