Question about Kenmore 57029 Side by Side Refrigerator
Have a kenmore coldspot Side by side model 106.56562400 that is frosting up in the top section of the freezer. Have confirmed the defrost heater is working. Removed and turned off ice bin and maker. Didn't help
watugot
  • 290 Answers
SOURCE: Frost on icemaker door
Most likely the ice door is not closing properly.
Clean out the ice chute and look down it from the inside while you shine a flashlite up from the outside. If you see light around the door then it needs to be replaced or something is wrong with the mechanism.
Post back and let me know what you find.
Posted on Nov 21, 2007
  • 172 Answers
SOURCE: Kenmore Coldspot w/Ice Maker Not Making Ice
hi LOP7,
In most cases you can easily solve this problem.
step one would be to make sure your freezer is getting cold enough. If you have icecream in your freezer is it frozen solid or is it soft. Most icemakers cycle around 0 degrees and if your freezer is not getting to 0 then it will not cycle and it will not make ice.
Step two would be to make sure you icemake is cycling. To do this simply lift the little shut off arm on your icemaker and wait about an hour then go back to the icemaker and drop the arm down. The icemaker should start going through a cycle. You should notice the arm slowly begin to raise and the ice dispencer fingers will begin to turn. Then you will hear it call for water. You may hear a humm.
If the freezer is cold enough and the icemaker is cycling that only leaves the inlet valve. replace the valve and enjoy the ice.
If the freezer is cold enought and the icemaker does not cycle, then you have a bad icemaker. Simply replace the icemaker and viola.
Third if the freezer is not cold enought 0 defrees. Then you may have a defrost problem. In this case post more info and I will be happy to help. Good luck mca0824@aol.com
Posted on Apr 30, 2008
gaeb7
  • 25 Answers
SOURCE: Frost build up in the freezer section of my side by side Kenmore
Replace the defrost clock.
Posted on Feb 25, 2009
tborn6
  • 700 Answers
SOURCE: Refrigerator doesn't defrost
theres a defrost control on the unit that is probebly bad. its in the upper right of the refrigerator aand depending on the unit is either solid state or mechanical
Posted on Mar 27, 2009
  • 531 Answers
SOURCE: defrost timer location on Kenmore model 106.56542400
carry control board part#2149705
Posted on Apr 06, 2009
I have a kenmore coldspot model 70167998 - loud vibration in freezer; i'm thinking maybe it's the frost free fan going out? Is this a fire danger?
no theres not any fire danger,it may just be the fan blades hitting ice build up due to defrost issues you will need to remove the rear inner wall in the freezer to see exactly what it is
Jan 31, 2013 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
I HAVE A KENMORE COLDSPOT 106.56542400 MODEL.THE REFRIGERATOR DOES NOT GET COLD AND BOTTOM FREEZOR SECTION FROSTS UP.IF I UNPLUG REFRIGERATOR FOR A DAY,EVERYTHING WORKS OK FOR ABOUT 2 WEEKS AND THEN...
We had the same thing and the problem was the frost sensor on the coils inside the freezer. It is behind the metal cover that gets all frosted up. When it works it senses frost on the coil and tells the control panel to activate the defrost wire which heats up the space melting any frost and then shuts off.
Our issue was the frost sensor but it could also be the heating element or the control panel. Anything in that little system.
Sep 21, 2010 | Kenmore 56549 / 56542 / 56544 / 56546 Side...
Kenmore Coldspot freezer too warm
Remove the access panel in the freezer section to expose the evaporator coils. If the coils in the freezer section get plugged up with frost, this frost will block the evaporator fan motor from blowing the cold air around. The fan blade can also hit this frost and either become noisy or stop altogether. Locating the defrost timer can be tricky....they are often hidden behind the back bottom corners of the fridge at the bottom, in the last few years the timers have been located in the ceiling of the fresh food section, and some behind the cold control cover. Once you locate the defrost timer, slowly turn the screw like wheel in the middle of the defrost timer with a straight screwdriver until the fridge shuts off. You are now in defrost. If the defrost heater(s) comes on now, replace the defrost timer and defrost thermostat. If the heater(s) does not come on, you can ohm test the defrost heater for continuity or volt test for 120 volts to the heater(s). If you have no power to the defrost heater(s) you can also bypass the defrost thermostat to see if the defrost heater will come on, join the 2 wires together to bypass the defrost thermostat. If the heater now comes on, replace the defrost timer and defrost thermostat. If the heater itself is bad, defrost the fridge with a hair dryer, replace the defrost heater* and defrost thermostat. If the defrost timer seems "hot" to the touch or is noisy ( like a ticking or screeching noise )...replace it.
Hope this helpout......
Jul 28, 2010 | Kenmore Refrigerators
Kenmore Coldspot model 106 - Snowing in freezer!
its not defrosting. check heater operations. bimetal near heater. check defrost timer
Feb 08, 2010 | Refrigerators
Mar 26, 2009 | Kenmore 53342 / 53344 Side by Side...
Kenmore coldspot not making ice, and not cooling in the bottom
Your refrigerator is frosted up. Remove the inside panel of your freezer. Defrost the ice out of the coils and check the heater and bi-metal. If both are good then your defrost timer is bad. If one is bad replace and you have it fixed. Good luck.
Michael Anderson
(865)945-3808
Dec 02, 2008 | Kenmore 53642 / 53644 Side by Side...
Frost buildup
  It is not defrosting.  You have to remove back wall of freezer where frost is and take hairdryer to melt away frost.  You need to check defrost heater.  This is on bottom of evaporator coils.  It has wires going to it on both sides.  This has to be checked for continuity.  If ok on top of coils is a round unit called a defrost terminator.  This needs to be checked for continuity also.  This must be done before you defrost coils.  It should have continuity when its cold.
  If these are ok you probably have a bad timer or defrost board.
Oct 25, 2007 | Kenmore 53542 / 53544 Side by Side...
Kenmore 57029 Side by Side Refrigerator Logo
135 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
dweatherby
paulcarew
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
