I HAVE A DYNEX SIRED KEDYBOARD AND TODAY IT STARTED NOT TO CONNECT TO THE COMUTER WHEN I PLUGGED IT INTO MY LAPTOP USB PORT. THE GREEN LIGHT COMES ON FOR HALF OF A SECOND, THEN GOES OUT.
    Sergeant:
  • 169 Answers
This problem happens when the mechanism of the keyboard is bad.so the advice is to change the keyboard.
Posted on Dec 30, 2010
How to connect mouse to computer
Hi there are two different ways in connecting a mouse on your computer, you can connect it to a usb port or PS/2 (green round port).
May 07, 2013 | Dynex Computers & Internet
I dont know how to install my mouse to my laptop. The laptop is an ASUS. please email me asap
You can only connect USB mouse to yout laptop. For USB mouse the driver is not needed. You can just plug in the USB cable of mouse in USB port and go ahead. Windows will install the relevant software automatically.
Thanks,
Amar
Sep 05, 2011 | Dynex Wireless Optical Laptop Mouse...
When i connect my laptop power pack/adaptor to a source of light the power light on the power pack comes on, but when i connect plug in the power pack/adaptor pin to the power inlet port at the back of the...
click start control panel administrive tools ,computer management ,device manager look through all of your devices if you see a yellow question mark?or exclamation mark ! or red x
right click to reinstall drivers or
if you can see your usb but its not working
ports(com&lpt)right click update driver
sometimes the wires inside the cable will be damaged due to bending or stretching or placing heavy equipment upon the cable,
just replace the cable of the hard disk, when you plugged the external disk drive you got that windows could recognize the USB device change the cable everything should work fine again,
check the USB leads that attach to the motherboard usually red-white-green-black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems also make sure the computers Ram and Cmos battery are securely seated
hope this helps
Jun 17, 2011 | Computers & Internet
Hello, I'd like to know why my Dynex Wireless N usb adapter keeps disconnecting from my laptop, to reconnect I have to unplug / plug back to get signal, then I get signal for a short period of time then...
Try turning off Wireless Zero Configuration,in services. & disable on startup. Start>>Run>>services.msc navigate down till you find it, double click & change.
Feb 10, 2010 | Dynex Enhanced Wireless-G USB 2.0 Network...
My dynex usb hub is not working
You need to unplug the power adapter from the wall, and disconnect the usb cord from the PC/laptop for at least 30 seconds. Then plug everything back in. Apparently this model suffers from static electricity from time to time. I have this hub also and it works every time.
Apr 06, 2009 | Dynex 4-Port USB 2.0 Hub
Cannot connect to internet using Dynex Wired Router
First, power down all equipment.
Second, plug in power to modem, let all the lights come on and boot up
Third, plug in the router power and let that boot up and the lights come on
Fourth, Plug in each pc to the ports labeled 1-4
The WAN port should be connected to the Modem also.
Mar 19, 2009 | Dynex 4-Port Ethernet Broadband Router...
Dynex wireless mouse DX-PWLMSE won't work
The mouse should be Plug and Play. Did you install the drivers before plugging the mouse's receiver in? The PC has to have the drivers first in order to take advantage of the Plug and Play capability. If you plugged the mouse's receiver in before installing the drivers, unplug the mouse receiver, uninstall the driver, reboot your PC, reinstall the driver, then plug the receiver in and you should be fine.
Otherwise, press the Connect button on the receiver first, and then the Connect button on the mouse, and that should establish the connection. You don't need to disable your touch pad in order to use the mouse.
Jan 22, 2009 | Dynex Wireless Keyboard/Optical Mouse...
My usb port light doesn't turn green
first check the usb driver is installed & usb in enabled in device manager
Dec 26, 2008 | Dynex 7-Port USB 2.0 Hub
Dynex wireless G router
When the installation software asked me if I performed the steps in the Quick Installation Guide, I just said yes. Here's what I had done prior (I'm not saying this is what the guide says to do, but, I was able to set up my DYNEX Wireless Enhanced G Router after having done these steps):
  1. Connected the power cable and plugged it in to the wall.
  2. Connected the Internet cable from my DSL modem to the Green port on the back of the router.
  3. Connected my PC using an RJ-45 cable to one of the blue ports on the back of the router.
Dec 10, 2007 | Computers & Internet
Computers & Internet Logo
21 people viewed this question
David Payne
David Payne
