Question about Kenmore Elite HE4 Electric Dryer
Kemore he4 electric dryer 5E error code ? - Kenmore Elite HE4 Electric Dryer
4 Suggested Answers
dididsaythat
  • 291 Answers
SOURCE: Error Code E1
got a model #
Posted on Sep 02, 2007
blueextc3221
  • 15935 Answers
SOURCE: I have a Kenmore Elite HE4 gas dryer no heat
The F40 error is a communication error which means the main control W10111616 is not communicating with the motor control part number 8544799.
First - go through the machine and check all harneses 7 plugs. This expensive machine uses the cheapest parts possible. Unplug and re-plug all connections you can find.
Particularly the controller (CCU) and motor.
Most likely neither control is the problem but since the main control was replaced we know it's not the problem.
The key to diagnosing this problem is to check voltage to the motor control. There is a black and white wire going to L1 and neutral.
Refer to the wiring diagram for an image of this.
If there is 120 volts to the control and the blower motor is not running then the 8544799 motor control is most likely at fault.
It is more likely you will not read voltage there.
Use extreme caution checking live voltage and only do so if you're comfortable and confident using a volt/ohm meter.
If there is no voltage to the motor control and the main motor doesn't run the thermal fuse can be at fault or the main control which was replaced and didn't help.
From the description you give I believe the main motor is running when you get the F40 code so the thermal fuse and main control are most likely okay.
If there is no voltage to the motor control then the problem can be a fuse link that may be open preventing voltage from getting to the motor control.
This part is not the thermal fuse and is not listed in the parts diagram or even shown on the wiring diagram. The fuse link is most likely the cause of your troubles.
If the inline fuse link is open you will have to replace the entire wire harness. The inline fuse link is not available as a separate part.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.#%@@#
Posted on Sep 23, 2010
blueextc3221
  • 15935 Answers
SOURCE: kenmore elite he4 quiet pak 9 dryer display code
PF - Power Failure - PF error code indicates a power failure during the dryer's cycle. Press and HOLD start to continue the cycle, or press off/pause to clear display.
Posted on Sep 30, 2010
What is an E1 error code? what does it mean?
Go to google and ask what does E1 error code mean on a Kenmore Dryer (Model #) and you will get several answers
Jul 29, 2015 | Kenmore Elite HE4 Electric Dryer
What does error code f1 mean on my kenmore elite dryer??
A model # will help a lot in trying to help YOU with an answer here . It's ALWAYS a necessity when you're posting on here for help . At LEAST 25 Sears Model #'s come up when you search for an Elite HE4 on repairclinic.com . .
Jul 20, 2014 | Kenmore Elite HE4 Electric Dryer
Kenmore (Whirlpool) Elite Electric Dryer 110.64086201. Diagnostic check generates a 5E fault code. What the heck is that?
5E - WATER DRAIN ERROR
5E is displayed if the water level frequency detected is 25 KHz or less in the initial phase of the UNB -detecting cycle. The Water Drain error can be cleared by turning POWER SW OFF and back ON.
Sep 28, 2010 | Kenmore Elite HE4 Electric Dryer
It is showing a code of PF on the front
Here is a tips that I wrote that will help to explain why you get the PF Error Code
PF Error Code for Appliances
heatman101
Sep 16, 2010 | Kenmore Elite HE4 Electric Dryer
Kenmore elite he4 quiet pak 9 dryer display code
May 15, 2010 | Kenmore Elite HE4 Electric Dryer
Error Code E1
replace the thermistor
Dec 20, 2008 | Kenmore Elite HE4 Electric Dryer
Kemore Elite HE4 Dryer
Hi! juysu
Please check the power cord, by checking if there is 240V on the power terminals inside the back of the machine where the power cord is connected.
InMrFixIt
Aug 27, 2008 | Kenmore Elite HE4 Electric Dryer
Kenmore Elite HE4 Electric Dryer Model 110.85087-400
Do you have a volt-ohm meter to check the heating element and thermal fuse??? I take it the dryer comes on and tumbles but doesnt heat up???
Jan 19, 2008 | Kenmore Elite HE4 Electric Dryer
Kemore Elite Dryer Repair
at the bottom of the unit there will be 3 torks screws remove them and the panel will open so you can see the insde and the heating element box...UNPLUG FIRST!!!
Nov 25, 2007 | Kenmore Elite HE4 Electric Dryer
Kenmore Elite HE4 Electric Dryer Logo
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
