Question about Spy Nikita Sunglasses
Who's sittiing next to me? - Spy Nikita Sunglasses
    Scholar:
  • 103 Answers
Hi
i am really sorry please be more specific and clear with your quetion so that i can help you out .
thank you
Posted on Dec 30, 2010
Tip
CREATING TRUST RELATIONSHIP BETWEEN TWO WINDOW DOMAIN(2003 server)
Using two domains for example Domain X and Domain Y.
You can create a two-way trust with domain-wide authentication.between the two domains if they belong to the same organisation depending on the imformation that you want to share or use between the two domains .you do this on an established domain controller for each domain.
  • STEPS
  • .On the server where you have domain controller for example on Domain X ,log on as an administrator then go to >Start >Administrative Tools >Active Directory Domains and Trusts.then Right-click on Domain X, go to > Properties. >click on "Trusts" tab. then > New Trust. click - [Next].
  • In the name field type the second domain to trust thats domain Y, in this case then click >next to continue
  • then Select the Direction of the Trust. either two way trust or one way but in this case its a two way then Click [Next].
  • In "Sides of the Trust", select the "This domain only" bullet. then [Next].
  • Set the Authentication level to "Domain-wide Authentication". then [Next].
  • you will be prompted to Enter a Trust Password twice. also Remember to make it strong enough to comply with password criteria in your domain security policy.
  • Click [Next] - [Next] - [Next].
  • Select the "No" bullet to the Outgoing Trust Confirmation - [Next].
  • Select the "No" bullet to the Incoming Trust Confirmation - [Next].
  • Click [Finish] - [OK].
  • Log off of DomainX ,
  • ON THE SECOND DOMAIN (DOMAIN Y) YOU PERFORM THE BELOW STEPS
  • Then .Login to DomainY using Administrator account.
  • go to > Start > Administrative Tools ->Active Directory Domains and Trusts.
  • Right-click on Domain Y, and select Properties. click on "Trusts" tab. Click the [New Trust...] then [Next].
  • in the Name field type domain X to indicate the domain to trust, then click [Next].
  • Select " the Direction of the Trust. in this case its a two way trust then Click [Next].
  • In "Sides of the Trust", select the "This domain only" bullet. Tthen Click [Next].
  • Set the Authentication level to "Domain-wide Authentication". then Click [Next].
  • you will be prompted to Enter a Trust Password twice.dont forget to use the same Trust Password that you used previously in the step above then Click [Next] - [Next] - [Next].
  • Select the "Yes" bullet to the Outgoing Trust Confirmation - [Next].
  • Select the "Yes" bullet to the Incoming Trust confirmation - [Next].
  • to finish Click [Finish] - [OK].
  • Then Log off of DomainY.
on Dec 30, 2009 | Computers & Internet
Why is my clutch pedal stuck down?
Return spring is likely missing
Apr 24, 2014 | 2000 Alfa Romeo 156
Set time hour day
Comdial DX-80
  • Press "Feature" "#" "*" and enter your password (default is "########").
  • Press "Show" and "0814"
  • Press "Save" and then "Show".
  • The option to change the year appears. Press "Next" to skip. To change, press "Chg" then enter 2 digits for the year and then "Save" and "Next.
  • The option to change the month appears. Press "Next" to skip. To change, press "Chg" then enter 2 digits for the month and then "Save" and "Next.
  • The option to change the day appears. Press "Next" to skip. To change, press "Chg" then enter 2 digits for the date and then "Save" and "Next.
  • The option to change the weekday appears. Press "Next" to skip. To change, press "Chg" until you see the day you want. Press "Save" and "Next.
  • The option to change the hour appears. Press "Next" to skip. To change, press "Chg" then enter 2 digits for the hour in military format and then "Save" and "Next.
  • The option to change the minutes appears. Press "Next" to skip. To change, press "Chg" then enter 2 digits for the minutes and then "Save".
  • Press the "On/Off" button to exit the programming mode.
Nov 04, 2013 | Comdial Executech® II 6600E-PG Corded...
