Question about Sony NEC Optiarc AD-7200A IDE Internal DVD Drive DVD Drive
When I put a dvd in my laptop it spins but wont pull anything up to play it. It sounds like its trying but nothing happens. I used to could open my media player and then it would detect the disc but now that rarely works...
  • Sony Master
  • 27,725 Answers
Make sure that the dvd burner is getting enough power test all leads that are attached to the dvd burner including electical extensions and make sure they have a secure connection or just replace them there might be bad/faulty or
your drivers may have been corrupted or you might have a virus run your antivrus program
you might have to physically unplug the leads for this cd/dvd burner then plug them back in or
you might have to uninstall then reinstall your DVD/CD or uninstall the driver then reinstall for this device
control panel admistrive tools,computer management,device manager scroll down cd dvd rom drives right click you can you can update driver,roll back driver,or
select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall
if this does not fix the problem it might be a registry problem
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
hope this helps
Posted on Dec 30, 2010
Doesn't load the disk
Someone needs to open it to SEE what is happening--if the unit holds more than one disc (model seems to indicate that) you likely have a mechanism problem with something jammed or even broken--mechanism could also be out of alignment which is a task for a pro.
Look and see what is happening is first thing needed here.
Apr 24, 2012 | Cyberhome CH-DVD 300 DVD Player
All of a sudden my disk and dvd movies will no longer pop up when i put then in the disk holder and push them in nothing happens i can hear the disk spinning for a few seconds and then it stops but nothing...
Insert a disk. Wait for the disk-spinning to stop.
Open "My Computer".
Double-click the icon for the CD/DVD drive, to see if Windows can read anything from the disk.
Jun 25, 2011 | Sony VAIO VGN-FE880E/H Notebook
DVDs wont play? I put a DVD in and nothing comes up, it wont do anything now.. i dont know what happened. how do i fix this problem?
If there is no action after the DVD is put into the carriage then the mechanism is not reading. If CD is spinning but not reading it can be a fault optical unit.
In the first case you can reinstall the drivers, use the system restore to set it back to better program loading date.
Jan 11, 2011 | Gateway T-1620 Notebook
HELP!
If the driver was the problem, the drive itself would not likely be seen at all. The message idicates that the disc can not be read. It is possible that the optics have failed, but normally there would be an indication of this prior to complete failure. Try cleaning the lens using a coton swab and alcohol. This should resolve the problem.
Update this if the problem continues.
Dan
Nov 09, 2009 | Computers & Internet
HP 530 Laptop CD/DVD Drive Not Working
Please buy new CD/DVD drive since it wont open you cant event check using media. Its a possible mechanical failure.
Aug 17, 2009 | HP 530i (Q6750A) DVD±RW Dual Layer...
Acer aspire 2930 DVD player only opens some dvds
Try Media player classic under k-lite codec pack. Then open video files on the dvd. If it doesn't help try another codec player. If nothing helps could it be that dvd player is not capable of multilayer dvd reading.
Apr 10, 2009 | Acer Aspire 2930-4661 Notebook
Dvd drive wont work
You probably need a new drive. if the computer is only six months old it should still be under warranty. Just call the manufacturer and tell them you have a faulty dvd rom and see if you have to send the computer back or if they can just send you a new drive.
Dec 30, 2008 | HP Pavilion dv2700t Notebook
Cd/dvd combo drive (HP laptop) wont run
ur dvdrom need service ur dvd's lense need to clean
Dec 29, 2007 | HP (346789-001) CD-RW/DVD-ROM Combo Drive
Sony NEC Optiarc AD-7200A IDE Internal DVD Drive DVD Drive Logo
110 people viewed this question
Top Sony Computers & Internet Experts
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
