Question about E-Machines Computers & Internet
After booting machine up it will just die in 5-10 minutes
  • 67 Answers
Its a Motherboarboard issue. Replace the Motherboard.
Posted on Dec 30, 2010
I wanna know how to change a fuse for a saturn aura 2007.
What fuse ? Regular mini fuse ? Just pull it out with the fuse puller tool located in the fuse box compartment . Replace with same number fuse . 5,10 , 20 , 25 etc.. what ever it is . How To Safely Change Blown Fuse
Feb 02, 2017 | Saturn Cars & Trucks
Bible parables/stories to prove life after death?
No.eclesias 9:5,10 ezequiel 18:20proves that the soul dies.but God will resuracte humans.acts 24:15.this is the eternal life john 3:16 revelation 21:3,4.which will be on this earth.isaias 65:21-25
Jan 04, 2017 | Homework
Fridigdere up rite stackable dryer keeps beeping and shuts off after running for about 5,10 seconds,what do I check,?????
Google the model and codes. You should find instructions in how to to retrieve the codes and that will point you in the right direction.
Oct 14, 2016 | Dryers
Satellite a105-s4284 powers on and goes through boot successfully for about 1 minute then does a hard shutdown
I'm sure you have reseated/replaced the Memory mods? Have you thoroughly cleaned the fan, vents, heatsink? Have you done ANY hardware updates? Graphics? If you boot to Safe Mode any change? Have you tried a System Restore? Try another Cord/Charger with the Exact same power specs. Try removing battery and boot.
Mar 31, 2013 | Toshiba Satellite A105 Notebook
Blank screen "BOOTMGR is missing" for toshiba satellite A215-S5837
I would assume this may have Windows XP or 7, see if you can find the recovery disk for your machine. One of the things you can try is use the CD as your boot disk (you may need to enter the BIOS or SETUP to change the boot order...there will be a key to hit when you see the Toshiba splash screen when you first boot the machine...it will say press "<some key here>" to enter setup.)
Once you boot from the disk I would try getting to a command prompt and running the following command: chkdsk c: /f /r
This will scan and repair any bad sectors on your hard drive and if they can be repaired it may make your machine bootable again. If they cannot be repaired, it may be that your hard drive is dying. Either way...if you get into the machine (even from the boot disk) if you can see the drive, I'd recommend backing up whatever files you can, because if the drive dies, you will lose your data
Feb 28, 2013 | Toshiba Satellite A215-S5837 Notebook
My aunt have inherited a laptop from her late husband, she said the time she uses it ( almost two years after the husbanded passed away) it never asked for a username or a password until when she took it...
You can remove or change the Windows User oradministrator's password. You need access to a computer with Internet access todownload the Hiren's Boot CD and burn it onto a CD. Then insert this CD into the laptop/computer and boot upthe laptop/computer with the Hiren's CD and follow the instructions. There are very useful utilities CD and it a Linux boot CDwhich contains quite a lot of Utility programs including a password removalprogram. Click on one of these links todownload HIREN'S BOOTCD :- http://www.hirensbootcd.net/ http://67.20.82.163/
Feb 15, 2011 | HP Compaq nx9030 Notebook
I have acer itnel atom, its window has currpted and i installed new window xp but it takes atleast 20-30 minutes to start.what i should do for proper start, Thanks
Your hard drive may be dying and cannot read files as fast as it should. A brand new windows installation should boot withing 1-2 minutes. Having a bad hard disk would also be the cause of your windows corruption in the first place. Listen to your computer boot up and see if it makes and identical clicking patterns, you will hear clicking regardless but make sure they stay random. if your disk is dying you will hear the same click over and over as it tried to read a specific file.
Jan 19, 2011 | Acer Aspire One PC Notebook
Rust on the lid
You will need to use steel wool to lightly scour off all rust, Then you should use an enamel paint or clear fingernail polish to repaint the area.
Oct 11, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
T22 boot fine, runs for four or five minutes and then dies.
The "circle z" is the power indicator light. The fact that this stays on tells that this is not an overheating problem, which is common, since in that case the power and light would go off Do you all know a blast of canned air or whatever source can clean out most dust and lint accumulations that cause this problem? Just blow in where the hot air comes out. It sounds like it could be a hard drive probem, recently I have had more failures of fairly new ones. You might try booting it in safe mode, hit (F8) while starting to boot, and see if you have the same trouble, this would eliminate a driver problem as the source if it didn't happen in safe mode
Feb 26, 2009 | IBM ThinkPad T22 2647 Notebook
Computers & Internet Logo
23 people viewed this question
Top E-Machines Computers & Internet Experts
Matthew Spark
Matthew Spark
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