My whirlpool LSR7233B will not spin or adjatate
sound's like the couping between the moter and the transmition is bad.to replace the coupling you first to remove the two screw's on the frount of the control panal.than pull control panal forward and lift up and back.next you nead to remove the clip's on the left and right.next unplug wire harness from door switch line.next lift the door and pull body forward and out.the whole body will come off.the first thing you will see is the water pump.remove the two 1/4# screw's from clamp's holding the pump on. next remove the two clamp's.next pull pump forward and to the left to keep it out of the way.next remove the wire harness from motor.next remove the clip's from motor and pull motor out.next remove what is left of the coupling from the motor and the transmition.install new coupling kit.you my have to use a exstention and a hammer to tap new part's on motor and transmition.next place rubber part on transmition and line open hole at 12 oclok.on the moter make sure you have one of the prong's at 12oclok to match the transmition.take the motor and line it up with the transmition and push it on.next reinstale the two clip's to motor.next reinstale wire harness to motor.next realine warter pump with motor.you my have to manualy turn coupling to get motor to line up with pump.reinstall clip's to water pump along with the two 1/4#screw's.next reinstall body on frame and reinstall the clip's to the left and the right.next hook up the wire harness back on the door switch line.next rotate control panal down and set in place and reinstall the two screw's and you are done.
Nov 17, 2009 | Coffee Makers & Espresso Machines
Labels on black and decker toaster oven worn off CT0650C
Top dial is Bake/Broil knob, it goes left to right. Starts with OFF @ 9 0-clock next is 100 dgre then @12 o-clock 180 Deg. is at top center next is 250 Deg. next 350 located opposite of off. Next @ 4 o-clock is 400 Deg. Next @ 5 o-clock is 450 Deg. and finally at the bottom at the 6 o-clock position is BROIL. The Center Knob is BAKE TIMER . Starts @ off position as 0, next @ 10 o-clock is 10-mins. Next @ 12 o-clock position is 20 mins. Next @ 2 o-clock pos. is 30 mins. Next @ 3 o-clock pos. is 40 mins. Next @ 5 o-clock pos. is 50 mins. Next and finial pos. is 60 mins. The Bottom knob is TOAST @ the 9 o-clock is is 0 next @ 11 o-clock pos. is Light , Next between the 12 & 1 o-clock pos. is MEDIUM and the final pos. @ 3 o-clock is DARK. TOAST.
Jun 13, 2009 | Black & Decker CTO650 1500 Watts Toaster...
Step by step guide to installing sap on windows 2003
hi dear
