Question about Maytag Dryers
Drier turns but no heat (electric drier) - Maytag Dryers
  • 1,772 Answers
Dsd
Sorry to read about your problem. Their is a 80% chance you have a defective heat coil or coils. or the heat selector switch is defective. in addition you may have a clogged dryer vent.
I suggest you place a call to a service company.
I tried to help you. Please help me and vote/rate this response thanks.
If you live in Denver area, I can help you.
Posted on Dec 30, 2010
Kenmore 500 dryer
If you mean that it is not heating and stays cool, most likely the pilot sensing thermocouple needs replacing (if you have a gas drier with a pilot light) or the electronic ignition contacts need replacing (if you have a gas drier with electronic ignition). Not sure about an electric drier, but probably the heating element needs replacing, or the thermocouple sensor (most likely). None of these are very expensive.
Jul 23, 2014 | Kenmore Dryers
Dryer taking to long to dry cloths, all vents are clear
sometimes a element that heats the dryer breaks giving it only power till were it broke /then will cause no or very little heat these run about 30-34$ depending on what type of brand of dryer you have
Apr 10, 2010 | Maytag PYE2300AY Electric Dryer
Td 4212 w Drier is not heating
Check if it still turns but no heat. If it's a kenmore or whirlpool, it's like a fuse in back of dryer. I would need mor info if it's not these models
Jul 28, 2009 | Zanussi TD4212W Electric Dryer
Drier shuts off
Thermostat controls heat. There is also a
motor centrifulgal switch, in the element
circuit, that the motor closes to insure
the motor is turning. Try another heat
setting. There is more than one
thermostat. You may have blown the
'thermal fuse' too, which requires
replacement. The elecment has a contact in
the 'timer'circuit too.
It is possible that your element has
failed also.
Tripped high limit. Must clean the lint
filter and the exhaust vent tube and all
the way in to the dryer. Hot air exit is
restricted.
Jul 12, 2009 | Whirlpool LER5636P Electric Dryer
Amana electric dryer will heat but only when.../ LEA60AW
It seems there is some wire loose, check on the both side of heating element points.
The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter.
Good Luck!!
Thanks
Jun 22, 2009 | Amana Dryers
My AMANA electric drier will not heat
Verify 220 volts to the terminal block where the cord connects.
If 220 is there, unplug the dryer and check the thermal fuse and hi-limit thermostats on the dryer cannister.
Feb 22, 2009 | Amana NDE2335AY Electric Dryer
Roper Drier no heat and continuous run for two hours
Your drier heating elements operates on 220 voltage, the drum and clock operate on 110, so you either have a blown fuse in one side of the fuse box ( easy fix )some time the circuit breaker will just need to be reset by turning it off and back on, or your heating elemant has opened up and will be more expences to fix, or it could just be a wire end has burned off. unplug plug from outlet remove back from drier and have a look see, and if bychance you have forgotten to clean your link trap if could be a high temp safety that has open and sometimes can be reset by pushing the reset button, all this is inside the back of the drier, if after that it may be time to call your friendly repair shop
Oct 20, 2008 | Roper REX4634KQ Electric Dryer
Maytag Drier, doesn't turn, doesn't heat, but dings.
hi thanks for the question i would check the power coming to the dryer it looks like its only getting 110 check that the appliance doc
Sep 17, 2008 | Maytag Atlantis MDE7400AY Electric Dryer
Need a diagram to change heating element and sensors
unplug the drier pull it out from the wall about a foot facing the drier take a small putty knife and insert it about 3" from the edge push the knife in till you feel the spring clip push in on it and lift the top then repeat that on the other side fold the top back till it leans against the wall look in the drier on the front edge of the front door panel there are two 5\16 in screws there remove them and un plug the light switch and the door switch assembly .grasp the front door panel and give it a quick snap forward to disengage the retaining clips and the door from the drum remove the door .Lay on the floor reach in and remove the belt from the idler pulley and blower motor pulley .Then while standing at the side of the drier grasp the belt with one hand and the front of the drier drum with the other and **** up sharply on the belt to release the drier drum from the rear drum bearing then remove the drum out the front on the rear you will see the heating element there will be one sensor on the heater pan that's the safety or high limit thermostat the tiny one on the drier body is the thermal overload the one on the vent at the bottom is the operating thermostat but its rare to have a problem with them if the drier is not heating the first thing i recommend is check your voltage and connections and don't assume just because its running its getting full voltage check it with a meter driers will run on 110 but will not heat without 220
Mar 10, 2008 | Frigidaire GLER341A Electric Dryer
Estate dryer kicks off circuit
you can check where the cord is connected to the drier did you use the cord off your old drier see if the cord is tight at the back of the drier and the center terminal of the cord should be on the center of the terminal block and why did you buy a new drier hold my rating till were done please
Jan 30, 2008 | Estate TEDX640JQ Electric Dryer
Dryers Logo
41 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
