Question about Crayola Color Wonder Magic Light Brush
The brush isn't lighting up when i hold it over the pots
How does blade remover from can opener for cleaning
Spray it with kitchen cleaner, wrap it in clingfilm and leave it for 20 minutes. Scrub it with a wet pot brush. Keep dipping the pot brush in water until it comes clean.
Jan 13, 2016 | Office Equipment & Supplies
My scooter slows down then goes back up again
The problem you have got is the throttle pot is faulty. Get this replaced and it will be fine
Jun 19, 2015 | Pride Mobility Products Celebrity X...
I have a hard time starting my pathfinder sometimes, it wants to drag.
have got same problem with my 95 terrano deisel. if you leave for 10 or more seconds after glow plug light goes out it starts fine. aparantly they still glow after the light goes out.
Dec 27, 2011 | 1995 Nissan Pathfinder
Sparking at brushes
This isn't abnormal although cleaning the armature with fine emery or sandpaper can help.BTW, new brushes will always need a period of run-in before their contact with the armature has reached its best.
Nov 27, 2011 | Food Mixers
Where is the belt housed on the Hoover vacum cleaner model U5461-900? The belt number is 38528-033 but I can't find where the broken belt is to replace it.
Simply lay the machine down with the brush assembly facing upwards, and remove the four screws holding the bottom plate in place, and remove it. Put the new belt around the motor shaft, then around the brush assembly and push the brush back into place. Turn the brush with your fingers before replacing the bottom plate, to be sure the belt isn't caught between the brush and housing.
Jul 27, 2011 | Vacuums
My Moka Easy Bialetti electric espresso maker switches off before all the water has been percolated through into the upper pot. I have recently replaced the rubber seal etc. at the base of the pot.
I emailed support at Bialetti and here is what I got:
Check the coffee funnel for any dents around the edge of the funnel. Normally if this brewing problem happens after changing a gasket the problem is a dent or the funnel is out of round and the new gasket isn't formed to it like the old gasket was. Don't bang the funnel to get grounds out or it may dent or get out of round. Try pulling the funnel over to one side in the water chamber and if you see a space on one side pull it tight with the other finger to bend back into shape if possible or replace the part.
Take the gasket and filter plate out from under the upper unit and hold the filter plate up to the light to check for any clogs right in the center where the coffee brews up. You should be able to see through all the holes in the filter, brush clean if needed
Jan 13, 2011 | Bialetti Moka Easy 6-Cup Espresso Machine
Scooter is about 6 years old. Light to medium use on pavement. Batteries about a year old. Problem: It looses power intermittently. Some days scooter work fine. Other days not very good. It seems like...
ahs could be the brushes they are pretty easy to check. On the rear of the motor should be 2 access screw covers carefully remove them and slowly remove each brush. if they are worn more than halfway I would replace them. Now I have seen your problem caused by dirty or worn speed pot. The speed control pot is fairly inexpensive to buy and easy to replace. If you have an ohm meter you can ohm it out checking for erratic meter movement as you slowly turn the knob. you should get a smooth increase or decrease in the meter as you turn the pot up or down. Hope this helps you
Oct 05, 2010 | Golden Technologies Golden CompanioN II -...
Do not know how to program fresh start oasis full button over fil
Remove the brew basket and water defuser (sprinkler head) it should come off with a 1\2 turn.
Place your measuring pitcher or empty pot in place.
Turn the main power switch off in back of unit.
Press and hold the Brew(full pot) button.
While holding the Brew(full pot) button turn the main power button in back to on.
Once the red light flashes over the Brew(full pot) button release it, then press it once to start the brew cycle.
Let it flow until desired level in pot or measuring pitcher.
Press the Brew(full pot) button once to Stop.
Press the Brew(full pot) button once again to lock the settings into memory. Memory will store the settings even if machine is unplugged.
Half pot button is automatically set.
Apr 09, 2009 | Oasis FreshStart 80 oz 10-Cup Coffee Maker
Green light is blinking, but I am unable to trun the power on.
rival smart pot 38651 crock pot all light blinking
to reset this you need to hold both thye right and left button for 30 seconds. the cause of this is from unpluging the unit when it is on also a power failure will cause this. if this does not work hold all four buttons in. they only tell you this if you get the right person at Jarden Consumer Solutions
www.crock-pot.com
Oct 30, 2007 | Rival 38601 Smart Pot 6-Quart
Crayola Color Wonder Magic Light Brush Logo
66 people viewed this question
Top Crayola Toys Experts
Tom Chichester
Lawrence Oravetz
Cristal  Nash
Cristal Nash
Level 1 Expert
Are you a Crayola Toy Expert? Answer questions, earn points and help others