SAP4.7 Installation On Server 2003 SAP 4.7 INSTALLATION GUIDE 1. CREATE C PARTITION 6GB AND D PARTITION 70GB. INSTALL O.S SERVER. SET SYSTEM YEAR TO 2010 OR 2. CREATE LOOPBACK ADAPTER. START→ SETTINGS→ CONTROL PANEL ADD OR REMOVE HARDWARE→ NEXT→ NEXT→ SELECT ADD ANEW DEVICE NEXT SELECT WANT TO SELECT THE HARDWARESELECT NETWORK ADAPTER SELECT MICROSOFT NEXT NEXT FINISH. 3. CREATE IP ADDRESS MY NETWORK PLACES LOCAL AREA CONNECTION RIGHT CLICK PROPERTIES SELECT INTERNET PROTOCOL (TCP/IP)ADDRESS CLICK ON PROPERTIES AND IN IP ADDRESS 200.200.200. 20 AND OK OK 4. VIRTUAL MEMORY MYCOMPUTER RIGHT CLICK PROPERTIES ADVANCED TAB CHANGE SELECT D DRIVE INITIAL SIZE 2000 MAXIMUM SIZE 2000 CLICK SETOK OK OK 5. COPY ALL THREE DVD IN D DRIVE. SEE THAT D DRIVEMUST HAVE ATLEAST 54-55 GB FREE SPACE. 6. JAVA 1.4 INSTALL [FROM DVD 1] JAVA 1.4 DOUBLE CLICK NEXT I ACCEPT NEXT NEXT NEXT FINISH. JAVA PATH MY COMPUTER RIGHT CLICK PROLPERTIES ADVANCED ENVIORNMENT VARIABLE [SYSTEMVARIABLES ] SELECT NEW VARIABLE NAME JAVA_HOME VARIABLE VALUE ----------- START RUN BROWSE SELECT DRIVE PROGRAM FILES ANDPASTE IN VARIABLE VALUE BOX {Enter Path of JAVA) OK OK OK . 7. ORACLE 8I INSTALL [FROM DVD 3 ] ORACLE 4 NT I386 SETUP ORACLE 8I NEXT NEXT NEXTGLOBAL DATABASE NAME ORA NEXT INSTALL FINISH [ OREXIT] 8. INSTALLATION . [FROM DVD 3] KER NT I386 NTPATCH R3 DLLN DOUBLE CLICK ON THIS PRESS OK. KER SAPINST NT SETUP. SAP 4.7 INSTALLATION SELECT THIS AND PRESS NEXT NEXT SYSTEM ID ----- GIVE ANY DIGIT ALPHABETS [EX: SAI] NEXT SELECT CENTRAL INTANCE NEXT NEXT SELECT LOCAL INSTALLATION NEXT NEXT SELECT C DRIVE NEXT ------- GIVE PASSWORD AS 123 IT WILL ASK TWO TIMES THATPASSWORD NEXT 9. AFTER INSTALLATION OF ABOVE STEP GO TO : \ RIGHT CLICK ON USR SHARING & SECURITY SHARETHE FOLDER IN SECURITY TAB TICK ALL ALLOW. GO TO PROGRAMS SAP INST ORACLE KERNEL CLICK ONPREPARE NEW INSTALLATION. THEN AGAIN GO TO PROGRAMS SAP INST ORACLE KERNEL CLICK ON SAPINST SERVE WITH GUI. AGAIN FOLLOWS THE STEP IN STEP 8 WITH THE FOLLOWINGCHANGES. SELECT DATABASE INSTANCE INSTEAD OF CENTRAL INSTANCE SELECT LOCAL INSTALLATION NEXT NEXT SELECT D DRIVE D DRIVE} FOR BOTH OPTIONS NEXT NEXT IN PACKAGE LOCATION GIVE THE ADDRESS OF DB1-----ETC. DB1 EXPORT 1 LABEL.ASC DB2 EXPORT 2 LABEL.ASC DB3 EXPORT 3 LABEL.ASC EXPORT 4 LABEL.ASC EXPORT 5 LABEL.ASC EXPORT 6 LABEL.ASC EXPORT 7 LABEL.ASC NEXT NEXT. SELECT THE OPTION NO MNLS REQUIRED AFTER THIS IT WILL TAKE 15 HRS FOR INSTALLATION. ITWILL SHOW SUCCESSFULLY INSTALLED. 10. GO TO GUI GUI WINDOWS WIN32 SETUP. ã NEXT NEXT SELECT ALL NEXT INSTALL. 11. AFTER THAT CLICK ON SAP LOGON IN THAT CLICK ONNEW ITEMS DESCRIPTION ANY NAME APPLICATION SERVER TO KNOW THISOPEN SAP MANAGEMENT CONSOLE, IN THAT CHECK THE NAME ABOVEPROCESS LIST AND FILL WITH THAT NAME. SYSTEM NUMBER 00 12. CLICK ON LOGON USER ID DDIC PASSWORD 19920706. THEN GO TO SU01 TRANSACTION. GIVE THE USER SAPUSER (this is the user name to logon to sap) THEN PRESS F8. GIVE ANY NAME IN LAST NAME INITIAL PASSWORD REPEAT PASSWORD. THEN CLICK THE TAB PROFILES GIVE SAP _ALL SAP_ NEW & THEN PRESS ENTER & SEE IT WILL ASK THE PASSWORD , THIS IS THE PASSWORD TOLOGON TO SAP, GIVE ANY PASSWORD AND LOG OFF. 13. AGAIN LOGIN TO SAP NEW ID & PASSWORD AND THEN GOTO SE38 AND CREATE A PROGRAM STARTING WITH LETTER IT WILL ASK FORACCESS KEY. IN THAT TYPE 366 87 66 322126 127 8 694. Thank you
Imrna
Pls rank me as possible have nice day
Apr 20, 2009 | Microsoft Windows Server Standard 2003 for...
