Question about Matrix 226R (VPR226R) PC Desktop
I am having a problem with the display. It seems to flicker and become distorted and the cursor drags with a shadow. could this be my video card
  • 536 Answers
It could be your video card. To confirm, use a different monitor with your computer and see if the same problem happens with the other monitor.
If the other monitor works fine, then the problem is with the original monitor; otherwise its the video card.
If the video card is built-in to your motherboard, there's not much you can do to fix it. If it's a separate card, I would suggest taking out the video card, inspecting the connectors for debris, and then re-insert the card. This "reseating" of the card might resolve your problem.
Make sure that you disconnect the power cable from your computer to prevent you from electrocuting yourself.
Posted on Dec 30, 2010
Monitor distorts colors and goes out of sync horizontally after 15 min
they dont last forever... time for replacement as most are not user-serviceable..
Mar 08, 2014 | Dell UltraSharp 1905FP 19" LCD Monitor
Everytime i turn on my k42j laptop, screen becomes distorted ( multiple dots with different colors) then suddenly the display just disappear ( blockout).
It seems that either the display for the laptop is going, or the video card is. Is the computer's power light still lit when the display blacks-out?
Apr 22, 2013 | Computers & Internet
Horizontal line across screen, only when dragging over large areas with the cursor
Have you tried updating DirectX?
You can also try scanning your computer with RadarSync (for free) to see which drivers are outdated. You can then install the updates by searching for them using Google. But, if you want to let RadarSync update them automatically then you can buy the license.
David
Feb 21, 2013 | AOC Computers & Internet
Cursor and text jumps for dell inspiron 1150
Click the Windows "Start" button or press the "Windows" key. The "Start" menu opens. Type "Cursor blink" in the "Search programs and file" text box. A list opens. Click "Change Cursor Blink Rate." The "Keyboard Properties" window opens. Click the "Speed" tab. A list of options appears. The "Cursor Blink Rate" section shows a "Cursor Blink Rate" slider displaying a range from "None" to "Fast." Click and drag the slider button to the "None" area in the far left portion of the "Cursor Blink Rate" scale. Click "Apply." Click "OK." The cursor stops flickering on the screen.
Feb 04, 2013 | Dell Inspiron Computers & Internet
Logitech m 705 mouse pointer flickering
A list opens.
Click "Apply."
hope this helps
Sep 12, 2012 | Logitech M705 Wireless Marathon Mouse,...
The display on my laptop is blurry and has some type of distortion making it difficult to see (especially photos and videos). I've tried multiple resolution settings and none seem to resolve the issue.
Are you sure the video adapter card is OK? A low-end video card may not
have the bandwith necessary to support high refresh rates at high
resolution. Just because the card will *generate* a given mode doesn't mean
that it will work well. Try the following steps.
1. Reduce the refresh rate to 60 Hz The monitor may seem to flicker a
little, but don't worry about it.
2. If there was no change, the problem is likely in the monitor
3. If that improved the resolution, then try removing any monitor extender
cables and play with higher refresh rates again. If that fixes the probem,
great, otherwise
3. Replace the videa adapter card with a better one.
Oct 20, 2011 | HP Pavilion dv5-1125nr Notebook
X6000 white screen. distorted display at startup, with lines, flickering, hazy display, eventually becomes all white. Tried connecting to an external monitor, same result. Is this a video board issue? ...
1.your video card driver must have crashed try re-installing it !!
or
2.your video card must have failed !!try connecting your laptop to a CRT or LCD monitor and check it out !!! if you get the same thing in your CRT then its your video card change it if you want!!
Jun 15, 2011 | Computers & Internet
Heat from monitor
The monitor,screen,adapter or display of a computer is the primary user interface. Monitor problems are some of the most common computer problems since the voltages inside a monitor can be as high as 10 KV. Many of the problems can be fixed yourself by simply changing the settings but in a few cases you may have to either replace or repair the monitor.
google_protectAndRun("ads_core.google_render_ad", google_handleError, google_render_ad); How to troubleshoot and fix computer monitor/display problems
1. The monitor/display flickers
Check the refresh rate. If the refresh rate is 50 Hz/ 60Hz (depending on which country you stay), it can be affected by interference from electrical power signals like those from fluorescent lamps . Increasing the refresh rate to 72Hz is recommended , since higher refresh rates reduce eyestrain and headaches
2. The display works fine initially, then after some time there are black lines on the screen and then the display disappears
There is a problem with the copper windings in the CRT monitor which are getting heated. It is better to replace the monitor
3. For a new monitor, you get a blank screen or distorted image.
Many monitors, especially LCD monitors, can only handle resolutions which are less than the native resolution, so set the resolution at the native resolution only. The native resolution of a LCD display is lower for smaller LCD screen sizes, typically 1024 X 768 for 15" LCD. CRT monitors have a better resolution than LCD displays
4. The display on the monitor is not steady
This is a result of power system interference from users of the power grid, particularly UPS, power tools and heavy machinery. Try changing the position of the monitor.
5. There is a shadow on the images on the display
Try reducing the contrast setting on your monitor.
6. Monitor becomes blank occasionally
Could be a problem with the display card, check with another monitor. The monitor display cord and power cable should be fixed properly and there should be no loose connection.
7. Dark Spots on the Screen.
Move speakers,USB modem and other magnetic devices away from the monitor.
8. Incorrect Colors - red may become dark brown, blue becomes purple.
Check your video cables and connectors for bent or broken pins and wires. Sometimes there may be a problem with your display card, which can be retuned using a software available with monitor technicians.
9. Run Antivirus to scan corrupt software files.Virus cause distorted characters and images.
10. Set your monitor/display pixels to the software requirements. some softwares require higher pixels to run or to be displayed. some media players, web applications, video games applications and photo editors/view softwares have option to view photos on low or high quality
Jan 29, 2010 | Computers & Internet
SyncMaster 940B
Sounds like you have a video card problem. If it works on someone elses PC and not yours. Replacing this video card on your PC should fix it..
May 14, 2009 | Samsung SyncMaster 940B 19" LCD Monitor
Friend's Laptop Screen has become too dark to work with
You could have a defective screen - a defective inverter or a CCFL lamp.
To determine if you have a LCD screen or video card problem, read this and follow the instructions.
Defective CCFL backlight, it may have the following symptom:
  • Screen flashs on red/pink and off.
  • Picture stays on in red and slowly be come normal.
  • Picture flickering with dim display.
  • Picture flickering on and off.
All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp
Connect an external monitor to your laptop and power it up, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight.
Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out www.lcdparts.net for parts, repair service and DIY info.
Apr 24, 2009 | Toshiba Satellite U205-S5002 Notebook
Matrix 226R (VPR226R) PC Desktop Logo
Top Matrix Computers & Internet Experts
David Payne
David Payne
Are you a Matrix Computer and Internet Expert? Answer questions, earn points and help others