LOST COMBINATION
When you lose the key you need to contact sentry and provide your details for security reasons.
They will give you the key.
| Sentry® Safe | Contact Us
Dec 14, 2008 | Sentry Fireproof Safe
How too change time
Norstar Merdian Press Feature.
Enter "**8463".
Enter the password (default is 266344). The display shows
Hour: 01
Next Change
Select CHANGE. Display shows:
Hour: __
Cancel
Enter two digits for the hour. Chose AM or PM when Prompted.
Select NEXT.
The display shows:
Minutes: 00
Next Change
Enter the minutes.
Press the RLS button to end, or press NEXT to change the date.
The diplay shows:
Year: 99
Next Change
Enter the two-digit year.
Select NEXT and repeat to change the month and day.
Press the RLS key to save the time and date and exit programming.
Top of Page
Norstar Meridian CICS Time
  • Press "FEAT".
  • Press "*".
  • Press "*".
  • Press "266344" (CONFIG) or "23646" (ADMIN).
  • Enter password "23456" (ADMIN) or "72787" (SCPLUS).
  • You will see "Terminals & Sets".
  • Press "Next" five times.
  • Press "Show"
  • When you see "Hour", press "Change" or "Next" to skip.
  • Type in the hour using military time as a 2 digit number.
  • Press "Next".
  • When you see "Minutes", press "Change" or "Next" to skip.
  • Type in the minutes using a 2 digit number.
  • Press "Next".
Date:
  • When you see "Year", press "Change" or "Next" to skip.
  • Type the year in 2-digit format.
  • Press "Next".
  • When you see "Month", press "Change" or "Next" to skip.
  • Type the month in 2-digit format.
  • Press "Next".
  • When you see "Day", press "Change" or "Next" to skip.
  • Type the day in 7-digit format.
  • Press "Next".
  • When you see "End of List", Press "Rls" to exit.
Top of Page
Nortel Norstar Telephone Systems Changing the time on a Norstar system must be done using a display phone. Using a M7310 or T7316 the right 2 buttons under the display are "NEXT" and "SHOW" respectively.
  1. To enter programming mode press "FEATURE" and "* * 2 6 6 3 4 4"
  2. Enter password (default = 266344) - display should read "Terminals & Sets"
  3. Press "NEXT" 5 times - display should read "Time and Date"
  4. Press "SHOW" - display should read "Hour:___"
  5. Press softkey "CHANGE"
  6. Enter hour - display should read "AM OK or Change"
  7. Select AM or PM
  8. Press "NEXT" - display should read "Minutes:___"
  9. Press softkey "CHANGE"
  10. Enter minutes
  11. Press "NEXT" - display should read "Year:___"
  12. Press softkey "CHANGE"
  13. Enter year
  14. Press "NEXT" - display should read "Month:___"
  15. Press softkey "CHANGE"
  16. Enter month
  17. Press "NEXT" - display should read "Day:___"
  18. Press softkey "CHANGE"
  19. Enter day
  20. Press "NEXT"
Sep 15, 2008 | NorStar T7316E Corded Phone
Searching drivers for sharp AR-5316 for windows Vista platform.
are you sure it is for a Vista or is it trying to load to a Windows based OS???
try this site
http://promosearch.sharpusa.com/search/?sp-q=ar%205316%20drivers&sp-a=sp10009e61&sp-k=
Personally I do not like their site it is not as user friendly as other sites. ( have to do a lot of research to find what you want)
Good luck
Aug 17, 2008 | Sharp AR-5316 Advanced Digital Imager...
Spy Nikita Sunglasses Logo
Top Spy Clothing Accessories Experts
Da Doc
ray gallant
Are you a Spy Clothing Accessory Expert? Answer questions, earn points and help others
